Atlas VSS Option - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-24-2010, 09:39 AM   #1 (permalink)
Member # 94793
Atlas VSS Option
I'm putting a 5.3/4L60E in my Jeep. I have the 40 tooth sensor for the PCM in between the tranny and t-case. I'd like to put a speedo only sensor in the Atlas tailshaft so I get proper odometer/speed readings.
I know i can swap the tailshaft, but that seems like a lot of money for no reason. I can't run the Jeep 3-wire sensor that AA sells with my gauges. Is there a standard VSS that is compatible out there?
sylgeist is offline   Reply With Quote
Old 07-24-2010, 06:50 PM   #2 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
What gauges are you running? Stock?
ANDY<--- ME!
TrailWorthyFab.com<--- THE BEST DOUBLE BEAD LOCKS!
Project: Dookey's revenge<--- My Junk!
OFF ROAD GEAR<--COOL SWAG!
Old 07-24-2010, 08:19 PM   #3 (permalink)
Member # 94793
I'm using a custom Dakota Digital panel. I need a standard 2-wire AC signal for it.
Old 07-29-2011, 07:42 AM   #4 (permalink)
Member # 94793
In case anyone runs across this thread I found a solution. It's not the most elegant but it gets the job done. I bought the mechanical cable drive speedo gear housing from AA for the Atlas. Then I bought a sensor from Dakota that bolts onto that housing and there's my basic 2-wire speed sensor hookup.
Old 07-29-2011, 07:46 AM   #5 (permalink)
GM at TWF
Dookey's Avatar
Member # 23680
Thank you for updating your thread. It does help in the future.
ANDY<--- ME!
