Red neck welder - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-18-2010, 02:43 PM   #1 (permalink)
Member # 129774
Red neck welder
I'm wanting to build an engine driven welder on my TJ and am to cheep to buy one of the over priced pre made ones. I want to add a second alternator where my AC compressor would have went. I'm not worried about the easy parts about it like building the brackets or exciting the alternator to put out 36 volts. What I want to know is will a stock alternator and its internal voltage regulator hold up to the occasional on tail stick welding job?
D.P. Lynx is offline   Reply With Quote
Old 08-18-2010, 04:34 PM   #2 (permalink)
Member # 33026
google weldernator. Most use chysler or ford with the external votage regulator.
83 CJ9 TBI350/TH350/231/D300 8274 D60/14b, 15" airbags 39" PBMD
94 F350 460 165"wb towpig
Chrisbuilt is offline   Reply With Quote
Old 08-19-2010, 09:36 AM   #3 (permalink)
Member # 42281
In the tech section on th efront page there are plans to build an on-board welder, complete with part#'s
robs88yj is offline   Reply With Quote
Old 08-19-2010, 10:56 AM   #4 (permalink)
jpony645's Avatar
Member # 45974
Unless i missed it, the only thing I saw was the Ready Welder install.
jpony645 is offline   Reply With Quote
Old 08-19-2010, 11:19 AM   #5 (permalink)
Member # 93306
youtube has your answer watch these three videos. the kid in the vid is a little corny but pretty informative. also a link to the instrucables website where he listed the parts needed:http://www.instructables.com/id/On-B...-for-vehicles/
YouTube - Building a On-board Air Compressor / Welder Part1
YouTube - Building a On-Board Air Compressor / Welder part 2
YouTube - Building a onboard air compressor / welder results
[COLOR="Red"]BUY MY JEEP $7000 OBO:[/COLOR][url]http://www.pirate4x4.com/forum/showthread.php?t=754738&highlight=cheep+jeep[/url]
bardenk1 is offline   Reply With Quote
Old 08-19-2010, 02:58 PM   #6 (permalink)
BAMF
Member # 111998
Here's a little more in-depth info on an onboard welder.
http://www.midwesternmedicalmachine....tor/index.html
Tyler76010 is offline   Reply With Quote
Old 08-19-2010, 03:48 PM   #7 (permalink)
craigellis77's Avatar
Member # 31763
You missed it:
http://www.pirate4x4.com/tech/on-boardwelder/
My M38A1 build thread
craigellis77 is offline   Reply With Quote
Old 08-19-2010, 04:00 PM   #8 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
jumper cables, two battery's, and a coat hanger....
DJ404564X4 is offline   Reply With Quote
Old 08-19-2010, 07:00 PM   #9 (permalink)
Member # 22393
To be honest 2 batteries sucks, 3 works ok... but 4 rocks. We do it all the time, but if you got a compy best unhook the battery terms on your rig.
OlyWa
Originally Posted by ashman:I love seeing leafs on a cherokee. Its like having a mohawk at church.
OlyWaXJ is offline   Reply With Quote
Old 08-20-2010, 08:10 PM   #10 (permalink)
Member # 52164
I built one from a semi truck alternator (delco). I took it to an electric shop and had them remove the internal regulator. A ford or dodge alternator is ready to go as they have external regulators ( at least the older ones did). You want to use the highest amp alt. you can find as they start putting out a higher amp at a lower RPM. The one I had welded and ran grinders ect. It was like a 147 amp or so alt. Worked well. Just practice at different RPMs and for different heat settings and record your results for easier setting and welding on the trails. Good luck.
badk5 is offline   Reply With Quote
