duke it out
Member # 11132
Location: If I could start again, a million miles away.
@ smart ass
It looks like my garage now, when you are ready show some more pics. I will make a web page, too, when my axle swap is done. Good luck.
....“I never shot nobody I didn't have to”.... |
#7 (permalink) | |
Member # 9988
Man, I thought that you only aired down when going wheelin'...I have to air down in order to get my piece into the garage.
Building tools that create the 4th state of matter. |
Member # 1792
Just curious,How are going to do this?Going to build a bumper/ crossmember and hang the springs from this?What springs are you useing?Should work pretty well I would think.So some more pics as you get further along.Blazin
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kids 70Jeepster fullwidth on 34/9.50 swampers. |
#17 (permalink) |
Member # 2757
FRONT
87 YJ DANA 30 RC 4" LIFTED YJ SPRINGS STOCK LENTH YJ SHACKLE SHACKLE REVERSED RS9012'S REAR STOCK D35 locked with 4.11's gears from 87 yj (direct swap) -D35 Housing is BEEFED UP (I have an 8.8 - needs gearsd) 57" CHEB SPRINGS added aproxx 5" lift 4" EXT SHACKLES 3" BLOCK 6* Shim Aproxx 10" of lift.... with 35's & 4.10's ![]() 1989 XJ LIMITED - GOLD - BLING BLING!
ESREVER NI EVIRD |
#18 (permalink) |
Member # 2757
The front hanger assebly will be bolted with several 1/2" fine thead Grade 8 bolts... Two of the steering box bolts i have drilled through the angle iorn for, and shouldnt need that lame ass PS box holder arm/bar thing...
Whats with the small cast block at the end of the ps box? like its designed to keep the end cap from blowing off the ps box... The fromt shackle hangers will be welded into place, but before i do that, aboyt 16" of coverage area allong the frame in wich the rear shackle hanger will sit, will be lined with 1/4" plate and angle iorn, for added strenth, gussets will be added between the frame and the under paneling of the floor board... My hope is to be driveable front wheel drive next sunday, then a week after that have my custom sye done and ready to wheel!
ESREVER NI EVIRD |
#22 (permalink) |
Member # 7354
make sure that you sleeve the frame (both sides and bottom) around where the steering box mounts. 3/6s or 1/4 plate will do. This is a notoriously weak area on XJs. I ripped the box off my 97 twice and there was a two inch tear along the bottom of the frame in the area.
4" lift shackles? BOOOOOOOOTIE-FABALICIOUS!!!! SeanP
If you are not pissed off, you are not paying attention. |
#23 (permalink) | |
Member # 2757
Ur telln me!
pisses me off big time! arrg!oh well, i'll clean it someime... when i have time... ![]() Quote:
ESREVER NI EVIRD |
