Dana 60 ID - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-07-2010, 06:26 AM   #1 (permalink)
Member # 23020
Dana 60 ID
Someone has asked to verify that the axle I am selling is indeed a D60, and not a 50. Here are some pics- hopefully one of you smart folks can help me crack the code.
Front of pumpkin, no visual markings in the casting
Sticker on the tube. Does say 1999, so according to an old post I found of Mr. N's that should mean it is indeed a BJ60
Rear of pumpkin- bottom mark looks like NC smooshed together. There is also a 248 stamp in the top.
Overall shot of the axle
Can anyone help me out based on the numbers on the tag above?
I have a jeep. It is green.
HULK is offline   Reply With Quote Quick reply to this message
Old 10-07-2010, 07:33 AM   #2 (permalink)
robi615's Avatar
Member # 127789
I know there are threads on here that ask the differences between a dana 50 and dana 60, you could search for those threads. I believe a dana 50 has a 9" ring gear and i know a dana 60 has a 9.75" ring gear, so pop the cover and measure.
robi615 is online now   Reply With Quote Quick reply to this message
Old 10-07-2010, 07:38 AM   #3 (permalink)
Member # 63684
http://www2.dana.com/expertforms/deabill.aspx Type in your bom which is 610655-2 The other dead giveaway is the pinion nut on a 60 is 1-5/16 vs a 50 @ 1 1/8th. mark
Skorch is offline   Reply With Quote Quick reply to this message
Old 10-07-2010, 09:00 AM   #4 (permalink)
Member # 39607
It is a 60 if the tag is correct, the number (248)/60, 50/s are listed as (229)/50.
Parts Mike is offline   Reply With Quote Quick reply to this message
Old 10-10-2010, 01:01 PM   #5 (permalink)
Member # 140656
It is a Dana 60. 248 and 229 refer to the ring gear size. 248mm = 9.76" and 229mm = 9.01".
-Joe
Pirate Joe is offline   Reply With Quote Quick reply to this message
