jeep 4.0 harness question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-09-2010, 04:46 PM   #1 (permalink)
Member # 136252
Question jeep 4.0 harness question
I have a project I am working on that currently has a 258 carburated motor in it. I went to the junkyard today and picked up a computer,intake, exhaust, head and a bunch of other parts to swap a 4.0 head with efi on to my 258. I got the ecu from a different vehicle with the same motor because the one in the donor vehicle was gone. My question is are all 4.0 engine harnesses the same? I pulled the parts from a 94 grand cherokee laredo with a 4.0 and the ecu from a 95 cherokee with the same motor but the harness was in horrible condition so I figured I would buy one online. Are they all the same or do they differ between models/years for engine controls?
chimera_perpetua is offline   Reply With Quote
Old 12-09-2010, 04:53 PM   #2 (permalink)
Member # 136252
also do I have to use a grand cherokee harness or can I use a harness from a tj?
Old 12-10-2010, 03:39 AM   #3 (permalink)
Member # 98110
I would go back and get the harness from the grand.
tbrockey is offline   Reply With Quote
Old 12-10-2010, 03:44 AM   #4 (permalink)
Member # 136252
I would normally do that but the harnesses in both donor vehicles are torn apart from other people at the yard. Also does anyone know what wires I can throw away and what wires I can keep?
Old 12-10-2010, 08:48 AM   #5 (permalink)
Ghetto Fab.'s Avatar
Member # 6170
You can probably use whatever harness you want to, however there may be some smog equipment changes and some of the connectors may be slightly different. My guess is that all the wiring is essentialy the same though. Like others have said, I'd try to find a harness out of a grand cherokee the same year as your motor to make it easy.
As far as what wires to keep, you need to keep everything thats critical to engine operation, and everything else can go. You need to get a good wiring diagram. I like to start at the computer and go through each wire one by one untill I know what every wire coming out of the computer does and label the ends if I can. I was able to eliminate 2/3rds of my junkyard harness in a couple hours by doing so. Most of that was lighting and body electrical junk.
Kevo
Ghetto Fab. is offline   Reply With Quote
Old 12-10-2010, 10:12 AM   #6 (permalink)
Member # 136252
thank you for the info, do you know where I can find a wiring diagram? Or where I should start looking? I appologize for my ignorance but this is the first time I have ever attempted something like this.
Old 12-10-2010, 02:32 PM   #7 (permalink)
Member # 169466
Your best be would be get the factory service manual (FSM) for the year and model of Cherokee (XJ) or Grand Cherokee (ZJ) you are using as the donors. I got a 95 XJ and I posted a 95 ZJ FSM to http://www.workshopservicemanuals.com/. I do not know what was available for the 94 year.
You can search the site for the manual you want, but to download you have to register. I was leary, but so far it has worked out well for me. I got the manual I wanted and in a attempt to help others out, I posted the 95 ZJ FSM.
rer747 is offline   Reply With Quote
Old 12-11-2010, 06:57 PM   #8 (permalink)
Member # 175955
Another thing you will find handy in a decent manual is called a pinout chart. It tells you what every pin at the pcm connector goes to in a simple list. Like a wiring diagram but it will speed up the process alot if you know what you are looking at and it will also be very handy in making a wiring harness work if it doesn't exactly match the engine and pcm.
gearheadmb is offline   Reply With Quote
Old 12-15-2010, 05:21 PM   #9 (permalink)
Member # 48456
FWIW, my 6 cylinder '94 YJ is OBD-1, OBD-2 came in '95. The '94 OBD connection is under the hood. OBD2 ports came out under the dash.
half-cab is offline   Reply With Quote
