PROJECT:Primitive CJ - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-29-2010, 03:05 PM   #76 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
Im interested to see how you mount a steering box.
76 CJ-7... mostly chevy parts
www.centexoffroad.com
mudskipper4x4 is offline   Reply With Quote
Old 12-29-2010, 05:04 PM   #77 (permalink)
xPOLYMATHx
LucasFury's Avatar
Member # 113176
Send a message via AIM to LucasFury
Exactly. In order for me to use the Astro box I bought from you (I think it was you anyway,) I'd have to also move it forward (or rotate it) to keep it from contacting the tie rod. At that point my approach angle will be ruined. We'll see.
Dirty deed done dirt cheap!
and custom leather belts and such too.
1979 FSJ Chief almost for sale. Inquire within.
LucasFury is offline   Reply With Quote
Old 12-30-2010, 12:12 AM   #78 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Originally Posted by LucasFury View Post
I'm real anxious to see what you come up with for steering. I'm in the midst of an SUA XJ stretch, and steering will easily be the hardest part.
I will be using a steering box that mounts to the outside of the frame like that of a scout, ford, or toyota ifs - whichever one is more compact or suitable for my application
mounting a box on the inside like the factory one or astro box is out of the question, with the axle moved forward as much as I did its too cramped at full bump.
... that being said I have an astro van steering box for sale or trade
primate60 is offline   Reply With Quote
Old 12-30-2010, 07:24 PM   #79 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Full bump
Before and after pic taken from the front
in both pics the pass. side axle jack stand is maxed out and a little lower than full bump or right in between
Primitive 1 Ton
http://pirate4x4.com/forum/showthread.php?t=940930
Old 12-31-2010, 12:09 PM   #80 (permalink)
craigellis77's Avatar
Member # 31763
Originally Posted by craigellis77 View Post
Who's the maker of the tube fenders?
Originally Posted by primate60 View Post
Genright
Thanks.
My M38A1 build thread
craigellis77 is offline   Reply With Quote
Old 01-17-2011, 06:02 PM   #81 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
14" kings
springs are 200/250 x 14" to start I still need to order a helper spring but am currently undecided on the specefic one
Primitive 1 Ton
Old 01-17-2011, 06:10 PM   #82 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Picked up a steering box at the junkyard, basically just went and started looking at different vehicles that might suit my application
I ended up pulling one from an '86 chevy C20 van its basically the same as the astro box except its a little bigger and mounts up to the outside of the frame instead of the inside like the astro box
left:astro
right:C20
The pitman arms are interchangeable on the two boxes so I swapped the astro arm on for now - eventually ill make one thats longer but this will do for mock up
Primitive 1 Ton
Old 01-18-2011, 09:03 PM   #83 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
got a package in the mail from jb conversions
my new 32 spline rear output shaft assembly and a new seal for the front output shaft
Primitive 1 Ton
Old 01-18-2011, 09:10 PM   #84 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Primitive 1 Ton
Old 01-18-2011, 09:14 PM   #85 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
last shot before reassembly...
Primitive 1 Ton
Old 01-18-2011, 09:22 PM   #86 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
my new driverside drop dana 300
I decided to go with a 1310 cv yoke on the new output because I had a cv driveline made less than a year ago and it will be cheaper to have it modified than to remake the whole thing.
the yellow connector coming off the speedo is an adapter that came with the howell tbi kit
BLING...
Primitive 1 Ton
Old 01-18-2011, 11:52 PM   #87 (permalink)
YellowRenegade's Avatar
Member # 142386
sweet! how was the t-case assembly??? looks alot easier than the stock case
you going to run hydro assist?
some guys with 40's do and others don't. A buddy of mine has an AGR box that turns his tires no problem. And I have the factory box with the assist.
Josh
YellowRenegade is offline   Reply With Quote
Old 01-19-2011, 12:59 PM   #88 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
the case assembly was fairly simple I imagine it was easier to do than the stock case but I wouldnt know as all ive done was tear one apart.
I have thought alot about hydro assist my plan is to have it drilled and tapped by psc and possibly even use some of thier components when the time comes. However funds are a little tight right now and its not part of my immediate build plan.
Primitive 1 Ton
Old 01-20-2011, 12:43 PM   #89 (permalink)
Rock Hard Rock On
Canyonmann's Avatar
Member # 126126
good job bro! Ill be keepin track of your heap!
No quit fawkin around and get busy,,,,spring is not that far away
We may not have it all together, but together we have it all. ROCK HARD & ROCK ON OFFROAD BROTHERS!
My Build /forum/jeep-hardcore-tech/884419-all-chrome-bling-bling-wrangler-build.html
Canyonmann is offline   Reply With Quote
Old 01-20-2011, 10:43 PM   #90 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Thanks for the inspiration ... ive been tryin' to get in the 'quit fawkin around mode' for a few weeks now.
Primitive 1 Ton
Old 01-24-2011, 11:41 PM   #91 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
made a couple basic tabs for axle side lower link mounts using .25 plate. They will connected with a gusset also made from .25 steel before its finish welded.
Primitive 1 Ton
Old 01-24-2011, 11:50 PM   #92 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
I cleaned up the framerails and tacked on the link brackets. They are from poly performance I modified them slightly to get the correct angle I was after. The spacer type deal is .25 plate, it will be fully welded to the frame and then boxed in with another piece of .25 steel at a 45 degree angle and the top and bottom will be boxed with 3/16.
Primitive 1 Ton
Old 01-24-2011, 11:59 PM   #93 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Im pretty happy that there is 1 less jack under the jeep now.
the axle side upper link is also from poly I just cut it down a little bit to fit undernieth where the radiator will sit.
The upper is 1.75 x .120 DOM
The lowers are 2 x .250 DOM
There is about 8-3/8" of verticle seperation between the center of my lower link and upper link BOLTS... Does anybody see a problem with this amount of seperation?
Primitive 1 Ton
Old 01-25-2011, 10:46 PM   #94 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
some more boxing for the box using 1/4"
My panhard will be mounted to the inside portion of the frame which is now 7/16" thick
Primitive 1 Ton
Old 01-25-2011, 11:29 PM   #95 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
I kinda lag on the pics sometimes this was one of those times
I boxed in where the front top bolt will be going through the frame and into the steering box. With the notch out I did prior to the box install the back upper through bolt is basically the same way.
when I made the covering plate for the new frame edition I drilled 4 wholes where the boxed section was and tied it all together with some plug welds
Primitive 1 Ton
Old 01-26-2011, 12:56 AM   #96 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
like most steering boxes I have seen there is somewhat of an offset between from the box casing and the actual mounting surface. On the box I ended up using it was 1/2 inch as you can see below.
So I made some washer/spacer things that somewhat contoured to the mounting holes using two pieces of 1/4 inch plate welded tobether. I chose to do it like this because I was having trouble finding DOM that was a precision fit to the bolts and I didnt want to drill and retap the mounting holes. I think this will be a strong setup the skinniest section the bolts go through is 3/4". A lot of stress will be taken off the box when I can afford hydro assist.
ignore the ugly welds
Primitive 1 Ton
Old 01-26-2011, 01:03 AM   #97 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
pictures are about 1/4 inch shy of full bump...
The bumper will stick out past the frame about 3.5 inches further than what is shown. I think that adding some kind of skid type protector will be needed in the future...
Anyway there you have it the box is mounted
Primitive 1 Ton
Old 01-26-2011, 01:46 AM   #98 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
I got a package in the mail yesterday from poly performance. I asked about the pirate discount (as always) he said no but gave me free shipping - it showed up the next day One reason I prefer ordering from them.
4 FK rod ends that use a 3/4" bolt.
2 right hand thread and 2 left
The ones on the right are high misalignment and will be used for the panhard bar
The ones on the left are for the draglink
The piece of tube at the bottom is 1.375x.188 heat treated chromoly
I have a matching size piece of DOM - and I cant quite decide which one to use for the panhard or draglink
Primitive 1 Ton
Old 01-26-2011, 02:17 PM   #99 (permalink)
Member # 14004
Do yourself a favor and ditch the plates that came with the Harbor Fright press. They can explode and do some real damage.
/forum/ballistic-zone/849831-arbor-plates.html
/forum/tools-supplies/880050-arbor-plates-letzroll.html
82 CJ7 - TBI 304/T18a/D300/44/70/4.88/40's
87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's
Kreep is offline   Reply With Quote
Old 03-03-2011, 10:50 PM   #100 (permalink)
Jacks wasted life
primate60's Avatar
Member # 145196
Took a little vacation from the heep.
think I got the steering figured out
I did run into a little bit of a problem. The fk rod ends only have 14 degrees of misalignment. That wasnt quite enough to keep up with my suspension travel...
Primitive 1 Ton
