Project "YJ Unlimited" - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-13-2011, 02:29 AM   #1 (permalink)
Member # 121272
So I've been goin at my project for a while now, I guess I'll share with you pirates what I have so far...
Just to state up front some design aspects:
Its an '87 YJ with the tub stretched to LJ dimensions, it will be 4-linked front and rear, coilovers on all corners, on 40" tires, GM 14 bolt rear, Ford kingpin D60 front, 4 wheel steering with ram assist in the front, full hydro in the rear, 4.6L stroker I6 engine etc etc... on to the pics. I'll give you guys the summed-up version.
Oh p.s. this build started out being fully outdoors (I had no shop to build it in) which meant I could only work on it when weather, time and temperature permitted but now I have built a small shop at my house and I can work on it anytime.
So $200 bought me this...
which got its ass cut off..
and another ass off another jeep, this one cut a little longer..
Got a borrowed shop to do some weldin' in..
bought a TJ dash off of Jeepforum.com
$850 bought me an unmolested '79 Ford D60..
and $200 bought me a GM 14 bolt with a detroit locker in it.
wait there's more...
ChocFlip201 is offline   Reply With Quote
Old 01-13-2011, 02:53 AM   #2 (permalink)
Member # 121272
Then bought a good condition frame off of a local classifieds website for $100, cut off all the un-necessary brackets and junk, then sandblasted the part I needed of it to get rid of any surface rust.
and hit it with a shot of rust-preventing primer.. (as you can see, still working outside)
Drove up to Idaho to exchange $300 for this... (1993 stock, complete 4.0)
Tore it down, had the block hot-tanked and checked for cracks, and had the head shot-peened and magnafluxed for cracks too. All good to go!
Marked the ports for gasket-matching and port 'n' polishing..
Mild intake port flow job on left, unmolested intake port on right.
more....
Old 01-13-2011, 02:57 AM   #3 (permalink)
Member # 121272
Now working in the new shop, first task is boat-sides.
Before:
This is where I originally wanted my cut (bottom of masking tape)...
But that wasn't going to work, so I moved it up and then cut..
And out with the old! (don't pay any attention to the frame in this pic, this isn't what you think.)
Expect more updates tomorrow.
Old 01-13-2011, 07:22 AM   #4 (permalink)
Member # 33026
are you going to trim back the front portion of the inner fender? Body mounts, cage, top?
here is my CJ9
83 CJ9 TBI350/TH350/231/D300 8274 D60/14b, 15" airbags 39" PBMD
94 F350 460 165"wb towpig
Chrisbuilt is offline   Reply With Quote
Old 01-13-2011, 10:21 AM   #5 (permalink)
Member # 121272
Honestly I havn't given the wheel wells that thought but I think i'll rattle that idea around in my head, and body mounts are getting reworked next after the boatsides, I stretched a stock YJ top, and yes it's getting a cage.
Old 01-13-2011, 10:30 AM   #6 (permalink)
Member # 121272
Oh and I also have a scrambler half-cab top for it.
Old 01-13-2011, 02:25 PM   #7 (permalink)
Member # 140656
First thoughts after reading:
TJ Dash
LJ length
Not a leaf in sight.
Then I thought, "Wouldn't it just be easier to put a YJ grill on an LJ?"
But that's no fun! Build looks great so far, I'm going to follow this one. Also, working outside sucks. I've had to do that with my Jeep. I live on the coast so I can't leave anything bare metal overnight or else it glazes over in rust.
-Joe
A half ass put together green YJ.
I have not failed. I've just found 10,000 ways that won't work.
Thomas A. Edison
Pirate Joe is offline   Reply With Quote
Old 01-13-2011, 02:55 PM   #8 (permalink)
New Beginnings
jpfrk2001's Avatar
Member # 99513
this could be something nice to watch
jpfrk2001 is offline   Reply With Quote
Old 01-13-2011, 06:14 PM   #9 (permalink)
Member # 121272
But that's no fun!
-Joe
When I started this project there would have been no way to afford an LJ or even a wrecked one, so I work with what I can hard to beat the price of a full body of a solid jeep for $200.
Old 01-13-2011, 06:19 PM   #10 (permalink)
Member # 121272
Day 2 of boatsides..
So I got the passenger side pretty much all wrapped up for now. I had to go run some errands this morning and get my 1/8" plate for the boatside skin. (this area is also having the 3/8" skidplate come up and cover this area so 1/8" was plenty enough).. anyways enough talk, here are the pics. Hopefully tomorrow I will be able to get the drivers side cut out and welded in all in one day, then onto the body mount alterations..
Old 01-16-2011, 07:26 AM   #11 (permalink)
wallysheata's Avatar
Member # 21191
Not sure I FULLY understand what you're saying. So you have 1/8" boat sides, then you're going to plate them with 3/8" or your skid plate from your belly is going to go up and tie into them? Having run 3/16" boatsides on my old YJ and 1/4" boat sides on my buggy reinforced ever 13" with 2x3-3/16 box, I can tell you that if the 1/8" is exposed at all it will not last. My YJ was so mangled up my doors stopped fitting after a few seasons from multiple rock hits, and even my buggy has dents in the 1/4" boat sides from a few boulders. Just a heads up.
Narrowed 6.0L TJ-7 buggy
wallysheata is offline   Reply With Quote
Old 01-16-2011, 08:23 AM   #12 (permalink)
New Beginnings
jpfrk2001's Avatar
Member # 99513
Putting a Snail in your engine bay would be a cool way to get some ponies from the engine. trust me when I say, the torque curve is UNREAL!
just sayin. .
Old 01-16-2011, 11:09 AM   #13 (permalink)
Member # 121272
just sayin. .
I've read your turbo thread a year or so ago and believe me I thought about doin the same thing, but when I opened up some options, this 4.6L will be enough oomph for me.
Old 01-16-2011, 11:13 AM   #14 (permalink)
Member # 121272
Yeah I'm having a 3/8" steel skidplate and it is going to come all the way out and bend up and cover all the exposed 1/8" plate. Yeah ha I knew 1/8" would get mangled up but I chose that for the skin because its thin enough to easily weld to the existing sheet metal of the jeep, and thick enough that I can drill it and bolt my skidplate to it. I'll probably run some UHMW too.
Old 01-16-2011, 07:55 PM   #15 (permalink)
Rock Hard Rock On
Canyonmann's Avatar
Member # 126126
gonna be sick,,,get after it
We may not have it all together, but together we have it all. ROCK HARD & ROCK ON OFFROAD BROTHERS!
My Build /forum/jeep-hardcore-tech/884419-all-chrome-bling-bling-wrangler-build.html
Canyonmann is offline   Reply With Quote
Old 01-16-2011, 08:35 PM   #16 (permalink)
Member # 121272
Here are the pics of the drivers side boatside. This side turned out a little better than the passenger side, even though the passenger side turned out pretty dang good imho.
Old 01-16-2011, 09:01 PM   #17 (permalink)
Member # 121272
Also these are the rims I'm using. 2008 H2 17" 8x6.5" (purchased and delivered from Wallysheata, Thanks!) also you can see that I still have to finish putting the clear coat on that top right wheel. They are already bored out in the center to fit over a Ford D60 hub.
Old 01-17-2011, 11:30 AM   #18 (permalink)
New Beginnings
jpfrk2001's Avatar
Member # 99513
Damn those look nice! Mine are from a earlier model H-2
When you build your stroker, build it for forced induction anyways while your doin it. Im just saying, you will get a stronger foundation, and if you wanna go full retard, you have the ability to do it.
Old 01-17-2011, 01:23 PM   #19 (permalink)
Member # 124842
I love the boat side look and purpose but why didnt you get more of an angle to it like a 45?
derteracing is offline   Reply With Quote
Old 01-17-2011, 04:48 PM   #20 (permalink)
Member # 121272
Ah I was wondering if/when someone would ask that. And my answer is you'll see why I chose this angle here soon. i'll make sure to reference back to this post and point it out when I can show you with pics.
Old 01-18-2011, 12:37 AM   #21 (permalink)
Member # 121272
Yeah that picture doesn't do them justice, that was taken with my phone, they really look smokin but I have been sorta trying to find one more from a 2008 so I can have a 5th for a matching spare tire but this solid-spoke style is pretty hard to come by.
Nope I have somethin else in mind for this stroker, it will get built with high-quality and very reliable parts and I won't be worried about it crappin out on me. Forced induction strokers are usually built with a lower compression ratio than what I'm going with so it would be hard to build one in preparation for some boost psi. I'm not worried about not having enough power for this engine, maybe for a different buggy I'll mess around with some power adders but that's just not in the plans for this one.
Old 01-18-2011, 05:19 PM   #22 (permalink)
Member # 124842
Alright well everything looks good, keep up the good work, ill be following your build for ideas
Old 01-18-2011, 07:34 PM   #23 (permalink)
Member # 127171
Do you know how much they were bored? (the H2s)
"You never really know a woman until you meet her in court!"
sleepsontoilet is offline   Reply With Quote
Old 01-18-2011, 07:45 PM   #24 (permalink)
Member # 121272
I don't remember exactly how much the new opening is, I had some other H2 wheels opened up for the ford d60 hub but that was over 3 years ago and I can't quite remember the measurement on exactly how much it needs.
There is the small recessed spot on the face of the mounting flange around each lug nut (looking at the front of the wheel) and I know that the new opening diameter will come almost all the way to that recessed area, if that makes sense.
Old 01-18-2011, 08:06 PM   #25 (permalink)
Member # 121272
Frame Backhalf stage 1
*I take a lot of pictures, sorry 56k interneters!
Well now its time to finish the frame backhalf and the new body mounts, first off I started by cutting off the most rearward body mounts on my frame off.. The black line is the center of the body mount hole (I already wrote down all the dimensions of the location of the body mount hole in relation to the frame)
Then I cut two 20" lengths of 3"x4" rectangle tubing w/ .25" wall thickness
Then I marked out my design, and used an 1.5" diameter hole saw and drilled a hole.
Then I cut out my fishmouth designs.. I did one male fishmouth and one female fishmouth so I can further space out my welding surface and minimize any chance of shear on my frame. In this picture you can see how much of the existing YJ frame will get sleeved with the new frame material. (this is directly above will be placed.
and with some persuasion I coaxed in into its place.. this isn't exactly quite where it will be sitting but it is really close, for illustration purposes anyways.
In this bird's eye picture you can see in the right side of the picture there is a gap between the YJ frame and the male fishmouth, this was done on purpose so that I can pinch that together with a C-clamp and get some welding surface around the corner of the bend.
I'm not quite done with working on this piece, I just wanted to take some pics to show you what I've been working on today. As you can see (in green) I am going to add some more 1.5" holes for rosette welds just for extra strength. (as they say, overkill is underrated.) I will be building the rest of my frame off of these new pieces.
