Dana 18 input gear location.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-21-2011, 02:39 PM   #1 (permalink)
Member # 5326
What sets the depth (front to back ) of the input gear on a Dana 18? Does it locate against a shoulder on the transmission output shaft?
Thanks.
Mieser is offline   Reply With Quote
Old 03-21-2011, 04:32 PM   #2 (permalink)
Member # 9991
Yes, and tighten it as tight as you can get it with a breaker bar. I use my feet!
[url]www.scotthansen.net[/url]
MrWillys is offline   Reply With Quote
Old 03-21-2011, 07:32 PM   #3 (permalink)
Member # 5326
Yes, but what does the gear locate against? The output bearing on the back of the transmission or some kind of step on the output shaft?
Thanks.
Old 03-29-2011, 09:36 AM   #4 (permalink)
FrankenCJ's Avatar
Member # 186160
The t-90 (which bolts up to the dana 18) does not have a shoulder or locating device on the shaft. The input gear locates off of the transmission output bearing. Also you might check the torque spec for the castle nut that holds the input gear in place. Im not sure but over torquing may cause damage to your bearing. The castle nut in the dana 18s I've taken apart have been finger tight. Im not saying its right but just saying.
FrankenCJ is offline   Reply With Quote
Old 03-29-2011, 10:20 AM   #5 (permalink)
Kaiser5's Avatar
Member # 26472
Yep, make sure that nut is torqued correctly. I had the gear walk off the shaft in Moab when the nut decided it wasn't happy being part of the team anymore. The nice thing about the 18 in this situation is the ease of access with the lower and rear covers. I had to pull the lower to fish out the nut and the rear cover to put it all back together. They run surprisingly well on motor oil.
'84 Bobbed -8, LT-1, TH400, STaK 3 speed, front 60 with Detroit/35 spline shafts, rear 14 bolt with detroit, garage built rear four link, front radius arm, 42" TSLs on locked Racelines, PSC assist, WARN 8274, lots of plating.
'82 -'8 As stock as it gets...
Kaiser5 is offline   Reply With Quote
