85-91 Dana 60 in TJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-02-2011, 05:21 AM   #1 (permalink)
Member # 183296
85-91 Dana 60 in TJ
I am going to run an 89 Ford HP60 in my TJ and have been trying to find a way to place the coils on the axle tube. Is there a way to actually cut the center section housing on the driverside axle tube to make more room? If so does it cause any problems or weaknesses for the axle?? Any pics that anyone has from already doing this would be great.
scRUBI84 is offline   Reply With Quote
Old 05-02-2011, 05:30 AM   #2 (permalink)
NEWBIE (in capitals)
Member # 141351
if by "trying to find a way" you mean you looked under your couch, then you may want to try searching, as it's covered often.
I put the same axle under my XJ, using a lot of information I found on here, after searching, and reading the many threads covering the swap.
short version:
cut casting 1/2 way into the hole in the casting (hole for leaf centering bolt)
cut all the way around, then cut in half so you can remove it
voila
beakie is offline   Reply With Quote
Old 05-02-2011, 06:31 AM   #3 (permalink)
MR. HOGG's Avatar
Member # 146572
this has been covered many times, search
"Professional Driver on a Closed Course"
Off-Road Supply
4x4 Syndicate: Hardcore Offroad Club
MR. HOGG is offline   Reply With Quote
Old 05-02-2011, 01:17 PM   #4 (permalink)
Member # 99310
damnit freeman search u asshole
2001 TJ on Reds
01tj is offline   Reply With Quote
Old 05-02-2011, 03:58 PM   #5 (permalink)
Member # 183296
this POS Govt comp wont let me use the search option out here.....i hate u Marcus
Old 05-02-2011, 04:25 PM   #6 (permalink)
Twisty's Avatar
Member # 97798
It can't be done. You're wasting your time.
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 5.38s, full hydro
newenglandjeepz.org
Twisty is offline   Reply With Quote
