Newbie
Member # 178289
TJ front driveshaft question
I removed my front ds this weekend to replace the u-joints and cure my angry sparrows problem. It was going well until I started to disassemble the cv joint. I had never removed one before and managed to puke the needle bearings all over my workbench. Anybody know what that part with the boot and needle bearings is called? Mine is toast, and all the local parts stores along with the dealership didn't know wtf I was asking for. The best I could get was the dealership telling me to buy a new ds. I'm not going that route as it'd be cheaper to go with an aftermarket shaft at that point.
Member # 160071
ive never seen needle bearings in any drive shaft. thats strange! my TJ ds doesnt have needle bearings
are you talking about the needle bearings that are inside the U-Joint caps? thats what it sounds like to me. have you ever replaced a U-Joint before? im not trying to be rude just asking.
1989 jeep yj 6 point cage mildly built SBC built TH 350NP 208 Dana 44 f/r 4.56:1 Last edited by dem3500; 08-24-2011 at 09:00 AM. |
Ruiner of the Things
Member # 130031
Its the centering yoke. Sometimes called a ball yoke or centering ball. Make sure the stud on the end yoke is in decent shape. There is also a spring that lives in there. You need a 1310 series for a stock tj. Napa sometimes has them in stock.
'97 TJ -SM465, KluneV/D20, HO72/HP60, ORIs, 40" Comp Treps http://www.pirate4x4.com/forum/showt...=781656&page=3 '42 Dodge WC53 - Cummins CRD, Allison 1000, HO72s F/R, 38" Michelins http://www.pirate4x4.com/forum/tow-r...airstream.html |
Newbie
Member # 178289
^this. Went to napa yesterday and they had the repair kit for it, but if I remember correctly the whole setup rides inside a rubber boot, which was cracked and all around fucked up on mine, which I think is what was causing the noise (cracks=no more grease). Basically I'm wondering if I can get the boot and shit anywhere. And I could be wrong about the needle bearings, they may have come from one of the u joints, but I got pretty disgusted with myself when I got a handful of them and haven't fucked with it for a few days.
Member # 130031
You can buy the boot separate. Rockford driveline IIRC. Catalogs are a bit complex but you should be able to source it from them.
Member # 190788
One quick question as I plan on doing this this weekend. If the centering ball and sleeve look alright, should I still replace it. My angry sparrows comes and goes so I am going to replace the ujoints up front to see if this cures it. Anything I should do to the centering ball if it still looks ok? grease it, clean it etc....? thanks for any help~Chris
