Member # 32019
amc 360
Hello all,
I removed and rebuilt a 360 (auto tranny) and going to replace my 304. I just recivied a flywheel from another 360. Were all the 360 flywheels balanced the same or do I have to take my flexplate and flywheel down to the machine shop to have it balanced alike? Thanks |
Archimedean
The amount of static imbalance (starting point) is the same for all 360s.
However, then FINAL balance (done as a rotating assembly) would be different engine-to-engine. The real question is; how far (or how close) to tolerance will your engine be if you put this flywheel on as-is? If you've done a gnat's-ass blueprint job on this engine, then I would say stop at nothing, spare no expense, and get this flywheel balanced on your rotating assembly. If you've done a 'normal' ring-bearing-gasket-cam-lifters-timing set job, then I would bet that you can run the stick flywheel as is. If it were mine, I'd throw it on and run it, but I wouldn't be doing a full-boogie blueprint drag-race style build for a Jeep.
Someone sort of local sell me a Dodge NP435, or the mainshaft/tailhousing from one. Or, sell me a Ford NP208 input gear... |
