Need help!! Should i buy this d60 tomorrow?????????? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-13-2011, 03:30 PM   #1 (permalink)
Member # 183431
Came across what i think might be a good deal. Planning a rear stretch in the coming months. guy wants $400 for the axle, says there is only very minor surface rust on the detroit, none on the ring gear. Reason i like it, 4:88s and a detroit are already there. He said it came from a 76-79 F250 and thats all he knows. He did say it was a FF as well, but didnt know spline count.
Thinking of offering him 300? Thoughts???
bofer is offline   Reply With Quote
Old 10-13-2011, 03:49 PM   #2 (permalink)
Archimedean
rustywagoneersdotcom's Avatar
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
At 400 bucks he should be willing to pull a shaft out and count.
But at 400 bucks, I'd bet it's 30 spline.
Someone sort of local sell me a Dodge NP435, or the mainshaft/tailhousing from one.
Or, sell me a Ford NP208 input gear...
rustywagoneersdotcom is offline   Reply With Quote
Old 10-13-2011, 04:57 PM   #3 (permalink)
Member # 183431
think its worth it? or should i just do a 14 bolt?
Old 10-13-2011, 06:33 PM   #4 (permalink)
Member # 132847
I could be wrong, but it looks like it's a balljoint front end. And if it is a balljoint Dana 60, it would have to be 30 spline, correct?
Redneck24/7 is offline   Reply With Quote
Old 10-13-2011, 06:34 PM   #5 (permalink)
Member # 183431
Im only looking at the Rear.
Old 10-15-2011, 06:55 PM   #6 (permalink)
Necromancer_tat's Avatar
Member # 198573
A 60 plus a functioning Detroit locker already set up for the gear ratio you want, and you haven't bought it yet for only $400? Just the locker is worth what he's asking.
Necromancer_tat is offline   Reply With Quote
Old 10-15-2011, 07:14 PM   #7 (permalink)
Ho Shorts's Avatar
Member # 109328
This
Depending on what you are running it in the 16 spline may hold up fine as well. The size difference between the two axle shafts is less than 1/8". I have a 16 spline 60 in the back of a CJ5 right now actually.
Measure the WMS, if it's 63.5" then it's a 16 spline but if it's the wider 67" then it's 30 spline
Originally Posted by Soundguy View Post
You don't need to take off the cover, just stick a screwdriver in that 50amp 240V plug under the panel while licking your fingers and touching the door of the panel. If your pecker rips through your jeans it's 3 phase.
Ho Shorts is offline   Reply With Quote
Old 10-16-2011, 10:36 PM   #8 (permalink)
Member # 75018
Thats an HD 60 or a dana 61 ,both late model and could have 30 or 35 spline depending on option list .
The deep ribbing gives it away,but a tough axle ,stronger then run of the mill dana 60's .
And point made earlier;detroit cost over $500 and gears with bearings $280+
'69 Jeepster charity case rockcrawler :imagined
pyrocrat is offline   Reply With Quote
Old 10-17-2011, 01:19 AM   #9 (permalink)
Member # 198573
Did you end up buying it?
