Higher spring rate TJ coils... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-21-2011, 09:28 PM   #1 (permalink)
Indy Will's Avatar
Member # 114707
Looking for a higher spring rate for the front of a stock-ish height TJ. I could stand about another 1" of lift if I had too.
Any common factory application for this or aftermarket part numbers?
Indy Will is offline   Reply With Quote Quick reply to this message
Old 10-28-2011, 09:54 PM   #2 (permalink)
Member # 100284
get Rubi coils, they are a higher spring weight and about 1" taller than stock TJ.
Silver '06 'X'
"The Pirate Boat!":skull:
KennyTJ is offline   Reply With Quote Quick reply to this message
Old 10-29-2011, 12:41 AM   #3 (permalink)
gtxracer's Avatar
Member # 25303
Actually Rubi springs aren't taller unless you use them on a 4cyl model with no hard top.
97 TJ 4500 wannabe Build Thread:
Instagram: @DukeEngineeringSolutions
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more!
gtxracer is offline   Reply With Quote Quick reply to this message
Old 10-29-2011, 05:56 PM   #4 (permalink)
Indy Will's Avatar
Member # 114707
Forgot to add I already have Rubicon coils....
Old 10-30-2011, 01:58 PM   #5 (permalink)
whiteman's Avatar
Member # 54841
The only thing you will probably find would be Old Man Emu coils. They offer a selection of different weights.
OME part# 2933 yields 2" of lift from stock and is good for an additional 180lbs of weight on the front.
whiteman is offline   Reply With Quote Quick reply to this message
