What wheel bolt pattern? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-26-2011, 05:14 PM   #1 (permalink)
Newbie
sac_jeep's Avatar
Member # 117376
Send a message via MSN to sac_jeep
I have never had the opportunity to select my bolt pattern before as I have whatever I have.
However, with my current build I knew it would come up sometime, but really have not thought too much about it, low on my list of things. Anyhow was just going to choose 5x5 1/2 for no particular reason when I asked some of the guys around here for any input on the performance differences.
Well that was a mixed bag of results.
My only requirements are 17" steel wheels, 35" and 37" tires.
Here are my options:
5 x 5-1/2" Bolt Pattern
6 x 5-1/2" Bolt Pattern
8 x 6-1/2" Bolt Pattern
For anyone who knows performance differences;
Any pro/cons?
Strengths/weaknesses?
Costs?
??? whatever
ECV: MorningWood
3, 5, 8, 1849 & 169
sac_jeep is offline   Reply With Quote
Old 10-26-2011, 05:18 PM   #2 (permalink)
247pia's Avatar
Member # 174055
What axles are you running?
247pia is offline   Reply With Quote
Old 10-26-2011, 05:35 PM   #3 (permalink)
Ajs biggest fan!!
RANGERROD's Avatar
Member # 172656
I'd go 8x6.5 that way 1/2 ton or one tons I wouldn't have to rebuy wheels.
RANGERROD is offline   Reply With Quote
Old 10-26-2011, 09:13 PM   #4 (permalink)
jamespadgett's Avatar
Member # 99417
id go what toyota/chevy 1/2 ton is. more wheel choices(especially used) plus you can lend/borrow from a toyota on the trail.
jamespadgett is offline   Reply With Quote
Old 10-27-2011, 09:07 AM   #5 (permalink)
Member # 87682
That would be 6 on 5 & 1/2
wranglerwilson is offline   Reply With Quote
Old 10-27-2011, 09:08 AM   #6 (permalink)
Member # 87682
Originally Posted by 247pia View Post
what axles are you running?
x2 Would not see the need for 8 lugs on 35-37 in. tires.
Old 10-27-2011, 09:56 AM   #7 (permalink)
Newbie
sac_jeep's Avatar
Member # 117376
This is for a SpiderTrax setup on a TJ.
ECV: MorningWood
3, 5, 8, 1849 & 169
Old 10-27-2011, 04:29 PM   #8 (permalink)
247pia's Avatar
Member # 174055
Finally. First I thought you were a dimwad.
The 6 on 5 1/2 is a good choice as mentioned above.
I vote 8 lug though because if you ever decide to sell your wheels you have a bigger market and if you get another wheeler it most likely will have or will be getting 8 lug axles so you can wheel swap.
