#451 (permalink) |
Member # 200081
Get some gasket eliminator http://m.grainger.com/mobile/details/?R=2LPP2 that stuff its great for sealing surfaces. Its a little more money but that stuff works
#452 (permalink) | |
spot me? mydfghgfff!
Member # 25303
yeah that's some change! Thanks for the link though, I might pick some up if I can find it locally. The Grainger here just closed.
97 TJ 4.0/np435/d300/3link/4link in progress Ultimate Wrangler Build Ups and Swaps Thread
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! |
#453 (permalink) |
Member # 187456
You do have all the grounds and other wires hooked up right?
[QUOTE=bigford;10609690]On a side note: I remember telling my second ex wife " My truck comes first, then my job, then you " I never liked that woman. [/QUOTE] |
#454 (permalink) |
Member # 25303
Didn't mess with any of 'em, so yes they should be fine. I can double check them but the bellhousing and CPS went out to Novak this morning.
#455 (permalink) |
Member # 187456
Grounds, fuses and relays are always the first things I check when I have an "electrical problem". Novak should be able to get you back on the road.
#456 (permalink) |
Member # 178200
You didn't check for spark/injector pulse before sending out the crank sensor and bellhousing, or did I read those posts wrong?!?!?!
Even if the crank sensor is in the total wrong location (assuming its correctly spaced from the flywheel trigger) you would have spark, injector pulse and at least a backfire or pop. I suspect you may have another issue somewere... USE PERMATEX "THE RIGHT STUFF" on your case and it won't ever leak again...... RTV is fawkin garbage!!!!!!!
#457 (permalink) | |
Member # 56430
There is also a kit (either Novak or Advance Adapters) which moves the CPS to the front crank pulley. And there's a chance, it's simply a bad sender. Good luck. Interesting build thread. Tony
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12 Member Eldorado Dust Devils, a PNW4WDA member club |
#458 (permalink) | |||
Member # 25303
/forum/jeep-hardcore-tech/260612-cutting-hole-bellhousing-cps-4-0-a.html http://www.jeeptech.com/convtrans/sm420yj/ /forum/jeep-hardcore-tech/354802-crank-position-sensor-cps.html /forum/jeep-non-hardcore/783310-tuesday-crankshaft-position-sensor-cps-question.html http://www.jeepforum.com/forum/f11/9...s-good-905398/ I got a little pop out of it when I poured starting fluid down the throttle body. Everyone I have asked and explained my situation to has told me it's the CPS. I'm all ears if you have something else you would suggest. Oh and picked up some Right Stuff.Quote:
Thanks. AA used to sell the CPS relocation kit but they told me their supplier had some quality control issues. They now only sell the bellhousings ($370) that have a CPS mount built in. Hesco makes the only other CPS relocation kit ($320+). I might take you up on those templates if Novak can't machine my bellhousing. Or I might have to find a fresh bellhousing to start with. I'll know more Tuesday when I call them. By sender do you mean CPS? I've tried two and tested both with an ohm meter so they should be good.
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! Last edited by gtxracer; 05-27-2012 at 02:49 PM. |
#459 (permalink) |
Member # 187456
Hey man "The Right Stuff" IS the shit! I've used it on my diffs, pinion seals and Np231 and its yet to let me down. Well worth the extra $ for a step of from RVT IMO.
#461 (permalink) | |
Member # 149566
Keep up the build, looking AWESOME!!!
Pacific North West Jeeper My HEMI, ROCK JOCK, 4-LINK, etc Build:: /forum/jeep-hardcore-tech/850159-1997-tj-2-5-l.html Seattle Fabricators: www.crawlmag.com www.bentmetalcustoms.net www.auburncarrepair.com www.home.comcast.net/~thoseguys/ www.xo-fab.com www.metalhavoc.com |
#463 (permalink) | |
Member # 56430
Edit: What flywheel do you have?
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12 Member Eldorado Dust Devils, a PNW4WDA member club Last edited by Treeclimber; 06-04-2012 at 08:20 PM. |
#464 (permalink) | |||||
Member # 25303
![]() Quote:
Thanks, almost there. ![]() Quote:
![]() Cleaning and draining the D300, new rear output seal and the Right Stuff about to go on ![]() My fantastic girlfriend bought me a bunch of posters and I decided I need more tool storage. Getting the garage organized finally gave me room for a rolling workbench. This is from Home Depot and is a Husky brand but it seems to be great quality. I've bought Craftsman in the past but they've gone downhill lately and Husky hasn't let me down. I've had their pro series tools for about 2 years now without any broken pieces. ![]() ![]() And finally I got my rear axle side shock mounts tacked in place. I am not sure if I am going to like the design so they've only got large tacks for now. Here's the design again, all bolted up-
#466 (permalink) | |
Member # 25303
![]() Slaved all day in the shop - have the next two days off as well so the jeep will get almost all my attention. I got the twin sticks mounted and they shift well so far but I'll have to try it with the vehicle running to really know. I really dig the twin stick setup though ![]() Sealed up the D300 best I could without tearing it down, only some minor small leaks. Realized the driveshaft needs to be massaged to allow any kind of droop easy fix for tomorrow though.Designed and drew up the extensions for the half corners to make them full corners. I also drew up the mount for the carrier bearing and will be getting both cut out of 3/16" by my buddy with a plasma CNC. Thanks Wes ![]() Best part - I went through hundreds of feet of wire and grounds - found one loose ground, tightened it up. No start. Can't hear the fuel pump, still trying to remember how to jump the fuel pump relay. Battery might not have enough charge, however, I just read this from one of the threads I posted earlier: Quote:
Something to note: the clown that installed the alarm system in this rig nearly burnt it to the ground. There's a couple wires that are melted but I knew this after I pulled the dash apart and hastily fixed his mess. There are a couple crucial wires that needed to be hooked up to the remaining alarm harness for it to run. I'll need to check those tomorrow. I'll try to take pics and note them for anyone else with a jacked up Clifford alarm install. CPS issue isn't suspect then. Before anyone says it - yes, I probably could have tried to troubleshoot this without sending the bellhousing to Novak but I'd rather have it done to know it's good to go. Now I'm tracking down the ground that's possibly missing and how to jump the fuel relay. Cliff notes - how do I jump the fuel pump relay and does anyone have a pic of the ground on an ax15? ![]() edit: I may have found the culprit but this may just be a sensor, probably back up light sensor edit2: yes it is, back up sensor (http://www.scribd.com/doc/7057536/Je...l-Transmission). Stu Olson has a neat little write up on this sensor and it's also considered a safety switch (http://www.stu-offroad.com/engine/aw4/ax15removal.htm).
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! Last edited by gtxracer; 06-08-2012 at 11:54 PM. |
#467 (permalink) |
Member # 25303
Whew, time for an update.
First, the Jeep runs. It still doesn't start from the key but it runs. I have to jump the starter relay but at least I know it's firing and idles. This is the mess from under the dash and I already pulled out about 100ft of wire before this: ![]() Pulled out all of it and said goodbye. This is without the two gigantic "brain boxes" that were shoved under the dash too: ![]() In the lower left corner you'll see three little fuse boxes. Yeah, those were shoved deep under the 4.0 and were just a GROUND. *facepalm* notice the one on the right! ![]() And this is what under the dash is supposed to look like after I repaired it:
#468 (permalink) |
Member # 25303
This brings us to today's fab and what-not-
carrier bearing mount, tacked together: ![]() welded the nut completely on the other side, I didn't want it coming loose ![]() Doesn't seem like much, but that little piece saved me hours of work and it only took me 30 minutes to draw up! Sorry for the crappy picture, lighting was terrible. These are the corner extensions. I will also have a lot more room for uptravel and future tire size plus it will accommodate the factory flare until I bend up some new ones- ![]() Tomorrow will be more of the same, hope to finish most of this. I need to pull the top cover off the np435, I think I misaligned the shift forks somehow when I put it on. I have the alignment guide picture somewhere and I'll post it when I find it again. Oh, and it felt great to have the 4.0 fire up and the twin sticks worked pretty good!
#469 (permalink) |
Member # 25303
It runs and drives, drove it around the neighborhood in 4lo. Couple things-
destroyed one of the cables on the D300 from the leverage of the twin sticks ![]() definitely going to flat tow it for now, it's LOUD no reverse, shift fork must not be lined up, easy fix clutch safety switch bypassed with a closed circuit (some say a fuse is a fix) starter works intermittently because of above corners are nearly done, came out well and will use stock flares for now steering hits the passenger side spring mount, need to trim it front locker seems to be engaged permanently, like a spool need to final weld the shock mounts finish front 2 piece driveshaft tidy up the welds, flap disc any remaining edges and paint them Sorry for my lack of pics and tech, I'll add more later. I spent most of the time in the shop from the past three days fixing little issues, tracking down wires, and finally driving around the block. Carrier bearing mount finished, ready to put in place. The plan for this came together well, the opening I drew happens to be in just the right spot for the bolt to pass through ![]() stubby short shaft of the 2 piece driveshaft ![]() corners, my fantastic girlfriend drilled the holes, what a sweetheart! ![]() The clutch safety bypass, took out the connector and made the circuit complete. Starter works most of the time, feels like the computer or solenoid is fighting the wiring for control over the starter. ![]() I'll be back Friday and will be kicking ass all weekend to get the TJ and Silverado ready for the trip next Tuesday.
#472 (permalink) |
Member # 25303
Thank you
![]() Final push is this weekend, wheelin on tuesday - thursday. New to-do list: paint armor, frame, etc mount rear flares and armor mount tailgate and spare make tunnel cover and paint it setup TJ for flat tow fab flat tow mounts for TJ finish weld the rear shock mounts and paint add studs for brake lines check fluids check brakes and clutch for leaks run through all bolts, add locktite or torque cut skid plate and mount it, paint finish weld rear driveshaft finish weld front shorty shaft fab and weld front slip shaft mount and weld carrier bracket and paint I also have to change out the catalytic converters on my silverado...that'll be fun.
#473 (permalink) |
Member # 198485
Nice jeep, looks like it should be a blast when it's done. I'm trying to get my long arm project done so we can go on vacation in two weeks.
My Build http://www.pirate4x4.com/forum/showt...5#post14471555 |
#474 (permalink) | ||
Member # 25303
![]() Quote:
Finished pics to come tomorrow or tuesday after all the work is complete.
#475 (permalink) |
Member # 198485
I like the fact you built most of the stuff yourself and still have a Jeep.
The tube buggies are kool but not in the winter. You are definitely getting the welding skills honed on this project! Way to go!!
