#76 (permalink) | |
Member # 198573
Something like Spidr's 509 hybrid axle but with the Hp d44 center section instead of the 9" he used: http://www.pirate4x4.com/forum/showt...1009725&page=3 |
#77 (permalink) | ||
spot me? mydfghgfff!
Member # 25303
![]() Quote:
97 TJ 4.0/np435/d300/3link/4link in progress Ultimate Wrangler Build Ups and Swaps Thread
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! |
#78 (permalink) | |
Member # 198573
On a side note, if you would like to sell the RCV shafts as a complete set PM me with a price, as I was thinking about buying those same axles next month with my Christmas bonus check. |
#79 (permalink) | |
Member # 25303
I'm eventually going to 37 and 40s in the probable future and a hp30 gear set will NOT last forever on krawlers. Big tube 8 lug hp44 would not have to be retubed...and I can't believe you just said put 60 outers on a d30. ![]() edit: 3/4 ton hp44s are 3" OD tubes and all kingpin 60 inner Cs have 3.125 ID...but I have BJ 60 knuckles so I'll have to check on this. Doesn't really matter because if I find a ford HP60 for anything less than $600 I'll probably take it. They pop up from time to time here
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! Last edited by gtxracer; 11-21-2011 at 06:41 PM. |
#80 (permalink) | |
Member # 198573
I realise the ring and pinion wouldn't live long with 40's, but neither will the ball Joints running D30 outers like you mentioned. There are a lot of hybrid axle combos I've seen people build on here, but bigger heavier diffs, with tiny outers and knuckle is not the way I normally see anyone do it, so yeah, an HP D30 with 60 outers makes much more sense to me than an HP D44 with D30 outers and ball joints that barely live with 35" tires while you want to run 37" or 40" tires. Good luck with your build, and I'll make sure not to offer anymore stupid ideas from now on.
#81 (permalink) | |
Member # 25303
The balljoints are living fine, as I said earlier. This is why I said you couldn't read... ![]() "tiny" outers is a pirate-ism. Run what you need, not what sounds cool on the internet. If I'm not blowing balljoints, why would I go through the asspain of changing my lug pattern and buying new wheels? Not only that, I'd be running a 1 ton axle on thirtyfuckinfives when my polished turd runs it fine. So I'd either be spending money on new wheels AND tires now or buying wheels now and then again when I get bigger rubber. Not smart. While I get you're trying to help, it's way out of my means and would be a waste of time that I could spend wheeling. hp44 + 30 outers with RCVs = bulletproof axle with a "weak link" being the balljoints. Wanna know when I see balljoints fail? When guys drive on broken u joints or shafts and the two pieces try to pass each other and it pulls the ball out of the socket. Balljoints are pretty easy to replace, if I get tired of doing them I'll glue on the 1 ton outers. Pretty simple really. Try not to believe all the bullshit here. 1/2 the builds on here are to be cool and hang with the joneses. Harsh reality but it's true. Guys throw all kinds of cash at their rig to make it a KOH car or hardcore trail rig but never even challenged their rig on 1/4 ton axles. I'm not building the shit out of my jeep to stare at it in the garage because it's too fuckin big to take to the trails around here. Build your own and quit yer bitchin at me for doing shit the way i want
#82 (permalink) |
Member # 198573
Sorry, I didn't mean to sound like I was bitching at you. I'll check it out as you build it, I'm interested to see how well it works.
#83 (permalink) | |
![]() then, after youve wheeled the living piss out of it on 35's and want a new challenge, you can go to the 44 w/ 60 outers and 37s. just seems like a big waste of time/money? to me when you could be out wheelin instead of fuckin with it
Joe Fuerst [url]http://insanityfab.com/phpbb/index.php[/url] |
#84 (permalink) | |
Member # 56176
The Build [url]http://www.pirate4x4.com/forum/showthread.php?t=680391[/url] Last edited by Curt's_97; 11-24-2011 at 07:15 AM. |
#85 (permalink) | ||
Member # 25303
![]() Quote:
1.75" would be nice but in order to get the proper CLR you'll need a 4.5 or 5.5. If I can find someone that will let me borrow their die I can try it. Bedliner is worth it to me because of all the crap I throw in the bed and it would be nice to have some grip on the floor too. If the tranny tunnel comes out the way I want it, I shouldn't have to modify it very much in the future. Good eye on the KP60, that's a good deal. I'm away from home unfortunately. Last time there was the same style axle for $600 on one of the local forums and I wasn't there to snatch it All in all, if I find a cheap hp60, I'd take it. Then again, I never intended for this Jeep to be bigger than 37s and a mild wheeler and trail runner. I want a buggy for the crazy shit
#86 (permalink) |
Karnage
Member # 55444
FYI I've seen a bunch of failed D30 outers. Not broken balljoints directly, but mangled inner Cs. They're not nearly braced well enough for the leverage on them. They might live with some decent gussets, but Its not a risk I would personally take.
Rubicon 44s are just a d30 with a bigger ring gear and they seem to hold all right, but I've held in my hands a couple of blown gear sets from them, front and rear from an LJ running 36s. If you put some time into it you could make a decently cheap upgrade, and still keep your bolt pattern, but I think you're honestly wasting your time on the 30....Just my .02
Thanks to BAILEIGH INDUSTRIAL
![]() Krush RT IFS/IRS Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color] https://www.facebook.com/KrushRacing |
#87 (permalink) |
Member # 25303
Thanks for the info spidr. What kind of situations caused the failures?
Rubi 44s are low pinion 44s and I wouldn't waste my time on one. I want a high pinion 44 from a Ford f250 if I were to do this swap. Bracing and gusseting the Cs should make them last a long time. This isn't a comp rig and I have yet to see a grenaded d30 knuckle or inner C. Not gonna throw 1 tons under my rig for 35s and I'm a crawler, not a rock bouncer. I'll be fine but thank you and everyone else for the advice. I'd rather put the big sticks under a buggy with some HP.
#88 (permalink) |
Karnage
Member # 55444
I've seen broken a broken rear gear set as well though, it was a broken pinion. Same rig.
The failures are usually abuse to be fair, but it's not as if they're that uncommon. The upper half of the inner c basically opens up and pulls the balljoints apart. I've seen the same thing out of a d44 once, but it was a very well used rig. On the 30s of seen bent knuckles on rigs running as small as 33s, basically stock drivetrain. Only takes one real good bad bounce and its game over. If I hadn't of gone the route I did I was toying with the idea of a 44 or 9" center chunk, and put Dodge unit bearing ball joint knuckles on it. 35 spline locker and you could run stock 60 inner and a shortened shaft on the other side, no hubs to fail, and they're basically give away axles. Without the hub in the middle you could run a 1" thick spacer adapter and get it down to your bolt pattern even until you stepped up to a bigger diff in the rear. Just thinking out loud of course, but for the money of messing with the 44, why not build something upgradeable. Your RCVs are likely worth almost what it would cost to put it together.(if you're able and willing to put it together of course)
#89 (permalink) |
Member # 25303
I looked into what you said Spidr, but those axles are kinda rare up here it seems and most dodge 60s go for the same or more than super duty 50/60s. I've seen the Dana 50s go for $150-$300 here complete so if/when I see another one I'll pick it up. They can be easily redrilled to 5 on 5.5 or 8 on 6.5. A super 88 kit in my 8.8 would give it a 5 on 5.5 pattern and can handle 37s. I wouldn't mind running a hp44 chunk and the 50/60 outers if I had the time and all the parts.
#90 (permalink) |
If you see an extra 50 go for that cheap, then let me know. While I have a great lead on all the hard parts for a 44/50/60 hybrid, I still might be interested. It just all depends. For that kind of price I wouldn't mind just having one sitting around.
-Brad Last edited by Optiskate; 11-24-2011 at 08:10 PM. |
#91 (permalink) |
Member # 25303
Will do, I'll keep my eye out when I get home.
#92 (permalink) |
Member # 25303
Drew this the other day, it's my gas tank skid I'll be fabbing. I got tired of trying to find one locally and I think it's dumb to spend $200+ on a skid. The base of this is 10g (1/8") and I'll do most of the bends with my 20t press. The other bends will have to be done on my workbench with clamps. Hopefully only 1 or 2 pieces will actually have to be cut and welded. The bottom will have the dimple from my stock skid grafted into it and will also have 16g plate on it to make the total thickness about 3/16". I'll be using 1/4"-1/2" UHMW for the bottom to help it slide over rocks and stumps. Since I have a 1" body lift I'll tuck the tank up 1 to 1 1/2" and it will also have the dimple for the tank mod. I will probably mold the tank in the stock skid first then finish it in this one. All the big holes are dimple dies, I'll use my 1 3/4" die for most of them and the flat strips are 1/8" strips that will give it a little reinforcement.
If you have any questions let me know, the design came out well considering I'm not in front of the skid right now.
#93 (permalink) |
Member # 25303
I'm back, scored a Warn tank skid for 75 bucks so I'm gonna run that instead. It will save me a lot of time instead of fabbing one from scratch.
I also got a anti rock bar and bushings from hurley, just need to fab some arms. Anyone have a good method or some tips on how I should go about this?
#94 (permalink) |
Member # 25303
I got started on the TJ again today. I mainly wanted to finish the crossmember and start on a few smaller side projects I needed if I had time.
First I wanted to know the angle of the frame. For anyone else wondering, it's about 9-10 degrees. ![]() There's a couple different ways to do it but that one helped justify my measurements. I clamped the frame mounts in place then measured between the two outside edges to get the two inner fishmouth distances. If this doesn't make sense let me know and I can explain it further. Then I cut the first side. Came out rough...lost some of my touch while I was away. Second one came out cleaner (pictured) ![]() ![]() It fit pretty well. The gaps aren't perfect but I also don't have a notcher. It still came out good. ![]() Measured more and more and more and more to get a final piece. I'll leave it tacked for now in case I make any changes. ![]() You can see the angle here: ![]() I also experimented with getting the front UCA mount done...but it didn't come out too well. Oh well, good learning I guess! ![]() Need opinions and experience: should I put another bushing on the trans mount to the crossmember? Is it really needed?
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! Last edited by gtxracer; 12-23-2011 at 06:08 PM. |
#95 (permalink) |
Member # 25303
Picked up the Warn skid, previous owner cut out part of it already to clear his diff. Coincidentally it's the same portion I would have cut out anyway. Crappy pic but whatever-
![]() I drew out the UCA mounts for the rear truss ![]() Cut em out then tacked them together. This is a tip I picked up from Pirate ![]() Started grinding them down ![]() Cleaned them up so they're all the same ![]() Then started drilling holes. I used a 9/16" hole saw since I didn't have a bit. Looks like I'll be buying one anyway because it grenaded after the 2nd hole. Completely smoothed out the hole saw ![]() But the first set came out nice
#96 (permalink) |
Member # 25303
I have a fantastic girlfriend
![]() ![]() Today I had some time to start on the "new" skid. I had to take off some material in order to maintain clearance with the diff and then add material for the bump. I really hope I get 4-5" with this mod or I'll have to stretch the front more than I wanted. Oh and I got the plasma working a little better.
#98 (permalink) |
Member # 25303
Thank you for your input. I think I'll run one just in case.
#99 (permalink) | |
Member # 149566
Great job on the build thus far!!!
Pacific North West Jeeper My HEMI, ROCK JOCK, 4-LINK, etc Build:: /forum/jeep-hardcore-tech/850159-1997-tj-2-5-l.html Seattle Fabricators: www.crawlmag.com www.bentmetalcustoms.net www.auburncarrepair.com www.home.comcast.net/~thoseguys/ www.xo-fab.com www.metalhavoc.com Last edited by PacificNWestJeeper; 12-29-2011 at 10:56 AM. |
#100 (permalink) | |
Member # 25303
Yeah she knows the secret about HF: it's all cheap!Picked up some goodies from the local welding and metal supply. Tomorrow I get to continue to work on the jeep. I should have a solid 12 hours tomorrow and saturday to crank out some good shit
