#27 (permalink) |
Member # 204556
I knew it had to be a Canadian Rig. the daytime runners gave it away. That thing looked like it was pristine when you had it. When I got it she was a little beat up. Lots of things need rebuilt. I must say you are quite the fabricator.
If i have any questions about the axles i know who to contact now.
#31 (permalink) | |
Bending light
Member # 24300
#33 (permalink) |
Member # 204556
Well these aren't topless but they should do the Job
![]() Got a few tires mounted lastnight ![]() Actually sitting back on the rear tires again ![]() The Gymnast just got a bit wider! ![]()
#34 (permalink) |
Member # 204556
Well we got the rest if the tires mounted today. Just have to torque down the botls for the beadlocks and they will be all finished. Also started on swapping the OBA but realized that the clutch pulley on the compressor doesnt line up with the rest of the pulleys. I will have to modify the bracket to make it work.
#35 (permalink) |
Member # 204556
I've been trying to make progress on the heep but i've been so busy between school and work. This week seems like its not going to yield much time to work on the Jeep since I have a big project due and work Thursday through Sunday. I have started pulling the front axles pulled out of the Jeeps and I am almost done modifying the OBA clutch to make it work.
Few updated Pictures ![]() Pulled the Dana 44 out of the Gymnast. Found out that the front busings are shot. I should have expected that. It didnt show any signs of bad bushings when driving it around though. ![]() ![]() This is what I am doing to the OBA clutch pully. I cut out the center section, flipped it over and welded it back in. ![]() ![]() ![]()
#36 (permalink) |
Member # 204556
I have been making some progress but I have been swamped with school work because the end of the semester is coming up. I had the truss that I ordered from T&T customs welded on and I had to do a lot of grinding to make it fit bc my axle has been shortened on one side only. I also had to notch out some of where the cast and the axle tube meet in order to get the LCA mount on the driver side to fit. (Pics coming soon).
I now have the axle bolted up under the Jeep but right before I was going to torque everything down and put the front tires back on I noticed that my driver side hub was completely frozen. Im assuming that the heat from cutting off the old brackets and welding on the truss caused this. I went to remove the hub so i removed the first spindle nut, then the locking washer, then the other spindle nut. I then noticed that the last person to put this axle back together put the other washer that was supposed to go between the two spindle nuts, between the back spindle nut and the outer bearing. I now cant get the washer out and I have been trying to remove the hub but it seems it is stuck on there pretty good. I tried a BFH, 10lb sledge, pry bars and heat but nothing has been able to budge the hub. From what I understand the whole unit should slide right off. I was thinking about buying a puller tomorrow but IDK if it will work when the hub is stuck on this bad. Anyone have any suggestions?? Last edited by JeepJake OIIIIIIIO; 04-15-2012 at 09:07 PM. |
#37 (permalink) |
Member # 204556
I finally got the hub off of the spindle with the help of a jaw puller a sledge and a breaker bar. I also got the on board air mounted today. I keep forgeting to take pictures but ill get some in here asap
#38 (permalink) |
Member # 204556
Well The axles are finally under the Jeep and it is driveable *:clap: Now I just have little odds and ends to finish up. I know the build thread kind of stalled so I will try to keep you up to speed. Feel free if you want to ask any questions or want pictures of something specific.
The first problem that I encountered *was that the truss that I ordered from T&T customs did not center on my axle correctly because the axle had been cut down. Regardless I was able to trim the truss enough to make it work. ![]() The second problem was that the mounting point on the axle to the lower control arm for the driver side was on the cast for the axle housing. This problem was solved with a cutoff wheel and a little bit of patients. I was able to cut enough of the cast away to make the lower link fit. ![]() ![]() After I got enough of the cast cut away and the truss welded on I realized that from the heat generated by the welder, the driverside wheel bearing had shrunk and froze up on the spindle. ![]() Now it is road worth but I have to address a few minor issues. First, the coil spring on the driver side is contacting the upper trac bar mount. ![]() Second, because the axle is a high pinion, the driveshaft wants to contact the down-pipe for my exhaust. Third, My front driveshaft needs to be shortened a couple of inches because of the longer pinion on a dana 60 vs. a dana 44. Here are a few pictures of how it stands now ![]() ![]() ![]()
#39 (permalink) |
Member # 34955
I don't think that bearing freezing up had much to do with the heat from welding. That just doesn't make much sense to me given it's location.
If you had the ground on the knuckle and were welding on the center section you could have had some arching going on in the bearing causing it to freeze. As far as removing it I imagine it's age was the issue there. Maybe you were welding near brake lines and the expansion of the brake fluid made the brakes apply and made you think the hub was stuck and wouldnt rotate. I doubt that though because you probably let everything cool and had to remove the brakes before taking the hub off. I'm really stretching for ideas here. I think it is more than likely just an old warn out bearing that was near death before you started. Yes, I was dissapointed there was no gymnast. |
#40 (permalink) |
Member # 204556
It wasnt the caliper for sure. That was my initial thought so i took the caliper off and it was still frozen. Before the old brackets were taken off and the truss was welded on the bearing acted fine. So im assuming it was from the heat.
#44 (permalink) |
Member # 204556
So I got to test out my new setup at Jeep Beach 2012 in Daytona Beach FL. Here are a few pictures. I didn't get many pictures of me wheeling it in the speedway but oh well.
Of course we had to stop at the auto parts store half way to Jeep Beach. ![]() ![]() The event ![]() ![]() ![]() ![]() ![]() ![]()
#45 (permalink) |
Member # 204556
How my Jeep Beach ended on the way home:
I was flat towing the Jeep with the transfer case and transmission in neutral when my cardigan Joint on my front driveshaft locked up and my NP231 split into two pieces. I learned my lesson, Always disconnect the front shaft when making a trip down the highway or just invest in lockout hubs. Oh well time for an atlas now ![]() ![]() ![]()
#49 (permalink) | |
Member # 204556
I am a major fan of the Rockkrawler lift. I wouldnt build a Jeep with any other product unless I custom built it myself. I've had the lift for almost 4 years now and the only thing that I had to do was replace the bushings. The bushings are the only drawback for me but I think most of their new stuff has the Krawler joints on both ends (basically Johnny Joints) and double adjustable arms. Either way my lift still performs good on the highway and offroad. I ended up getting a 1505 on the RTI ramp with my 35's which is super impressive for not running coilovers or air shocks. |
