Rough Country Long Arm kit on MJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-04-2012, 05:22 PM   #1 (permalink)
Member # 142399
I have an 88 Jeep Comanche that I'm trying to put a Rough Country Long Arm kit on. It has the Peosough (spelling) transmission. The RC crossmember does not line up with the rear mount. I called RC and no help. It seems to be about 4 inches shorter than the other trannys. I might try and make a new rear mount and trim the crossmember to fit around the transfer case (231)/trans. I have a few questions.
1. Has anybody installed an RC long arm on a comanche. Did it fit?
2, There are 2 sets of mounting holes in the frame. One set for the peosough and another set for the AX15?? which is about 4 inches longer I think. If I replace the trans and trans case what would be the unit I would need.?
3. I guess I would need a longer front drive shaft and shorter rear shaft?
4. Dose the shifter and TC lever fit in the same holes?
A lot of things are the same between an XJ and MJ but a lot of frame difference. So before I hack off the LCA brackets I need to know if its going to work.
Any help or questions are appreciated.
Mike
desertmike345 is offline   Reply With Quote
Old 01-04-2012, 08:54 PM   #2 (permalink)
heavychevy335's Avatar
Member # 152539
sell it and get the rubicon express long arm kit. i just installed one on an MJ two weeks ago, it worked with only slight modification. turned out nice
84 chevy k10 355/SM465/NP205 8" lift, 38.5's (Heavy Chevy)
99 XJ, 4.5" rubi express, 31's (DD)
heavychevy335 is offline   Reply With Quote
Old 04-03-2012, 11:34 AM   #3 (permalink)
FLY WHEEL's Avatar
Member # 168942
Rc long arm
R c long arm kit doesnt work with the pougeo !
You need a x 15 trans or automatic
89 YJ SOA. 302 V8 T-18 60/60 39.5 TSL`s
FLY WHEEL is offline   Reply With Quote
Old 04-04-2012, 03:18 PM   #4 (permalink)
Member # 142399
Thanks for the info. I found out the hard way. I made a rear mount that would work but about the time I was welding it up the POS internal slave started going out again. So not wanting to spend the extra $ and time to repair I found an AX15 and 231 with the correct shaft. Just collecting a few more parts and it should be good to go.
Mike
