Member # 121033
TJ stock locker compressor??
I picked up some rubi axles but the compressor that came with them was busted up and not usable. what did you guys rig up to make the lockers work or where can I find a small cheap compressor to use. thanks in advance
89 YJ but not really back halved!?!350 5.7L 4L60E D60 14B(shaved)5.13 39" BFG Baja projects atlas 4spV2 ADS coilovers and fox bumps at the corners! BOMTEC Racing 4476 jimmy's 4x4 support team ![]() Torchmate2x4 cutting your stuff for dirt cheap!PM for quotes! |
Member # 121033
yep and thats why i'm asking what you all did since its a PITA to try and find a used air comressor set up
Member # 121033
only people from dayton do shit like that
#8 (permalink) | |
Here's Johnny!
Member # 12867
I bought mine from the dealer. Cheaper by the time you factored in another air source and a quality regulator that could get down to the 5 PSI range. That was the difficulty and I dont recall having found one I would trust not to blow the seals or whatever out.
You can also find them used for even cheaper if you look around.
Member # 121033
some JB weld and some 3way barbed fittings ad it's fixed. thanks for the valid inputs and the shananigan comments
![]() freakin daytonians to much tire melting fumes in the brain cells for those guys
Member # 121033
nope ARB running off of a CO2 tank in the rear and the stock locker in the front on one compressor for now.
#14 (permalink) | ||
Here's Johnny!
Member # 12867
Thats why I was asking. I know it can be done just didnt see the purpose.
#15 (permalink) |
Member # 165202
Lol well it does and it doesn't. I've needed both lockers to get out of situations several times. So i'd rather have both then one. But yes i'd rather have both on separate pumps anyday. Just haven't got around to finding another pump.
