another hp44 build thread - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-28-2012, 08:25 PM   #51 (permalink)
mylilyj's Avatar
Member # 152850
Size:  30.1 KB chad and Shane from green country said they have had good luck with these gears. Alledgedly made in same facility as Yukon but I can't confirm that. But for a little over $500 for front and rear with install kits that are timken bearings I had no problem giving up my card info over the phone. Really excited to see what she does with 4.56 and the 5.2L v8 on 35s. Should put me in my seat a bit deeper than the 3.73 I previously ran.
sent from the darkside of the moon
mylilyj is offline   Reply With Quote
Old 03-28-2012, 08:26 PM   #52 (permalink)
GZ
GZ's Avatar
Member # 176008
Originally Posted by mylilyj View Post
Ford f150 hubs . 5x5.5 bp. These with the f150 rotors set my bolt pattern. Attachment 662016
Did you buy new? If so do you have a number. I am/did convert to 1/2 stuff on my 44 and only need these now.
03' Z & 2 Zuks.
GZ is offline   Reply With Quote
Old 03-28-2012, 08:41 PM   #53 (permalink)
mylilyj's Avatar
Member # 152850
I will add in that post with picture. Oreilleys number is 4943rgs
Old 03-31-2012, 10:25 AM   #54 (permalink)
mylilyj's Avatar
Member # 152850
Size:  38.7 KBinstalled AussieName:  uploadfromtaptalk1333214707058.jpg
Size:  42.5 KBinstalled ring gear
Old 03-31-2012, 10:46 PM   #55 (permalink)
mylilyj's Avatar
Member # 152850
I ordered these from complete off road.Name:  uploadfromtaptalk1333259007765.jpg
Size:  31.8 KBI mangled one trying to make fit. The next day I picked these up from car quest.Name:  uploadfromtaptalk1333259072851.jpg
Size:  56.1 KBnotice the difference. Worked great.Name:  uploadfromtaptalk1333259155641.jpg
Old 03-31-2012, 10:47 PM   #56 (permalink)
mylilyj's Avatar
Member # 152850
Erock and Ronhob stopped by. Got the gears in.Name:  uploadfromtaptalk1333259240199.jpg
Old 04-03-2012, 04:15 AM   #57 (permalink)
mylilyj's Avatar
Member # 152850
Sunday was a wash due to fam stuff and I had a few Monday after work so I got started on ball joints. I punched in spindle studs.Name:  uploadfromtaptalk1333451312893.jpg
Size:  36.5 KB I then used my ball joint press to install the upper. I cleaned the top surface of knuckle so it would seat cleanly. But I got this.Name:  uploadfromtaptalk1333451452801.jpg
I pounded my head off the wall trying to figure out why I couldn't get the c clip in. All my friends assumed I did something wrong. But after conferring with my military jeepers brothers it turns out there is no c clip for the upper ball joints. Just the lower ones. They put c clip in the package because other applications use it.
Old 04-04-2012, 02:54 PM   #58 (permalink)
Necromancer_tat's Avatar
Member # 198573
Nice thread so far!
When someone tells you that nothing is impossible, ask them to dribble a football!
Necromancer_tat is offline   Reply With Quote
Old 04-07-2012, 01:16 PM   #59 (permalink)
mylilyj's Avatar
Member # 152850
Some call them spring clamps. I call them u bolt eliminaters. Whichever,green country offroad makes these beefy. Fabbed from 1/2 inch plate with bolts thicker than the average ubolt. The axle is bolted in place.Name:  uploadfromtaptalk1333829767078.jpg
Size:  45.4 KBName:  uploadfromtaptalk1333829795342.jpg
Old 04-07-2012, 01:17 PM   #60 (permalink)
mylilyj's Avatar
Member # 152850
I also purchased a set for the 8.8 in back
Old 04-08-2012, 01:20 PM   #61 (permalink)
mylilyj's Avatar
Member # 152850
Now with the knuckles inside I am going to attept to assemble my axles with the yukon super joints. I watched this link but somehow not sure it will go as well as jesus does it.
Installation of Yukon Super Joints - YouTube
Old 04-08-2012, 07:39 PM   #62 (permalink)
mylilyj's Avatar
Member # 152850
I have to say..the joints wernt so bad. And video very helpfull. I used sockets and hammer rather then vice. Key is to make sure clips are seated. This is wrongName:  uploadfromtaptalk1333939110286.jpg
Size:  36.2 KBthis is rightName:  uploadfromtaptalk1333939159399.jpg
Old 04-08-2012, 07:47 PM   #63 (permalink)
mylilyj's Avatar
Member # 152850
Size:  43.9 KBNow next is bolt zerk fitting in,grease and done. Wrong the assembley won't fit through knuckle with zerks attached. Also note the upper ball joint zerk has to goName:  uploadfromtaptalk1333939615076.jpg
Old 04-09-2012, 04:06 AM   #64 (permalink)
mylilyj's Avatar
Member # 152850
started trying to figure how the caliper brackets are going to bolt in.
Size:  40.6 KBName:  uploadfromtaptalk1333969550145.jpg
Old 04-09-2012, 04:09 AM   #65 (permalink)
mylilyj's Avatar
Member # 152850
I decided to call it a night as I want to make sure I get the bearings and seals correct.
This is the oriellys bearing kit for the inner spindle that tides on the outer axle.Name:  uploadfromtaptalk1333969776383.jpg
Size:  34.0 KBit has the bearing with long needle looking bearings large seal and small seal.
Old 04-09-2012, 08:36 PM   #66 (permalink)
mylilyj's Avatar
Member # 152850
My guy erock fired up the new Lincoln 180.Name:  uploadfromtaptalk1334028646225.jpg
Last year in prep of this swap I picked stock cj Rims for $80. Then made a call to the pirate vendor DIY beadlock.com. here is a shot of them after welding.Name:  uploadfromtaptalk1334028848345.jpg
Size:  44.9 KB I ground to bare clean metal and he used wire brush in between passes to make sure its good.Name:  uploadfromtaptalk1334028999446.jpg
Old 04-14-2012, 11:37 AM   #67 (permalink)
mylilyj's Avatar
Member # 152850
Relocated valve stemName:  uploadfromtaptalk1334428633457.jpg
Old 04-15-2012, 08:57 PM   #68 (permalink)
mylilyj's Avatar
Member # 152850
I have to say thanks to erock33 for showing me how to do the next step. I also have to say thanks to Chris palsmeier from whynotcustoms.com for answering his phone and answering a few questions.
Old 04-15-2012, 09:04 PM   #69 (permalink)
mylilyj's Avatar
Member # 152850
Size:  44.2 KBthere are some tin dust type things that go on the axle,then the large rubber seal and washer.Name:  uploadfromtaptalk1334548853833.jpg
Then the small needle type bearings get tapped down into into the inner area of spindle.Name:  uploadfromtaptalk1334548999964.jpg
Size:  50.8 KBthen the small rubber seal on top and then its ready to bolt on. I used some antisieze between the spindle and knuckle.
Old 04-15-2012, 09:16 PM   #70 (permalink)
mylilyj's Avatar
Member # 152850
Ford spindle and caliper bracketName:  uploadfromtaptalk1334549572029.jpg
Size:  47.0 KBnotice the caliper bracket goes first then the spindle. The Chevy spindle goes on first with the caliper bracket second towards the out side.Name:  uploadfromtaptalk1334549753130.jpg
Old 04-15-2012, 09:33 PM   #71 (permalink)
mylilyj's Avatar
Member # 152850
Next will be to assemble the rotor(6048rgs),hub(4943rgs) with the wheel studs(610-219). Those are orielleys numbers.
Old 04-15-2012, 09:52 PM   #72 (permalink)
mylilyj's Avatar
Member # 152850
Upon initial set up it seemed the hub was getting Hung up on something before it was fully seated. It seemed the spindle bolts were hitting the hub.Name:  uploadfromtaptalk1334551621990.jpg
I inspected the Ford spindle studs and it seemed they were a little over 1/4 shorter then the Chevy ones I used. So once they were torqued in place. We cut enough out that it will clear.Name:  uploadfromtaptalk1334551920679.jpg
Old 04-17-2012, 04:23 AM   #73 (permalink)
mylilyj's Avatar
Member # 152850
Outer bearing Name:  uploadfromtaptalk1334661614536.jpg
Size:  25.3 KB inner sealName:  uploadfromtaptalk1334661678289.jpg
Size:  23.4 KBthe inner bearing is a37. I reused an old inner bc I forgot it and had a couple laying around.
Old 04-17-2012, 04:26 AM   #74 (permalink)
mylilyj's Avatar
Member # 152850
Nifty tool . Pushes old grease out while packing in the new with one pushName:  uploadfromtaptalk1334661868366.jpg
For those intereasted http://m.oreillyauto.com/mt/www.oreillyauto.com/site/c/detail/LIS0/34550/N0726.oap?ck=Search_bearing+packer_-1_3373&keyword=bearing+packer
Old 04-17-2012, 04:28 AM   #75 (permalink)
mylilyj's Avatar
Member # 152850
Inner bearing packed and seal in place Name:  uploadfromtaptalk1334662019123.jpg
