another hp44 build thread - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-29-2012, 07:45 PM   #101 (permalink)
mylilyj's Avatar
Member # 152850
Orielleys break pads
sent from the darkside of the moon
mylilyj is offline   Reply With Quote
Old 04-29-2012, 07:51 PM   #102 (permalink)
mylilyj's Avatar
Member # 152850
Shots with with tires finaly mounted up fronName:  uploadfromtaptalk1335754217184.jpg
Size:  44.2 KBName:  uploadfromtaptalk1335754276158.jpg
Old 04-29-2012, 08:03 PM   #103 (permalink)
mylilyj's Avatar
Member # 152850
Got the 8.8 out from under her and up on the benchName:  uploadfromtaptalk1335754992329.jpg
Old 05-04-2012, 12:41 PM   #104 (permalink)
mylilyj's Avatar
Member # 152850
Busy week for real world crap. But I managed to find a rim for spare and got the blaster on it. Getting frustrated need get this jeep back on the street pronto.
Old 05-05-2012, 11:14 AM   #105 (permalink)
mylilyj's Avatar
Member # 152850
Sent from my PC36100 using Tapatalk 2
Old 05-05-2012, 11:24 AM   #106 (permalink)
mylilyj's Avatar
Member # 152850
Old 05-05-2012, 02:30 PM   #107 (permalink)
mylilyj's Avatar
Member # 152850
Took some measurementsName:  uploadfromtaptalk1336253382899.jpg
Size:  33.2 KBName:  uploadfromtaptalk1336253403087.jpg
Got to grindingName:  uploadfromtaptalk1336253442095.jpg
Old 05-05-2012, 02:33 PM   #108 (permalink)
mylilyj's Avatar
Member # 152850
The 220 welder is off site. So I measured my pinion angle so we can set spring clamps at same angle where the 220 welder is. And I can be prepped and ready to burn. Save time too.
Old 05-06-2012, 07:59 PM   #109 (permalink)
mylilyj's Avatar
Member # 152850
Erock33 maning the licoln 180Name:  uploadfromtaptalk1336359473719.jpg
Size:  47.0 KBand Name:  uploadfromtaptalk1336359473719.jpg
sent from darkside of the moon
Old 05-07-2012, 04:25 AM   #110 (permalink)
mylilyj's Avatar
Member # 152850
Spring plates on the 8.8Name:  uploadfromtaptalk1336389940194.jpg
Old 05-07-2012, 04:28 AM   #111 (permalink)
mylilyj's Avatar
Member # 152850
Tie rod endsName:  uploadfromtaptalk1336389996733.jpg
Size:  34.1 KBName:  uploadfromtaptalk1336390028884.jpg
Size:  34.1 KBName:  uploadfromtaptalk1336390064952.jpg
Size:  33.5 KBName:  uploadfromtaptalk1336390100490.jpg
Old 05-07-2012, 08:27 AM   #112 (permalink)
mylilyj's Avatar
Member # 152850
With this tool I will be reaming one tre and the pitman arm to accept the Chevy tie rod ends.Name:  uploadfromtaptalk1336404437633.jpg
Old 05-08-2012, 07:50 AM   #113 (permalink)
KennyTJ's Avatar
Member # 100284
Looks like you realy limited your turning radious with those big tires by narrowing that axle???
Do the tires rub the springs? or does it clear at full bump?
Silver '06 'X'
"The Pirate Boat!"
KennyTJ is offline   Reply With Quote
Old 05-08-2012, 10:10 AM   #114 (permalink)
mylilyj's Avatar
Member # 152850
As of now this build thread is in real time. I am in process of figuring my steering and getting gears in the 8.8 in back. Once it is on the street I will be able to answer your rubbing concerns. As stated in the first post, I am not ever going past 35 inch tires with this rig. I ruled out full width options because it sees the street quite a bit. Besides 75% of my wheeling takes place at Cliffs Insane Terrain. Where the trails can get quite tight between trees. If I do get some limit of turning radius in there somewhere. I will chalk it up as saving ujoints...lol.
Old 05-09-2012, 04:19 AM   #115 (permalink)
mylilyj's Avatar
Member # 152850
So I started looking into how long to drill my pitman arm. I have a flat blank from parts mike. I was advised my pitman arm should be the same length as ball joint to tre. This is what I ended up with. Name:  uploadfromtaptalk1336562283118.jpg
My pitman arm didn't quite seem long enough.Name:  uploadfromtaptalk1336562340362.jpg
Old 05-09-2012, 04:24 AM   #116 (permalink)
mylilyj's Avatar
Member # 152850
I asked some questions. I did some searching. After reading up on Ackermans angles and hearing of people using longer or shorter pitman arms from various vehicles for different reasons I was frustrated and confused. Being this late in the build I chose to drill about 6.75 center hole to center hole.Name:  uploadfromtaptalk1336562683610.jpg
Old 05-09-2012, 04:29 AM   #117 (permalink)
mylilyj's Avatar
Member # 152850
As I said before I am not a mechanic. It shows here as I wasn't perfectly straight with the reamer.
Old 05-09-2012, 04:33 AM   #118 (permalink)
mylilyj's Avatar
Member # 152850
The initial thing I noticed is the nut on the tre would not sit flush on the tre. I wasn't comfortable with this. So I took the grinding wheel and ground the bottom of the pitman arm just a bit so when the tre nut is torqued down it sits flush against the arm.
Old 05-11-2012, 05:31 PM   #119 (permalink)
mylilyj's Avatar
Member # 152850
Going to have to wait till rear end is together to do some flex testing. But I have a feeling this is going to be a close call. May have to loose my stretch till I can move box forward a bit.Name:  uploadfromtaptalk1336782698831.jpg
Old 05-13-2012, 04:33 AM   #120 (permalink)
mylilyj's Avatar
Member # 152850
Got the gears and axles in the 8.8. I need to weld some tabs on for soft lines. Run new hardlines on the axle and its ready to go back under the jeep. Name:  uploadfromtaptalk1336908786813.jpg
Old 05-17-2012, 03:29 AM   #121 (permalink)
mylilyj's Avatar
Member # 152850
New hard lines on 8.8. Bleed system. Bolted up bolt pattern adapter in rear and tires. All that's left is diff fluid and steering to be streetable
Old 05-17-2012, 03:30 AM   #122 (permalink)
mylilyj's Avatar
Member # 152850
Old 05-19-2012, 01:40 PM   #123 (permalink)
mylilyj's Avatar
Member # 152850
Well I can't find a way to jack up to full compession in my garage. So I am going to finish steering so I can drive up something like a fiero to check for binding. I reamed the tre to accept tre.Name:  uploadfromtaptalk1337460013964.jpg
Old 05-19-2012, 05:11 PM   #124 (permalink)
mylilyj's Avatar
Member # 152850
1.5 inch dom that's .25 thick. Cut down and in place. I am waiting for a welder to free up some time. Here's how she is mocked up.Name:  uploadfromtaptalk1337472645318.jpg
Size:  46.2 KBName:  uploadfromtaptalk1337472689187.jpg
Size:  34.7 KBName:  uploadfromtaptalk1337472710920.jpg
Old 05-20-2012, 05:15 PM   #125 (permalink)
mylilyj's Avatar
Member # 152850
Thanks to overkill for taking time out to weld my steering together.Name:  uploadfromtaptalk1337559219471.jpg
Finally out of garage under own power. Name:  uploadfromtaptalk1337559259085.jpg
Size:  51.3 KB I need to figure out the vent on the 44. Weld shock tabs on the 44 and shorten the front driveshaft.
