Avalon Crawler
Member # 15221
2.5L to Auto Tranny
Has anybody adapted 4.0L auto or GM auto to a 4cyl jeep motor? I hate the manual for crawling. I haven't been able to find any info on such a swap.
I have a 99 TJ with 60/14b, 5.13's in it, 38.5 SX's, D300 with 4:1's in it. I done it all myself and I am not opposed to having to regear again to run the auto as I can set-up my own gears. I have a rear 60 I can swap in to replace the 14b. Any one done it or have any info on what needs to be done to do it?
TJ on Tons... |
Member # 191442
Some early '90s 2.5l XJ's came with the AW-4 as the auto transmission, 2wd and 4wd. The bellhousing from one of these will fit an AW-4 from a 4.0l. The TCM is different, too, gave a couple hundred RPMs higher shift point spread.
Newbie
Member # 158798
Agreed, your gear and tire combo would run at around 2900rpm at 65mph, I don't think a 2.5 could pull less rpm at that speed. The 32RH has a locking converter and a 2.74 first gear ratio, it is a good little trans and is much shorter overall than any Chevy you might adapt.
#5 (permalink) | |
Avalon Crawler
Member # 15221
What else would I need? Would I need to change out the ECU to accomodate the auto? Tranny's are like voodoo to me
TJ on Tons... |
Member # 3511
Trans, trans cooler, shifter, ecu - might need to change the input shaft on your tcase. Driveshaft lengths will change.
Chuck P The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in! www.oldjeep.com |
