Member # 70686
need transfer case for TJ will an XJ TC fit?
Ive got a 2000 TJ 5 speed 4.0, The TC is shot and im not finding any from a TJ
There are ALOT in the yards around here from XJ's but no TJ's.. All the XJ's are automatic....? Any help would be great. |
Banned
Member # 189895
It will be a lot of work switching from a manual to an auto. I just did it on my YJ, that was going from an AX15 to an AW5. I didn't use the computer, so that made it easier. I'm not sure if it would be the exact same or not. There is a post on here about the swap, not from to long ago either. To do what I did you'll need the AW5, shift cables, TV cable, flex plate, ring for the flex plate, bolts for it, shifter, and you'll have to clock your t-case.
http://www.pirate4x4.com/forum/showt...887&highlight= |
#4 (permalink) | |
Member # 68171
Edit: OP, I missed your responce. What's wrong with your T/C?...
Knuckelhead Last edited by Knuckelhead; 05-04-2012 at 06:16 PM. |
Member # 92402
The tcase from an xj is clocked differently then a tcase in a tj/yj. What is wrong with your tcase? They are very easy to rebuild with just basic tools. May be easier to just rebuild yours.
Chris
Tellico online rally post #690. 04'Rubi,tons,leafs,38's/99'TJ,stock |
Mostly Harmless
Member # 200161
Unless the main casing is damaged it's easier to rebuild yours, all internal parts are available at good prices from lots of sources, start at Morris4x4.com to compile a list of what you need then shop around, to give you an idea of how much you save shopping around, an Alloy USA tc chain is usually $110, I got mine, same brand & part number for $53, it pays to do the research
99 TJ Last edited by O_M_Jeep; 05-04-2012 at 10:49 PM. |
