Head light switch makes gauges go crazzy yj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-10-2012, 01:36 PM   #1 (permalink)
Member # 74368
1990 yj
My gauges go crazy when I turn on my head lights. Both my head light and dimmer switches have been taken apart and cleaned repacked with D grease.
I have been able to track it down to the middle contact in my head light switch that feed the dimmer switch. In the Manuel it labels as 72 18BL/RD. It goes to the dimmer switch as 90 18/pk/or and then turns into 52 180or/bk. I have traced it to the Gauge package circuit board connector. And cut it. The gauges still go crazy when I turn the head light on.
I then was wondering if power is back feeding from the dome circuit. I pulled the fuse. It reduces the amount of action on the gauges. But still screws them up.
I was going to try cutting the common ground 99 18BK? Wondering if power is back feeding in.
I have a feeling the issue has something to do with the dome circut. And my wipers dont work any more?
HAS ANYONE HAD A SIMMILAR PROBLEM? ANY SUGESTIONS?
Kole
1990 yj RENAGADE
5.7 TBI, SM465 NP241C wJB SYE
HP Dana60 front D60 Rear w5.38 locked and loaded
39.5 IROKS on 17 bling bling
project_mud is offline   Reply With Quote
Old 05-10-2012, 02:04 PM   #2 (permalink)
Banned
Member # 189895
I had it happen to me. I wired a KC Light toggle switch to it. Mine would go crazy when I would turn the dimmer to get the interior lights to come on. Now I turn the dimmer and flip the toggle, no more problems.
mwstudt is offline   Reply With Quote
Old 05-10-2012, 02:39 PM   #3 (permalink)
Member # 74368
what wires did you splice together?
1990 yj RENAGADE
Old 05-11-2012, 06:52 AM   #4 (permalink)
Banned
Member # 189895
I can look when I get home tonight. I figured it out by following one of the wires.
Old 05-11-2012, 11:33 AM   #5 (permalink)
Member # 17632
I'd like to know the fix since mine does it as well. I found with mine that if you turn the rheostat all the way down so the gauge lights go out the gauges read normal (though you can't see them ).
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 05-11-2012, 12:50 PM   #6 (permalink)
Banned
Member # 189895
When I get home tonight I'll let you guys know.
Old 05-11-2012, 02:40 PM   #7 (permalink)
92lilredyj's Avatar
Member # 91803
My dimmer makes my headlights go out when it gets hot... it sucks and scary when you are in town, or on a dark back road, going 50mph. I replaced the headlight/dimmer switch and it went away.
'92 YJ, 4inch springs, 36's H1 recentered, d30/8.8 4.10's locked. much much more.
92lilredyj is offline   Reply With Quote
