Member # 86167
High-Steer Help
I need help deciding what steering solution should be purchased for a daily driven 2001 Wrangler with a D30 front axle. I just purchased the rig and it currently has an upgraded tie-rod, drag link and Rusty's track bar. I have considered the Teraflex high steer knuckles, however, I imagine there are other effective set-ups available. Being that I haven't owned a TJ in 5 years and my last rig was not daily driven, I am unaware of the solutions available and appreciate the help. Below are photos of the current set-up. Thanks in advance.
Member # 145202
someone please explain to me how that works when the suspension flexes out? the lower heim is already on the edge of the misalignment spacers.
anyhow, since the knuckle is already drilled for that applications that means a stock or stock replacement system is out of the window. There are several routes to take. 1)replace knuckles and go with a stock replacement (Currie gets high regards) 2)ream the knuckles to accept 1-ton tie rod ends and run an inverted T system (controversy about running inverted T on Jeeps) 3)Reid knuckles. requires switching to standard lock out style hubs 4)WJ knuckle swap just a few options off the top of my head.
[QUOTE=CJesse7;13952680]we should have just picked our own damn cotton.:([/QUOTE] |
Member # 124275
JESUS, your current setup is a mess.
Either swap to a beefed up inverted Y (Currie) or do a WJ or Reid knuckle swap with a crossover setup. Two best options. If you want cost effective, a new pair of knuckles and Currie steering (and a non-sucky track bar) will do you well. The WJ/Reid setup can be made to work very well but will cost quite a bit more and require some changes.
"Don't fuck with my dog" -heavytlc |
#4 (permalink) | |
Member # 145202
Member # 124275
Sure, as long as he sticks to using rod ends. But unless he enjoys sucky steering, it's not a good option.
"Don't fuck with my dog" -heavytlc Last edited by imped4now; 05-13-2012 at 06:43 PM. |
Member # 86167
I agree, the current set-up is complete garbage. What the previous owner was thinking is completely beyond me. What do you guys think of the Teraflex knuckles and keeping the current tie rod and drag link? I do like the WJ idea if I can get ahold of the parts at a junk yard. Thanks for the advice.
Member # 124275
The Tera knuckles are basically WJ knuckles that will bolt up. You'll still have to fab up the links and will have to come up with a good track bar solution. I'd highly recommend checking out some WJ swaps that have been done right.
Here's an old thread that may help you but will definitely teach you a few things: http://www.jeepforum.com/forum/f9/wj...brakes-560997/ Don't miss page 4.
"Don't fuck with my dog" -heavytlc Last edited by imped4now; 05-14-2012 at 06:05 AM. |
#9 (permalink) | |
Member # 198573
When someone tells you that nothing is impossible, ask them to dribble a football! |
Member # 86167
Last set of questions before I decide between either the Currie system or the WJ swap:
Thanks again for the help. |
#14 (permalink) | |
Banned
Member # 189895
Lets start with the axle and work out. If you go with the WJ swap you'll have to replace the lower ball joints. They are a different taper then you current ones, the top ones are fine. Next you'll have to get 1/4" spacers for the knuckles. The knuckles are a little shallower, and without the spacer would leave you with a 1/4" gap between the knuckle and wheel hub. Your current wheel hubs/bearings will work fine, no need to replace them. You'll have to get new rotors, WJ rotors will have to be drilled to fit since the lug pattern doesn't match. You can also get rotors Ford Explrer Sport Trac rotors, these do not have to be drilled. Are you can get rotors from here, they are already drilled. If you are going to do the swap, try to find calipers from 2002+, the years prior are known to cause warping of the rotors. I used parts from a 2000 since my jeep is not a DD and I wouldn't notice the warping. This is a great set-up on a TJ, it gets you tierod up, and allows you to connect your draglink directly to the knuckle. You can drill the knuckles to use heims, or you can put in inserts to flip it and use rodends. Last edited by mwstudt; 05-15-2012 at 06:05 AM. |
#15 (permalink) |
Member # 124275
Of course it was.....you didn't have to deal with a track bar.
![]() And FYI, doing that swap won't raise the tie rod up unless you place it on the top side of the knuckle....then you have to place the drag link on the top side of the arm.....then you have to build a track bar and the mounts to match.....then...... The link I posted earlier describes the work involved on a TJ (or any linked 30) to get it right. The entire reason for the Vanco brake kit is the WJ swap's difficulty. OP, if you want to fix your steering then go get some junkyard XJ knuckles, flip the tie rod on top of the driver's side knuckle, and replace the track bar with something better. If you want it to end up well with no worries on your part, you can't do it for cheap. You'll either spend some money and have it done in a couple hours or spend more money and have it done in a couple days to a couple weeks (WJ), all depending on how proficient you are and how correct you want it to be. If you want nice steering for cheap, go pull the tie rod and drag link off the nicest V8 ZJ you can find in the same junkyard and run it....or order up Currie. It's that simple. You've got two options if you want good steering--inverted Y or crossover. Inverted Y, aka stock, has no real-world disadvantages, provides nice feedback, and has no play. If you go that route, you have two options--ZJ or Currie. That's it. If you want to go crossover, you can go with Reid or WJ knuckles. You'll spend more time and money on that route and the only gain you'll see is the ability to use larger calipers and rotors. Currie drag link, heat treated chromolly tie rod flipped on the driver's side knuckle, Currie track bar, stock pitman arm--perfect steering.
"Don't fuck with my dog" -heavytlc Last edited by imped4now; 05-15-2012 at 07:26 AM. |
#16 (permalink) | ||
Banned
Member # 189895
Exactly what I said! Flip it, OTT, cross-over, whatever you want to call it. Still don't see the need to pay $700 for a kit. If you know what your looking for, you can get the correct WJ stuff for a $150. |
#17 (permalink) | |
Member # 124275
And you're saying that I can get quality WJ TRE's (not Duralast, MP, or Moog) and build proper links for $150? I have yet to see a WJ setup done well on a dime budget. It can be done to drive down the road, but not to the standard that I'll personally accept. And I'm pretty sure you've got leaf springs. Setting it up for a coil spring suspension introduces more costs and much more time.
#18 (permalink) | |
Banned
Member # 189895
#19 (permalink) |
Member # 86167
What if I relocated the tie rod back to the bottom of the knuckle and placed the drag link on top? I know it would require the sway bar mount to be relocated but it might prove to be an effective solution.
#20 (permalink) |
Banned
Member # 189895
If you're looking for a quick, easy, temp fix. That would be the way to go! Don't get me wrong, you'll still need to do something about it sooner than later. Your sway bar mounts should still be fine. But the passenger side might hit a little.
#21 (permalink) | |
Member # 40238
So the best option would be new (well, UN DRILLED) knuckles, flip the tierod on the drivers side knuckle, new track bar and the Currie system? Oh and a STOCK pitman arm? Where is the best priced Currie system? and what do you guys think of the SAVVY tierod? http://shop.savvyoffroad.com/product...4&categoryId=7 Since he needs knuckles anyways, why not find a HP30?
#22 (permalink) | |
Banned
Member # 189895
#23 (permalink) | |
Member # 68171
I've done the WJ conversion and am very happy with it. After doing your research, come back here and start asking more questions...
Knuckelhead |
