chevota
Member # 117977
Can a D35 survive a trip to the rubicon ?
Sorry for the newbie question, Im a toyota guy. Ive read a lot about the D35 being crap. I have an older handicap friend that really wants to drive the rubicon . He has a 97 tj auto 3" lift 32 tires NO lockers. Ive been looking in to the ford 8.8 swap for him but to do it right with brackets, locker, brake lines and everything would be just under a $1000. I dont think he wants to get in to rock crawling so spending a grand just to do the rubicon one time is a little steep. " But it would be worth it to me if i had to tow him out" LOL. Would it make it if he drove smooth? Or not worth the gamble ?
Thanks james |
Newbie
Member # 179197
Should be fine as long as he stays out of the skinny pedal.
2003 ford F-350 srw ex cab long bed 4x4 7.3L 98 TJ with some stuff 2012 KOH Modified 4555 Get your Atlas support rings here www.roarkfabrication.com or call 606-286-0681 |
If you drive smart, then you can minimize breakage. Don't bounce on it, bind it up, senselessly beat the shit out of it. I drove with my D35 on heavy ass 35"x13.5" toyo's and a locker and only broke it twice. The first time I bounced backward down a hill and landed on a rock at full throttle and the second time I was cresting a hill at full throttle and let the rear end bounce a few times. The first time was an axle shaft the second time was the yoke. If hes driving smart, I bet he could even get away with lockers. You just have to pay a bit more attention and take into consideration that you do have the lockers. Its really not too big of a deal, just a bit of a learning experience.
-Brad |
Member # 118798
Location: 340 miles from the 'Con, but only 80 from Dusy
I did the Rubicon the first time in a bone stock TJ 4 banger. Open open, on 28's. 7 years ago I did upgrade the D35 to a super (hush. I was young and stupid.) and still haven't broken it. (I've broken just about everything else, not the rear). Just stay off the skinny pedal and pick your lines carefully.
All you need is duct tape and a big effin hammer.... [QUOTE='89 pos;11800277] white nationalist websites are my source. I don't do any real thinking on my own. [/QUOTE] [QUOTE=SkooledMedic;14815094] Yes I was being a fuckstick[/QUOTE] |
Member # 103689
4 squirrels will help it last longer than the 4.0. I wheeled my stock turdy5 for many yrs behind my 2.5 on 33s with very little issue. I swapped it out when I went to 35s.
'94 yj punished regularly. '91 f250 pulls it home after i break it. |
Member # 9154
Just go smooth and easy take a tug when needed. How's the 4.3? did you get refereed?
85 4rnr hi-pin e-lkr, hi-pin detroit 9" w/toy front discs, R151,redbox,d300 4:1, 98.5 dodge-edge EZ, TST p-maxIII, ex brake,Goerend trans,ford outers,quad air bags '05 arctic fox 1140-cameras,SS bbq and stove,280wts solar,inverter,cocktail cubes 24/7 '01 21.5 boat w/502 "Evil Satisfaction" |
Member # 13055
The short answer is Yes, it can be done.
Years ago, I did it with a lockrite in mine. Had a friend do it with factory limited slip. Had another friend do it with a lockrite in the front & open rear. However, it is a gambel.....It is when, not if, with the D35. If he is truley open/open. You may want to look at adding a single locker (front or rear) and carry a spare short side shaft (that's the one that tends to break) for the D35. If he has factory limited slip in the rear, he may be fine, but adding a locker to the front would be huge. I went the 8.8 route with a full Detroit and have not looked back. If your friend wants a solid upgrade axle for his TJ, I would look at finding a TJ D44 (bolt in) or an 8.8, and spend a few dolllars more for an e-locker for either axle. |
#12 (permalink) |
Member # 46447
i've run my d30/35 combo for 5 years, 4.88 gears and lockrites in both. I'm on 33's. I also carry spare shafts and tre's but have never broken anything. 4cyl's and a little finness on the gas pedal is key. Can it be done? yes. Is it ideal? no.
I have a pair of d44's that I need to build. just saving some cash, and waiting for these stock axels to go before I really get serious about it. |
#13 (permalink) |
Member # 17632
I don't think I'd worry about the axles as much as you will be dragging on stuff and probably banging the body a bit. I say it's 100% do-able, but expect some bumps and scrapes.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
#14 (permalink) |
Member # 212411
im alittle late on the feedback but i ran a dana 35 with a welded rear on 37s and as long as you are carefull with wheel speed and binding he will be fine. but wheeling is like a sickness you go out and see what its like and you will get the bug. then you will find yourself giving handjobs for jeep pars lol
IT ALL BREAKS WITH THE PROPER AMOUNT OF SKINNY PEDAL:flipoff2: |
#15 (permalink) |
Member # 55622
We have done multiple work weekends on the trail, and got anyplace we needed on our D30/35 combo, fully open/open.
Climbed Cadillac twice that way. Knew when to take a strap or a quick pull with the winch on Cadillac. The second time on Cadillac, we even pulled a trailer up. We have did just about everything on the Wentworth side while we were open. Can be done, just have to be careful on the skinny peddle, and carry spares. We were lucky, and never broke anything on the Rubicon with that setup. Todd
[COLOR="Blue"][SIZE="4"]BlueRibbon Coalition BOD and Life Member[/SIZE][/COLOR] [URL="http://www.accessarmy.com"][FONT="Comic Sans MS"][SIZE="5"][COLOR="Red"]www.accessarmy.com[/COLOR][/SIZE][/FONT][/URL] Cal4Wheel Life Member Access Army Air Warrior Sponsored by: [URL="http://www.raceline.com"]Raceline Wheels[/URL], [URL="http://www.currieenterprises.com/"]http://www.currieenterprises.com/[/URL] BFG, ARB, Advance Adapters, Hi Lift Jack, Rocky Trail Outfitters, Camel4x4. |
