Member # 198485
99 TJ 3 Link 4 Link Build
Time to get the old Tj in to better off road condition. Was up in Grayling over Christmas and broke the spiders in the 35 so I went and bought an 8.8.
Then I started thinking why go to all the trouble of swaping it into the stock suspension. Might as well get the 4 link done at the same time. Bought the truss, rear frame brackets and lower coil buckets along with all the Johnny joints, shocks and brake lines from Clayton. Built all the rest. Last edited by barnumb; 06-18-2012 at 10:17 AM. |
Member # 198485
Flex Check. Springs are RE 3.5" from Craigslist but the sit closer to 4.25". The lower axle brackets took a while to figure out and build. I burned up a tree worth of cardboard getting them how I wanted them.
My Build http://www.pirate4x4.com/forum/showt...5#post14471555 Last edited by barnumb; 06-16-2012 at 03:55 AM. |
Member # 198485
Decided to build the front brackets myself. Wife is on the Nikon, My fat ass running is the Bridgeport. Here we go........
My Build http://www.pirate4x4.com/forum/showt...5#post14471555 |
Member # 198485
More bracket building.
Member # 198485
Oops Missed some axel pics.
Member # 198485
Exhaust mods, moved the converter up about 18" turned the downstream O2 sensor sideways and stuffed the mufler between the t-case and the frame.
My Build http://www.pirate4x4.com/forum/showt...5#post14471555 Last edited by barnumb; 06-15-2012 at 11:47 AM. |
#12 (permalink) |
Member # 198485
Three link frame bracket.....
My Build http://www.pirate4x4.com/forum/showt...5#post14471555 Last edited by barnumb; 06-15-2012 at 02:07 PM. |
#13 (permalink) |
Member # 198485
More 3rd link frame mount and link.
#14 (permalink) |
Member # 198485
Back on the ground. Now I have to install the SYE and cut down my Craigslist XJ front driveshaft.
#15 (permalink) |
Member # 198485
Handgun mount keeps the XD handy for any trail thugs or backwoods drug runners.
Army surplus hand grenade shifter. Stock front bumper makeover. Tow bar mounts are welded to the frame rail and receiver is pierced through the crossmember. Then the bumper just slips over the top.
#16 (permalink) | |
spot me? mydfghgfff!
Member # 25303
![]() especially the XD mount, gotta remember that after I picked my .45 later this year. Rig looks good, my lil lady likes to snap pics too.
97 TJ 4.0/np435/d300/3link/4link in progress Ultimate Wrangler Build Ups and Swaps Thread
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! |
#17 (permalink) |
Member # 198485
Thanks, your build is looking good too!! I am doing mine one step at a time so I can still use it. Next installment will be a hp 44 gears and tires.
#18 (permalink) |
Member # 198485
Got my XJ front driveshaft cut down for the rear. I used a 1310-1330 conversion joint from Carquest and the Explorer flange.
#19 (permalink) |
Member # 198485
Got the SYE installed.
#20 (permalink) |
Member # 28712
Great build, i wish i had your shop tools . i am doing my tj 8.8 swap with
and old buzz box arch welder and a 100 harbor freight mig welder and the rest hand tools LOL........
keep building jeeps and trucks forever. |
#21 (permalink) |
Member # 198485
Thanks!! My next project is outboarding the rear shocks and home made sway bar disconnects.
#22 (permalink) |
Member # 128896
I like your build, simple. I wanted to comment on your springs, it's funny you say 3.5" spring measured about 4.25". I just upgraded to a 5.5" rubicon express long arm from a 4"short arm. Did before and after measuring, the 5.5" raised my tj 3" over the 4" I had in previously. As you can imagine, reinstalled the 4" springs... And I wish I had your tools, hell I dont even own a welder yet.
Sent from my PC36100 using Tapatalk 2
03Rubi TJ.4" RE LA lift,35's,work in progress.also wifes DD.. |
#23 (permalink) | |
Member # 198485
The tools are great until everybody within 50 miles finds out you have them. If I want to get something done in the shop I have to hide the cars and pretend nobody is home. One of my neighbors admited to using his binoculars to see if I am home......
My Build http://www.pirate4x4.com/forum/showt...5#post14471555 Last edited by barnumb; 08-09-2012 at 05:19 PM. |
#24 (permalink) | |
Member # 128896
