KJ Tech: About as non-hardcore as it gets - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-17-2012, 03:58 PM   #1 (permalink)
grnd93's Avatar
Member # 64925
Send a message via MSN to grnd93
Did pads and rotors on mu wife's 02 KJ a couple weeks ago (143,000 miles). Everything went fine and seemed normal until the other day when she came home from work I noticed a noise coming from the front end. Sounds like a high-pitched rattle. Braking has no effect on the noise, and vehicle speed doesn't seem to change it either (it does go away at a dead stop). Doesn't pull, or shake at all. Had the wheels rotated and balanced yesterday and the guys said everything looks fine. The noise seems to come and go as well. Usually not showing up until after a few miles of driving.
Could this be a hub bearing going bad? or maybe a CV joint?
grnd93 is offline   Reply With Quote
Old 06-18-2012, 01:52 PM   #2 (permalink)
grnd93's Avatar
Member # 64925
Not even a reply telling me how gay KJ's are? You guys are off your game.
Originally Posted by void_of_light
Somewhere in the Canadian wilderness, the new owners are questioning their decision to buy a forum filled to the brim with assholes.
Old 06-18-2012, 02:03 PM   #3 (permalink)
Member # 141679
kj's are kinda gay....doesnt help ya much but id figured id add it
97 Zj orvis-lifted 7" claytons f and r long arm with 36" iroks on shitty axles
NsTyFoX is offline   Reply With Quote
Old 06-18-2012, 02:31 PM   #4 (permalink)
grnd93's Avatar
Member # 64925
I feel much better now.
I'm pretty convinced its the hub bearing, but looking for other opinions before I drop $100 in parts.
Old 06-18-2012, 03:08 PM   #5 (permalink)
theytookmyname's Avatar
Member # 145344
Sounds kind of like when one of the wheel bearings went bad on my 4runner.
Made a consistent noise when moving that came and went. Eventually it got worse and became constant. *shrug*
theytookmyname is offline   Reply With Quote
Old 06-18-2012, 03:33 PM   #6 (permalink)
grnd93's Avatar
Member # 64925
Sounds pretty much exactly what I've got going on. Hope the wheel doesn't fall off before the weekend.
Old 06-18-2012, 03:43 PM   #7 (permalink)
In the Mountains
Trazer75MT's Avatar
Member # 214628
Check the backing plate and the little metal sliders the pads sit in first. i have bent those before or had them just a little off and they would touch the rotor and make nice noises. I have bent the backing plate a little bit to where it touched also. Just thought i would give you the free things to check first.
Trazer75MT is offline   Reply With Quote
Old 06-23-2012, 06:17 PM   #8 (permalink)
grnd93's Avatar
Member # 64925
Changed the driver's side hub bearing today. noise seems to be gone. there was also a little metal shield on the LCA right next to the ball joint. it just clips on, so i took it off in case it was rattling. I couldn't really see what purpose it would serve anyway.
Old 07-01-2012, 07:35 PM   #9 (permalink)
grnd93's Avatar
Member # 64925
this thing is pissing me off. still singing like a bird, but only does it after 10-15 miles of driving. the only thing really left is the CV joints. The boots are starting to crack anyway, so i might as well change them before they fling grease everywhere. I hope it takes care of it, i should be spending this money on my TJ.
Old 07-01-2012, 07:49 PM   #10 (permalink)
Member # 136485
100% sure it's from the front?
Front driveshaft good and greased?
Have you recently pulled the diff cover?
J_Impact is offline   Reply With Quote
Old 07-01-2012, 08:59 PM   #11 (permalink)
Member # 214801
The chicks mountaineer was doing the same thing. I was also leaning toward hub but for a couple hundred I decided to chase it down to be sure. I greased balljoints, TRE's, checked the CV's and went through 2sets of rotors and a set of pads. Finally got fed up and took a crap ton of Hi temp grease and greased the fawk out of both sides of the slides and the back of the brake pads. Noise is gone.
rednekYJ is offline   Reply With Quote
Old 07-02-2012, 03:06 PM   #12 (permalink)
grnd93's Avatar
Member # 64925
Slides are well lubed, I have never used anything of the back of brake pads.
Diff cover has never been off, I guess I should check the front u-joints. I keep forgetting its 4wd. Need to get it warm, the jack it up and narrow it down.
Old 07-02-2012, 03:19 PM   #13 (permalink)
Member # 214801
I never used anything on the backs of any pads until this vehicle. Just throwing it out there......
The bare dry back of the pad plate vibrates against the metal of the caliper. Keeping some brake grease or "anti-squeal" on the back of the pad metal keeps the metal to metal vibrations to a minimum. The action of the pad being pressed against the disk is what causes this, but the noise is transmitted to and amplified by the bare metal to metal contact of the caliper and brake pad back plate. The grease or anti squeal dampen the vibration and keep the bare metal surfaces apart & from making the noise.
Old 07-02-2012, 03:28 PM   #14 (permalink)
grnd93's Avatar
Member # 64925
I'll give it a shot. Honestly it was the first thing that came to mind, but I dismissed it because it was never an issue. Thanks for the tip.
Old 07-29-2012, 06:54 AM   #15 (permalink)
grnd93's Avatar
Member # 64925
Pulled the brakes, lubed the slides, smeared the jizz on the back I the pads. Noise was still there. Ordered new cv's and the rf hub. Replaced those yesterday. Still have the noise. Crawled back under it. Shook the drive shaft and I think I found the noise. The bad news is those fucking joints are expensive! $200 apiece, or $500 for the whole shaft!
Old 07-29-2012, 07:57 AM   #16 (permalink)
Member # 114084
Oh shit! $500!?
For $500 I would seriously be thinking wether or not she NEEDS 4wd.
My wife's KJ had a brand new front driveshaft when we bought it used.
08' JK 2-door, locked, 37's
90' F250 IDI turbo 4x4
Look twice for motorcyclists!
Free Beer is offline   Reply With Quote
Old 07-29-2012, 08:25 AM   #17 (permalink)
grnd93's Avatar
Member # 64925
Originally Posted by Free Beer View Post
Oh shit! $500!?
No kidding...this things basically got a whole new fronted now and I'm only in it for $300. I'll probably pull the shaft and start looking in junkyards. She uses the 4wd in the winter, helps keep her out of the ditches.
Honestly at this point I'd like to burn the thing to the ground.
Old 07-29-2012, 08:26 AM   #18 (permalink)
Trailside mechanic
kb1jkn's Avatar
Member # 88359
Send a message via AIM to kb1jkn Send a message via Skype™ to kb1jkn
Perhaps you can take the drive shaft out and carefully pop the covers off the joints and pack them with grease. if the thing isnt vibeing like crazy then it would make me think the joint it dry more than worn out yet....... if the whole thing is pressed together then drill a small hole, use a pencile grease tip and fill to your heats content. a nice shot of rtv in the hole will seal it up. For that money i think its well worth a shot.
kb1jkn is offline   Reply With Quote
Old 07-29-2012, 10:07 AM   #19 (permalink)
grnd93's Avatar
Member # 64925
Might give it a shot...the thing has been in 4wd less times than I have fingers. Sure it's got 145,000 on it but the joints shouldn't be worn out already. And if they do wear that fast they should cost less than 200 fuckin dollars!
Old 07-29-2012, 11:02 AM   #20 (permalink)
Member # 9991
First, pull the driveshaft and see if the noise goes away before spending anymore cash.
[url]www.scotthansen.net[/url]
MrWillys is offline   Reply With Quote
Old 07-29-2012, 11:08 AM   #21 (permalink)
Beat95YJ's Avatar
Member # 22176
Don't use logic here.
I had a similar driveshaft problem in my WJ. Company fleet mechanic didn't believe me and replaced the transmission instead. After he was done The noise was still there and he finally replaced the driveshaft. The funny part was I told him it was a CV to begin with. Thank God it wasn't my money.
Beat95YJ is offline   Reply With Quote
Old 07-29-2012, 11:09 AM   #22 (permalink)
Beat95YJ's Avatar
Member # 22176
You posted and non-hard-core. We're not allowed to flame you. We'd love to tell you how A KJ is gayer than four dudes fawking, but we're just not allowed to.
Old 07-29-2012, 11:16 AM   #23 (permalink)
grnd93's Avatar
Member # 64925
That's better
Old 07-30-2012, 06:01 PM   #24 (permalink)
Member # 17632
Those shafts suck. We have a bunch of Libertys at work. We had the local driveline shop make a shaft with common joints (one end double cardan CV) to see if it would work as a cheaper alternative, but that one had some vibes. It wasn't an issue for us since these things never leave our property, but if it was street driven it would get very old very fast. I would get a factory shaft. Just thought I'd pass on some first hand experience.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 07-30-2012, 06:49 PM   #25 (permalink)
grnd93's Avatar
Member # 64925
Just spent the last hour wrestling the shaft out. The rear CV is definitely shot. Boot is gone and everything. I'm sorta kicking myself for not seeing it sooner, but at least I took care of some of the things on the front end that were eventually going to need attention anyway.
now I gotta find a cost effective fix for this, looking at another $200 minimum probably just to replace to bad CV.
Oh and I noticed grease coming from the LF lower ball joint boot. I musta punctured that when I had it apart Saturday.
Anyone got a match?
