TBI computer controled distributor on 4.2L? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-19-2012, 09:14 PM   #1 (permalink)
Member # 8867
Send a message via AIM to YJ4LIFE Send a message via Yahoo to YJ4LIFE
Question TBI computer controlled distributor on 4.2L?
Is there a way to get the TBI computer to control the timing on a 4.2L? Do you just need a GM distributor? Why wouldn't the howell kit include something like that?
-Taz, '89 YJ
YJ4LIFE is offline   Reply With Quote
Old 07-20-2012, 11:54 AM   #2 (permalink)
CSP
Member # 1533
The stock distributor can be modified to do this. The mechanical advance springs need to be welded to prevent mechanical advance and the vacuum advance can just be disconnected from the vacuum line. At that point the purple and orange wires on the stock distributor are connected to the correct terminals on the GM 7-pin or 8-pin ignition module.
Your TBI system must first have this capability. Howell, for whatever reason, has just made the choice NOT to allow for computer controlled spark. You'd have to ask them why.
Affordable Fuel Injection's kits do control spark timing.
CSP is offline   Reply With Quote
Old 08-02-2012, 08:44 AM   #3 (permalink)
the freeak's Avatar
Member # 41185
Can the Howell system be retrofit to the OEM style where timing is controlled, or is the wiring/ ECM an issue?
the freeak is offline   Reply With Quote
Old 08-06-2012, 02:43 PM   #4 (permalink)
CSP
Member # 1533
You would have to add wiring to the Howell harness and reprogram the ECM to incorporate spark timing. I did it to the Howell kit in my CJ.
75 CJ5, 258, T18a, 4.27's, Warn 8274, Howell EFI
