lift and tire size - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2012, 03:59 PM   #1 (permalink)
Member # 216724
lift and tire size
Ok im new to the form jeeps and rockcrawling so trying to figure out what i need
i have a 92 xj 4.0ho thinking of going 4.5-5.5 lift what im wonting help on is what
is the best brand coil springs will be best for flexing and second what
Is the best lift for rear leaf packs or add leaf and blocks or anu
Other options and what is the best tire size for lift and cutting
Is not an issue
ddscott is offline   Reply With Quote
Old 07-22-2012, 07:09 PM   #2 (permalink)
Member # 197308
come back in 2 days
Brandonjames is offline   Reply With Quote
Old 07-22-2012, 07:15 PM   #3 (permalink)
Tonka Truck Driver
fatboyf150's Avatar
Member # 115381
Send a message via Yahoo to fatboyf150
Can you write that in English?
What happens in the Cooking Forum, stays in the Cooking Forum.
www.facebook.com/kenneth.rivenbark
fatboyf150 is offline   Reply With Quote
Old 07-22-2012, 09:17 PM   #4 (permalink)
DROCHONJR's Avatar
Member # 81356
Go RE 4.5 and sye kit and 33s
DROCHONJR is offline   Reply With Quote
Old 07-22-2012, 09:22 PM   #5 (permalink)
Member # 216724
It all seem plain english to me whats not to understand thinking of going 4.5 inch-5.5 inch lift and i
wont to know what the best tire size would be if i do fender cutting and what brand lift should i go with
Old 07-22-2012, 09:25 PM   #6 (permalink)
Ajs biggest fan!!
RANGERROD's Avatar
Member # 172656
Is frank in the jeep section now?
RANGERROD is offline   Reply With Quote
Old 07-22-2012, 09:32 PM   #7 (permalink)
Launch it
Georgia boy '88's Avatar
Member # 43592
Send a message via MSN to Georgia boy '88
Originally Posted by ddscott View Post
It all seems like plain English to me. What's not to understand? I'mthinking of going with a 4.5 inch-5.5 inch lift and I
want to know what the best tire size would be if I do fender cutting and what brand lift should I go with
A little better...
If you cut the fenders you can fit any size tire you want, probably more than your stock axles can handle. I fit 33's on 1 3/4" lift with room to spare.
'93 F-250 tow pig/dd- RIP ended up extra crispy
'94 XJ- yardsaled...
Georgia boy '88 is offline   Reply With Quote
Old 07-22-2012, 09:41 PM   #8 (permalink)
asian195's Avatar
Member # 128896
What size tire do you want? That should be your first question, to yourself. Then look at different manufacturers recommended tire size for their lifts. Probably can go up 1 size from there with trimming. How much are you willing to trim? Long arm? Short arm? How much money are you willing to spend? What do you have for axles? Gearing? There are a lot of questions you need to ask yourself. Then do some research on other builds to see what they are running.
I'd run 39" pitbulls, RE 5.5" short arm lift with some good trimming and weld up the stock rear gears. Should run like a champ....:banghead:
Sent from my PC36100 using Tapatalk 2
03Rubi TJ.4" RE LA lift,35's,work in progress.also wifes DD..
asian195 is offline   Reply With Quote
Old 07-22-2012, 09:46 PM   #9 (permalink)
Member # 114084
Is not an issue
I want to fill shotgun shells with periods, commas and apostrophes. Then, shoot the shit out of this run-on sentence.
08' JK 2-door, locked, 37's
90' F250 IDI turbo 4x4
Look twice for motorcyclists!
Free Beer is offline   Reply With Quote
Old 07-22-2012, 09:59 PM   #10 (permalink)
Member # 216724
Stock gears for now till i break something probly weld the rear and ill cut as much as it take tire size
Is basically what the axles will hold for a wile want to keep lift under $1500 not sure if long arm or short arm i read on here some people were saying no need for long arm under 5in of lift and that is what im trying to figure out i like the re 4.5in super flex and its short arm but dont know if i need the
long arm kit for better flex
Old 07-23-2012, 08:06 AM   #11 (permalink)
jsawduste's Avatar
Member # 77571
Subscribed
Bored and looking for some simplistic entertainment, PBB style.
Sent with smoke signal.
jsawduste is offline   Reply With Quote
Old 07-24-2012, 12:37 AM   #12 (permalink)
PBB Official WTPOS
SkooledMedic's Avatar
Member # 170546
you're on the wrong forum boy.
PM ironpig70, he can help you with your engrish and sell you everthing you need to lift your xj.
SkooledMedic is offline   Reply With Quote
Old 07-24-2012, 06:10 AM   #13 (permalink)
Captain who knows
Rooney77's Avatar
Member # 82435
OP, first, reread your English books, learn punctuation and how to proofread. That'll carry you a lot further on this forum.
Second, give more details. For instance, what size tire, what type of wheeling, what axles.....
Third, you really think you are the first person to ask this? SEARCH, repeat that step a few times, then ask your questions. There is very little more aggravating than seeing the same "what lift/tires can I run on my ____".
Until you complete all three steps, I'd suggest you not post again. And this post is an example of pirate being nice.
My diesel flatfender build:
http://www.pirate4x4.com/forum/jeep-...eys-build.html
Originally Posted by ironpig70 View Post
Fawk some people are idots.
Rooney77 is offline   Reply With Quote
Old 08-01-2012, 08:58 PM   #14 (permalink)
Member # 113298
Get a 4 inch lift. Some 24" chrome rims and low pro file tires and some neons.
l3igjames is offline   Reply With Quote
