TJ rear D44 vrs XJ axle difference? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-18-2012, 06:20 PM   #1 (permalink)
Member # 52979
Have a TJ dana 44 what needs to be done to fit this in a XJ (both are 1998)??
zakt is offline   Reply With Quote
Old 08-18-2012, 06:45 PM   #2 (permalink)
PBB Official WTPOS
SkooledMedic's Avatar
Member # 170546
I'm assuming its set-up for disk brakes.
Unless you are linking the XJ as part of the swap, you need spring perches, and that should really be it.
Obviously you'll need to adapt the e-brake cables and brake lines, but that should be really simple and straightforward.
Basically:
cut the coil spring perches and control arm mounts off the TJ axle, weld on leaf spring perches bolt the axle in and adapt everything else.
I am willing to take huge cock in the ass for an 8-ball
SkooledMedic is offline   Reply With Quote
Old 08-18-2012, 11:33 PM   #3 (permalink)
TheSpecialistOkc's Avatar
Member # 43215
Send a message via MSN to TheSpecialistOkc Send a message via Yahoo to TheSpecialistOkc
The XJ D44 has a thicker tube and less work.
TheSpecialistOkc is offline   Reply With Quote
Old 08-19-2012, 09:20 AM   #4 (permalink)
ONEtonXJ's Avatar
Member # 145633
cut all the 4 link bracketry off and weld some leaf spring perches on....
or the other way around.... build a 4 link cross member for the XJ and keep the 4 link mounts on the axle... i would do that if it were mine
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 08-19-2012, 07:35 PM   #5 (permalink)
Member # 219137
I have read this many times before but have never seen anybody put up any specs.... Is this just urban legend or what?
CZDiesel is offline   Reply With Quote
Old 08-19-2012, 11:38 PM   #6 (permalink)
Member # 85224
yeah, read the same-- said to have the same tubes (2-5/8") as in dana 35s with only 1/4" wall, but i've never put a caliper on one..
the 44 i put in my xj (from an old XJ) was dang tuff... beat on it regularly
xj(sold) current Junk ='80 CJ7 304, 4spd, 4.88s locked on 35s..
jlane99xj is offline   Reply With Quote
