Newbie
Member # 32848
78 D60 caliper
Installing Dayton 2 piece calipers on a 78 Ford Dana 60.
Where does the metal spring/shim go on the H block? Is this correct? I tapped in the spring/shim with the H block at the same time. Is Locktight enough, or should H block be tack welded also? |
#3 (permalink) | |
Member # 157355
be easy on those flanged bolts. I broke one off and it ruined the caliper.
