Jeep FC170 "Patina Rod" (and "mutt") - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-14-2013, 04:22 AM   #1 (permalink)
Member # 39799
After a year+ of not owning a Jeep, and just focusing on my now 14-year-old daughter's 2-door XJ build (build thread HERE), I got myself into another big project that'll eventually give me some great utility, and have some great character at the same time.
This will be a fairly low-budget build utilizing late-model drivetrain parts, with an attempt to maintain the character/patina of the FC cab. Here's the plan (updated below as parts/plans have changed):
  • Repair the floors in the cab and neutralize exterior rust as much as possible. Prep/paint the interior nicely, but retain the existing exterior paint scheme/patina, rust, etc.
  • Mount the cab on a 2008 Ford F350 Cab and Chassis frame (see below) painted nicely in satin black.
  • Mid-engine install of a '95 Cummins 6BT, 47RH 4WD transmission and 2001 Dodge NP241 DHD Transfer Case.
  • Build custom bumpers.
  • Build a semi-custom bed. The original bed is shot, so repair is not an option. Some of you chimed in and suggested rebuilding a bed like the stock one, but for me, the flatbed will give me the utility I need, and be a lot easier/cheaper than trying to reconstruct the stock-style bed.
  • Tire size? Stock F350 (~31-32" tall).
  • Must be built with a meager budget.
The FC170 cab donor (see below). I originally started with a different "Dan's Snowplowing" FC170 cab, but plans changed when I found the (better-condition) gray/patina FC170.
Jeep Commander "Saddle Brown" leather seats blend beautifully with the patina, and will add a touch of class to the interior. Matching custom leather arm rests and sun visors will complement the seats.
I wanted a stout, longer-than-stock heavy-duty frame for my project. Rather than work with the original frame, I decide to mount the cab on a late-model F350 Cab & Chassis frame, allowing me to use off-the-shelf suspension & axle parts. Ultimately, I landed on using a 74K-mile 2008 frame, which included the fuel tank, lines, etc. It also has the side pieces for a hitch (but not the center section).
The Ford Body Builder Guide on the Ford Fleet site has been an incredible resource for dimensional data.
I got the narrow F350 Cab & Chassis Dana 80 (71.1" WMS-to-WMS) from the same 2008 F350 C&C. Gear ratio is 3.73.
The front axle is a Dana Super 60 (3.73 ratio) from a 105K-mile 2005 F350 pick-up. I replaced the ball joints, U-joints & pinion seal, and am just finishing up getting the axle & suspension parts cleaned up & painted.
1994 Cummins 12v 6BT, 230K miles
Rebuilt 1994-1995 Dodge 47RH 4WD automatic transmission & 2001 NP241 DHD transfer case
1x1_Speed_Craig is offline   Reply With Quote Quick reply to this message
Old 12-14-2013, 11:13 AM   #2 (permalink)
jsawduste's Avatar
Member # 77571
Looks good Craig !! As always I know you will put your heart and soul into this project.
Might want to talk to Chris, Chris Fitzpatrick Offroad | Menlo Park, CA 94025 he was getting involved with some FC stuff and might be able to help out.
Sent with smoke signal.
jsawduste is offline   Reply With Quote Quick reply to this message
Old 12-14-2013, 12:13 PM   #3 (permalink)
Member # 39799
Thanks for the tip...much appreciated. I'm also fortunate because the guy I got it from (now a friend of mine) is local, and owns 3 of them himself, so I amazingly have a local parts supply. There also won't be much "FC" on this FC project, just the cab.
I'm excited to get it underway! I have wanted one of these for a decade.
Craig
1958 Jeep FC170 "Patina Rod", '97 XJ 2-dr. (14-year-old Mira), '00 XJ 2-door (12-year-old Maeve)
Old 12-14-2013, 12:32 PM   #4 (permalink)
Member # 98895
Send a message via AIM to dezrik Send a message via MSN to dezrik Send a message via Yahoo to dezrik
Awesome Project!! Looking forward to the build. Ive always been on the look out for a cab or a whole truck to build one myself. Seems a bunch of FC Builds have been popping up lately and I love it.
dezrik is offline   Reply With Quote Quick reply to this message
Old 12-22-2013, 07:26 PM   #5 (permalink)
Member # 39799
A few updates...
I found someone who could use the heavy-duty 12-leaf rear springs from my "frame cut", and will be pulling them off the axle later this week.
My '98.5-'99.5 F350 rear "frame cut" is now stripped down to a bare frame, and will likely be going to scrap in the spring. I had originally planned on grafting the stock front half of my stock FC170 frame to the rear half of the F350 Cab & Chassis frame. However, I found that the stock FC170 frame isn't actually solid enough to work with, and there would be a LOT of fabrication work to get everything aligned properly, as well.
I did, however, find a complete 2005 F350 Cab & Chassis 141"-wheelbase frame that I'll be picking up about 1 1/2 hours from my house this Friday. I'll have to build custom cab mounts up front, as well as figure out how to set up the steering box on the new frame, which is about 7" wider than the stock FC frame up front. The DRW rear axle will bolt into the new frame just fine. 2005 is the first year that the F350s utilized coil springs up front, which leads me to my next find...
Timing is up-in-the-air depending on when the seller can get the parts pulled, but I'll be picking up all of the front & rear suspension-related parts, and the Dana 60 front axle a 2005 F350 (SRW) that was hit in the rear. I'm not sure yet about the gear ratio of the front axle, and will likely have to regear to 4.30 eventually to match the DRW rear axle I already have. I'll also have to locate some DRW front spacers to mount on this SRW axle. The biggest challenge, though, will be finding a set of wheels. 2005 introduced bigger brake calipers & rotors on the F350s, requiring a minimum 17" wheel diameter. Most 8 x 170mm dually wheels I have seen are 16" wheels, and to further complicate things, the later-model (bigger diameter) DRW wheels used a different bolt pattern (8 x 200mm). I have a couple 16" DRW wheels, and rounded up some others, as well. However, I'll have to research if these are even an option up front, or if I'll have to go bigger down the road (aftermarket DRW wheels are stupid-expensive).
This is the result of my (novice) Photoshop work, giving me a "blank canvas" to hand-draw in the rest of the custom vehicle build using my somewhat dormant artistic skills (I started working on one today). Based on my calculations/estimations (many of which came from studying the drawings on the Ford Fleet "Body Builders Layout Book"...a GREAT resource!), the 141"-wheelbase F350 Super Duty Cab & Chassis frame should give me approximately the same bed length as the 1957 FC180 concept vehicle, but with a slightly longer wheelbase.
Pics of the "new" frame to come at the end of the week.
Old 12-22-2013, 08:05 PM   #6 (permalink)
Tinfoil Zone
FlatBlackXJ's Avatar
Member # 68916
Very cool! Always nice to see an FC getting brought back to life!
94 xj, 44/9, 4.5", 3 link, locked f/r, 35s.
94 k2500 suburban big block tow pig
IG: flatblackxj
FlatBlackXJ is offline   Reply With Quote Quick reply to this message
Old 12-28-2013, 03:13 PM   #7 (permalink)
Member # 39799
Thanks!
Here's my "new" 2005 Ford F350 141"-wheelbase Cab & Chassis frame. I coerced my girls into heading to Clare, MI to pick it up by offering to buy them lunch at "Cops & Doughnuts" in Clare (they're suckers for sugar). I also drove them (briefly) through Mt. Pleasant, where I went to college.
Here's the muscle of my Jeep rebuilding operation...my fiancee, Amy, and my daughter, Mira.
And here's the frame all nestled into it's longer-term home. I'll have to build custom cab mounts for the FC cab, custom motor mounts, and a custom mounting solution for the oddball cab-over steering box. Suspension & axles will be stock F350 items.
Old 12-28-2013, 05:25 PM   #8 (permalink)
jsawduste's Avatar
Member # 77571
Shipping on Amy to 48066. There is a frame in your post, where ?
Looks like a great start to what will be a super duper build.
Taling reservations for rides yet ?
Old 12-28-2013, 10:41 PM   #9 (permalink)
Member # 79132
This is going to be cool! Another thread of yours to watch!
deadman-v is offline   Reply With Quote Quick reply to this message
Old 12-28-2013, 11:37 PM   #10 (permalink)
Jeepfanforlife's Avatar
Member # 400441
Damn I'm subscribing can't wait to see more.
Conservative person above^
Jeepfanforlife is offline   Reply With Quote Quick reply to this message
Old 12-30-2013, 11:43 AM   #11 (permalink)
Member # 405930
Subscribed
wtfjackbbq is offline   Reply With Quote Quick reply to this message
Old 01-02-2014, 06:47 PM   #12 (permalink)
Member # 39799
Thanks guys!
What do you see here? I see replacement cab corners & sheet metal for my FC cab. Big thanks to my buddy Kyle for the scrap FC170 roof. The profile of the corners should work pretty well for the lower body corners. I traded an XJ 242 transfer case for a bunch of misc. parts...some sheet metal (including some floor pan sections coming soon) that I'll use to patch my FC cab, a better set of seats, and some small parts I was missing.
Old 01-03-2014, 08:11 AM   #13 (permalink)
Member # 175005
Looking good, im building a FC 170 myself. What is your plan for the steering?
jones486 is offline   Reply With Quote Quick reply to this message
Old 01-03-2014, 09:12 AM   #14 (permalink)
Member # 39799
Cool! Do you have any pics and/or a build thread?
Good question. I just started looking at Isuzu NPR steering-related stuff, and have to do more research as to whether it would work or not. I'm definitely open to suggestions. I just saw your "Fc 170 power steering ideas" thread, as well.
Craig
Old 01-03-2014, 01:32 PM   #15 (permalink)
Member # 175005
Yea my build is over in ifsja.org Fc 170 build... - International Full Size Jeep Association. I also looked at the NPR stuff but it can be hard to find good pictures and information on them or any cab over set up for that matter. I am looking at trying to do a set up similar to this one http://www.rvcruzer.com/images/UFO_2...ering2_XGA.jpg But with the steering box pretty much directly attached to the 90degree box, the only trouble is finding one of the little boxes. The main issue I have found with looking at the steering on various cab overs is that they pretty much all use rack in pinion.
Old 01-03-2014, 04:53 PM   #16 (permalink)
Member # 39799
Yeah, I have seen your IFSJA thread (didn't make the connection). Thanks for the steering ideas. I'll look into these, as well.
Old 01-05-2014, 01:43 PM   #17 (permalink)
Member # 400441
I like the concept named "the mighty Fc" with portal axles although it looks likes it's lifted higher than it should be it's very stable because of the weight distribution. Are you thinking of doing Portal axles?
Old 01-05-2014, 02:34 PM   #18 (permalink)
Member # 39799
I've seen the Mighty FC in-person, and yes, it's pretty tall (although I didn't take notice of what axles it was running when I saw it). I have no desire to use portal axles...too tall, and it wouldn't fit the character of this build anyway. I'm using stock F350 axles on my FC project (Dana 60 front, and a dually Dana 80 rear).
Here's a pic of my fiancee next to it at the 2012 Jeep Blessing.
I'm definitely a "keep it low" kind of guy, too. This is the '05 LJ I built on 1-tons, 37" tires, and only 3 1/2" of lift.
Old 01-05-2014, 09:53 PM   #19 (permalink)
Member # 202881
my dad has a few 170s one being a crew cab. other being a factory dual rear wheel. very interested in this.
fordf350dually is offline   Reply With Quote Quick reply to this message
Old 01-06-2014, 05:16 AM   #20 (permalink)
Member # 39799
Sweet!
Old 01-06-2014, 05:19 PM   #21 (permalink)
Member # 202881
If it ever warms up ill post some pics. I know he is on forward forum or something beause he registered his crew cab. has all the military paper work and service records. I believe its a 64?
The dually vins out to be the last 60 or first 61 dually with a 4 speed and vaccum assist brakes as well as a factory ramesy winch (missing of coarse along with the 4 speed shifter which is like hens teeth) but they are very cool trucks.
Good luck with the build!
Old 01-06-2014, 06:22 PM   #22 (permalink)
knightkrawler's Avatar
Member # 179963
Looking forward to this build subscribed.
Rig stolen by evil bitches......
'Resistance to tyrants is obedience to God." Jefferson
knightkrawler is offline   Reply With Quote Quick reply to this message
Old 01-07-2014, 05:28 AM   #23 (permalink)
Member # 120166
Send a message via AIM to SwampFox89@aol.com
I'll be watching this build, I have a 170 dually that I am going to start working on this year.
The way that you wander is the way that you choose.
SwampFox89@aol.com is offline   Reply With Quote Quick reply to this message
Old 01-07-2014, 01:25 PM   #24 (permalink)
Member # 156517
Cool build looking forward to more updates
Billy_Bottle_Caps is offline   Reply With Quote Quick reply to this message
Old 01-07-2014, 03:44 PM   #25 (permalink)
Member # 173375
Love the FC build, but the title disappointed me a bit, I thought maybe you were going to incorporate some m151 (mutt) parts into this. Not sure why you would, but it'd be cool ( to me at least)
1995 F150 Flareside 351W auto 3" lift 33s 186K cripplehauler
95stepside is offline   Reply With Quote Quick reply to this message
