Project "Collateral" - 2005 LJ on 37's - Page 17 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2017, 02:04 PM   #401 (permalink)
Member # 165670
New bracket. Cooling now, and then I'll pull the sway bar and check for bump on both sides.
My build.
rokk99 is offline   Reply With Quote Quick reply to this message
Old 03-19-2017, 05:39 PM   #402 (permalink)
Member # 165670
Got it done... I think. 6.5" up travel with the frame where it is now. I think it may end up more like 7.5 to keep level with the front.
Full stuff - passenger
Driver - has about 3/4" less uptravel because of the fuel lines and track bar mount.
Fuel lines - need to tie them up by the frame rail so they're clear of the axle brackets.
My build.
Old 03-20-2017, 08:13 PM   #403 (permalink)
Member # 165670
Replacement driver-side brake line is hooked up, springs installed and it's back on its own weight all around. With 1" of preload it's sitting about 1/2" high in the rear with 6-3/4" up travel. All in all, very happy with how things are looking. Just a couple small things left like bleed the brakes, hook up the driveshaft and recharge the nitrogen in the bumps and shocks. Oh, and the exhaust mods...
My build.
Old 03-21-2017, 08:49 AM   #404 (permalink)
Newbie
Member # 322985
Looking good, rokk.
beaureed445 is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 02:00 PM   #405 (permalink)
Newbie
Member # 477561
Sub'd! Great build Rokk.
Uncle_T is offline   Reply With Quote Quick reply to this message
Old 03-23-2017, 07:11 PM   #406 (permalink)
Member # 165670
14" long limit straps are perfect length and hooked up.
Ride
Full droop
My build.
Old 03-23-2017, 08:08 PM   #407 (permalink)
Member # 165670
Filled the shocks up to 200psi. I've never used a chuck like this before, but it makes sense now. Unscrew the valve, screw the chuck onto the schrader, turn on the tank, screw the valve down to depress the schrader. It fills in about 2 seconds. Turn the tank off, unscrew the valve and unscrew the chuck from the schrader. Charged the bumps to 200psi also. Well one of them anyway. The other has an issue...
I used an old lifting band as extra padding and to protect the cage paint. Not sure I like the look, but I do like the setup and where the reservoirs are located.
My build.
Old 03-24-2017, 08:14 PM   #408 (permalink)
Member # 165670
Yesterday, just as I was patting myself on the back and admiring a job well done, I decided that the fuel line needed to be bent just a bit further from the track bar bracket. A little tug here, pull there and POP... broke the plastic nipple that the fuel line attaches to. Shit... so now I'm screwed, and if you've followed this build for a while you'll know this is the second time I've busted this part of the pump.
So, out comes the tank, but wait, one of the two bolts on the front side is stripped. Air saw, die grinder and an hour later the tank is out. Spent most of the day today chasing down a fuel pump module. $220 later, and after drilling a new mounting hole, the tank is back in and the Jeep is running. So, aside from having now spent about $500 replacing fuel pumps because I'm stupid, it was a good day.
Before all of this, while bleeding the brakes, everything was going well - just getting the last few bubbles out all of a sudden it was just air. I checked the master cylinder and it looked full; it wasn't. Over the years, there became a stain where the fluid usually sits making it look just like it was full to that point. This was actually a relief because there's nothing worse than not knowing what's going on. We kept at it, and probably 20 pumps of the brake later some fluid started to come out of the bleeder. Hit them again and got a good pedal.
Still, tomorrow she drives! Looking forward to the payoff. This has been a lot of work. Sometimes I think people just show all of the pretty parts magically coming together. In my world it's a total shit show about half the time. The nice thing nowadays is that I have enough tools to work out of jams like these. For example, if I didn't have a good die grinder with a good carbide burr and a good air saw I would have not been able to get the tank back out.
Little things to button up and not forget tomorrow morning:
- Tighten limit strap bolts
- Tighten frame-side track bar
- Tie ebrake lines out of the way - not going to deal with the eldorado ebrakes right now
- Attach soft top and windows (probably a hard thing to forget...)
- Hood pins
- Torque all lug nuts
- Bend passenger front brake line inward (has been hit by the antirock arm bolt)
My build.
Old Yesterday, 10:54 AM   #409 (permalink)
Member # 165670
Proof it's actually done. First time on the road in 8 months. Haven't been on the highway yet, but the tire balance is good up to 55. Need to build the covers where the coilovers come through the body. It's pretty loud, not that it was ever quiet.
My build.
Old Yesterday, 01:09 PM   #410 (permalink)
giles45shop's Avatar
Member # 197896
Looking good - has to be a great feeling to actually drive it! Mine is coming up on a year of being under the knife. My buddy teases me every time we see a Jeep on the road - "His is better than yours" - because it's actually driving
giles45shop is offline   Reply With Quote Quick reply to this message
Old Yesterday, 07:09 PM   #411 (permalink)
Member # 165670
It is for sure. Now I have to do the front coilovers... hoping that will be a couple weekends. There's a lot less to deal with like the tank, brake lines, etc.
My build.
Old Yesterday, 10:31 PM   #412 (permalink)
Member # 165670
Trying to plan a bit more before diving in. Here's the list for the front:
Prep
- Lower rear 1"
- Weigh all four corners
- Buy bumps
- Buy bump cans
- Start figuring spring rates
- Re-valve coilovers
- Order strip of 3/16"
- Buy limit strap mounts
Front coilovers
- Remove battery
- Remove fenders
- Measure for current front frame height
- Set at desired frame height
- Remove tires
- Remove old shocks and springs
- Remove brake line
- Cut factory coil and shock tower off
- Set axle at full bump, leave steering connected
- Tack lower mounts
- Position coilover with 1" shaft showing
- Determine top mount position
- Check frame height and shaft showing at ride height
- Mark cut of shock hoop
- Tack hoop
- Mount coilover and cycle
- Trim inner fenders if necessary
- Figure out reservoir mounting location (shock hoop?)
- Remove coilover
Bump Stops
- Move axle to full bump
- Uncharged bump and compress
- Determine frame and landing pad location keep as far back as possible
- Reuse old spring pad?
- Place bumps 1" higher than needed
- Tack cans to frame
- Remove, trim or build new landing pad
- Build can support mounts
- Tack mounts
Track bar & sway bar
- Remove upper track bar mount half and swaybar mount
- Build new upper track bar mount out of 3/8"
- Wire paint off lower, inner mount
- Re-weld inner, lower mount for additional strength
- Tack upper on and mark location
- Use bolt to mark drill location on upper
- Drill
- Tack upper on
- Cycle suspension
- Build vertical brace to tie halves together 3/16"
- Tack brace on
- Cycle
- Finish weld mount
- Measure and mock anti rock mount
- Make mount of 3/8"
- Tack
- Cycle
- Finish weld
Limit straps
- Attach shocks
- Drop axle (with steering attached
- Tack limit strap mounts
- Measure strap lengths
- Order straps
- Attach and cycle
- Finish weld
Finish
- Weld everything
- Charge shocks
- Charge bumps
- Paint
- Attach fenders
- Add springs
- Mount bumps and shocks
My build.
