Member # 23487
Can anybody tell me how to pull the pins on TJ windshield hinges? The pins have heads on both sides of the hinge making it appear to be two pins per hinge pushed in on both sides of the hinge. I havent pried on them yet because they are painted. Figured that I could get the skinny from you smart folks before I fook them up.
Thanks in advance, Searcher
Some people like to know that they are buying an example of creative passion rather than industrialized pedestrianism. "Seabass doesn't need to sell crack! CRACK sells itself" - Bones |
Member # 8540
since you are probable just going to ruin them when you pull them out just drill out one side and replace the double sided pin with something easier to remove
i.e.-solid pin with flange on one end and drill a whole for a cotter pin on the other
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB Nothing is stronger than stupid... |
I have wanted to do this also. Seems I am always bashin my windshield frame. I just figure on using a nut and bolt to replace the pin. As far as geting the stock pin out I bet you could grind the head off one side and drive it out.
Carpe Diem, BABY! |
From what I've read/seen, you grind off one end and pound the crap out of it to get it out. Then you can slide a 1/2" reciever pin through there and call it good. I've got the pins, just haven't done it yet.
98 TJ gettin' some serious driveway time. |
Member # 16052
Took a side grinder w/ cutoff wheel to mine, cut the ends off the stock stuff and knocked out, real pain in the ass. Went to home depot looking for hinge pins and found pins the right size and length with a head on one end and holes w/ pins on other. works
POS TJ, is your shit running? Usual Suspects Offroad |
#17 (permalink) |
I can't believe some company isn't making hinges for all Jeep models with removeable pins. Seems like there would be demand. I've trashed two windshields cause I'm too lazy to unbolt the windshield. I would order a set...
Is 39.5 big enough to just say 40? If only it was 1/2" bigger! Last edited by jeepjunky; 08-24-2009 at 02:50 PM. |
