TJ Gear change - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2017, 06:57 AM   #1 (permalink)
Member # 19795
TJ Gear change
I am sure I am going to get grief over this but here we go!
I have want to do a gear change and the charts on the net are a bit deceiving so I though I would ask here.
1998 TJ Hard Top 4.0 3.07 gears AX15 with 33.5" tires,
What gears should I have to bring the engine back into it correct operating RPM?
Richard
Richard w is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 08:32 AM   #2 (permalink)
GreatWhiteXJ's Avatar
Member # 103442
Send a message via AIM to GreatWhiteXJ
6:17's
XJ Buggy. RoXJoX
GreatWhiteXJ is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 09:12 AM   #3 (permalink)
Member # 5021
Originally Posted by GreatWhiteXJ View Post
6:17's
6.18's
Don't be "THAT GUY" on the trail.
The Rockslut is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 11:06 AM   #4 (permalink)
Member # 166467
Noobs. 9.43 minimum. Max performance I would go with a 12.82
ranger4.0 is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 11:07 AM   #5 (permalink)
Member # 166467
Seriously though... this is the Cherokee hardcore forum, I would post this question in the jeep non-hardcore section and maybe in the general 4x4 section as well. Or maybe search google. The tj has been around a long time and I'm pretty sure you would find the answer you want with a two minute google search on any jeep forum
Old 03-20-2017, 11:22 AM   #6 (permalink)
Member # 19795
Gears
The header says Jeep-Cherokee so I though it covered both in the non hared core section. I do not see a section for the Jeep-Wrangler and as to searching the question I did and that is why I am here looking for first had info.
Old 03-21-2017, 06:11 AM   #7 (permalink)
Member # 171520
Jeep - Non Hardcore - Pirate4x4.Com : 4x4 and Off-Road Forum
rockwood is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 07:13 AM   #8 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Moved... to non hardcore...
2K posts and the jeep owner could not find the Jeep section
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 11:53 AM   #9 (permalink)
Member # 17632
I have 4.10s in my 2000. 4.0, 5 speed, 33" BFG KM2s. It's geared pretty good for the road, it'll go 75+mph comfortably (2600-ish rpm?) with 5th gear still being fine for lower speeds like 55-60. If you think you will go to 35s in the future, go lower now. 4.10s with 35s is no good in 5th gear unless everywhere you go is perfectly flat or downhill.
Travis..
'15 Ram 2500 4x4 Big C and a 6 speed
2000 TJ on 35's
crashnzuk is online now   Reply With Quote Quick reply to this message
Old 03-21-2017, 01:58 PM   #10 (permalink)
Member # 19795
diff
is that 2600 in 5th gear?
Old 03-21-2017, 03:28 PM   #11 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
I ran 4.56's in my 98 TJ with 33's. But I did start with 3.73's. I was much happier with the 4.56's when I upgraded to 35's.
:tank:
Old 03-21-2017, 04:39 PM   #12 (permalink)
Member # 19795
gears
My 35" tires truly measure 33.5"
Old 03-21-2017, 05:28 PM   #13 (permalink)
Mr. Lucky
Goldie Locks's Avatar
Member # 84122
4.88's if your doing a good bit of wheeling or around town driving. You wont like them at 70mph
4.10's if your mostly on road.
4.56 if your not sure and you might go with bigger tires later.
Just my opinion. I have had the all....
YJ on Ton's
Goldie Locks is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 05:37 PM   #14 (permalink)
Member # 79509
Rubicon came with 4.11s and 30.5 tires. The overdrive between the two is a .01 difference, so negligible.
There is no magical "correct operating RPM"
Minimum 4.56s on a regear.
I'm not happy, until you're not happy.
If you're from California, you're not a Yankee. You're not really anything.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 06:00 PM   #15 (permalink)
Member # 166467
4.88 are perfect for 35s. A little too much for 33s on the highway
Old 03-22-2017, 11:41 AM   #16 (permalink)
Valley Rock's Avatar
Member # 208306
X eleventy billion .
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 12:29 PM   #17 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
I've been running 4.56 gears in my TJ since '99 with both 33" and 35" tires and it works great both on the trail and on the street. With 4.0:1 low range they got me up Sledge Hammer twice once on 33's and again on 35's
DriverJC is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 03:56 PM   #18 (permalink)
Member # 19795
gears
Driver jc how did you get 4:01 low atlas
Old 03-22-2017, 10:09 PM   #19 (permalink)
Member # 166467
Wouldn't 4.0:1 be factory rubicon tcase
Old 03-23-2017, 12:59 AM   #20 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
Or a Tera low.
:tank:
