Inner race on spindle spins free? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2017, 03:22 PM   #1 (permalink)
Member # 148125
https://youtu.be/HMPyLuh5bfA
You'll see here how the inner race spins free on the spindle journal by hand. I've seen other spindles where the journal looks like crap because the bearing has spun on the journal. Is this going to cause me problems down the road? I'm considering one of these from ebay SPINDLE DANA 44 GM SMALL BEARING 706528X | eBay
I've been told they are cheap chinese knock off's and to stay away. The brand is DURASOLID out of California. From their description on their website, looks good to me. Opinions?
https://www.durasolid.com/
Found this thread, so far it seems their product is ok?..
http://www.pirate4x4.com/forum/gener...lid-stubs.html
Grumpy_one is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 07:41 PM   #2 (permalink)
goes to 11
Member # 200478
Your outer bearing should be a slip fit. It has to move freely to properly set your bearing preload. If you are really concerned, use loctite 609 on the race, keep it clean when assembling, and set the preload quickly. That is a low strength retainer that can easilly be broken without heat but will keep bearings from spinning. Typically used on electric motor bearings.
isbj60 is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 02:09 PM   #3 (permalink)
Member # 148125
The slip fit makes sense as to why I see spindles that look like the bearing has spun on these journals. Now I have to decided to keep the used ones or buy new. Thanks (the new durasolids are cheaper)
