97 TJ dies after 15-20 mins of driving. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2017, 04:48 PM   #1 (permalink)
Member # 109378
I just recently purchased a 97 TJ 4.0 auto 217,000 miles. It had been sitting almost a year with 1/2 of tank of gas. It cranked right up with a jump. I drive it about 20 mins temp sitting at 210 ran well. When I stopped it died and would not crank. I could start it on starting fluid and as long as I kept the rpm's up it would stay running. Around 1500-1200 rpms would bounce and just die. The next morning after sitting walked up and cranked right up. I drive it to the gas station and put some gas in it and drive home did fine. Drive it around my neighborhood could get it up to temp kill it and crank right back up. So I decided to drive it to work today about 20 min drive. When I got to work went to back in my parking spot and it died when I came to a stop. Would not crank back up. On my way to work I filled it up with non-ethonal gas because I thought I had the problem solved. Check engine light is not on, but have not scanned it yet. It idles around 600rpm's also. Tomorrow I will scan it and check fuel pressure, that's if it cranks in the am to drive home. Any helpful advice would be appreciated! Thanks
2013 3500 Dodge Laramie 4x4 Prairie Pearl
1987 K5 14BT/60 TBI454 400/205 42's
cclark746 is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 04:38 AM   #2 (permalink)
Member # 109378
Walked up cranked once died, cranked it up again started and drove it home. Except no stops this time, round trip about 15 mins.
Old 05-18-2017, 05:25 AM   #3 (permalink)
-jb-'s Avatar
Member # 117969
Wrong section to put this in. You've been here since 2008 and haven't figured that out yet?
Fuel pump.
Lets go wheelin!!!
-jb- is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 02:23 PM   #4 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Moved - looks like a bad fuel pump or one going out the door.
geberhard is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 04:41 PM   #5 (permalink)
Member # 109378
Fuel pump.
My bad... I was looking for hardcore tech! Might I ask how you came to that conclusion of the fuel pump?
Old 05-19-2017, 12:52 PM   #6 (permalink)
-jb-'s Avatar
Member # 117969
Because I had the same problem with my fuel pump in my TJ.
I've also seen the Crankshaft Position Sensor do some funky stuff.
But what you described sounds like fuel pump
Lets go wheelin!!!
Old 05-22-2017, 06:23 AM   #7 (permalink)
Member # 109378
Thanks!
Old 05-22-2017, 08:34 PM   #8 (permalink)
Member # 42887
Send a message via ICQ to stealthjeep1
Thanks!
A friend of mine had similar symptoms once upon a time. Long story but his turned out to be a cracked flywheel. Once it would hear up, it would warp enough the crank position sensor would stop reading. Let it sit for a bit and it would start back up.
Sent from my SM-G955U using Tapatalk
KJ6ZRM
Santa Rosa 4x4 Club
52 Rolling Gnomes
97 TJ, 4.0L, Manual, 4.5" RE Superflex Kit, 35" BFG KM2's
78 CJ5, 4.2L, Manual, 3" Skyjacker Lift, 32" Goodyear MTR's.
2005 Grand Cherokee Limited 4x4, 5.7L Hemi
2003 Ford F250 4x4 CCSB 6.0L Diesel
Never met a rock I wouldn't park on.
stealthjeep1 is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 08:54 PM   #9 (permalink)
Member # 56430
Guesses; fuel pump starting to go bad, bad Crank Position Sensor, or, the start of a clogged cat convertor
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12-'13
Member Eldorado Dust Devils, a PNW4WDA member
Treeclimber is offline   Reply With Quote Quick reply to this message
