House Stark
Death Wobble - 42ish to 45ish MPH
I'm getting some death wobble on my 97 TJ for those specific miles per hour. It started a while back (it's been parked for several months), and originally was a bad axle end trackbar bushing. Replaced that, still had it. Attributed to bad frame end bushing on trackbar. Replaced whole trackbar with brand new trackbar from 05 rubicon.
Possible things it may or may not be (that I'm thinking and don't know for certain): 1. Bad tie rods 2. Bad ball joints 3. Bad alignment (already has this, maybe it's off enough now because of horrible DW that it causes problems). 4. Wheel weights fell of tires and they are not balanced now (33 inch BFG Long Trails ATM). 5. Combo of the above. I took out the major players, and now only get it slightly during those MPH (give or take a little also). It's severe enough that it's noticeable, but nowhere near like it was when I had the bad bushing. |
Member # 31664
a new steering stabilizer will cover up any minor problems//allthough you might want to figure out exactly what it is so it doesnt get worse//same thing happened on my old 80 chev/new stab & it was good for at least the next year(sold it) everything on the front of my jeep is worn out some/new stab & at least i can drive it for now! will do rebuild when i replace axleshaft,swap gears, & maybe a locker/
aka ATF_jeepguy//90 yj 9"rear welded-buggy springs/d44 hp front soa 4" springs moved 2"s forward/full cage/35x14.50x15 swampers/ 4 banger & rattle camo [URL="http://www.flatfenderbrewing.com/"]http://http://www.flatfenderbrewing.com[/URL] [URL=www.atfclan.com]www.atfclan.com[/URL] [URL=www.rccrawler.com]www.rccrawler.com[/URL] [URL="http://profiles.yahoo.com/flatfenderbrewing"]http://profiles.yahoo.com/flatfenderbrewing[/URL] |
Member # 63252
Same here...
I have more or less the same problem and in my opinion it is all about caster. Did you solve your problem anyway? If you did, what did you do? Please let me know. Thank you.
spot me? mydfghgfff!
Member # 25303
I had a similar wobble on my 98 TJ. I had the toe aligned and the stabalizer replaced, but it was still there. I had to get a 2nd stabalizer put on and that did the trick. If you don`t want a 2nd stabalizer, try getting your tires balanced.
97 TJ 4.0/np435/d300/3link/4link in progress Ultimate Wrangler Build Ups and Swaps Thread
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! |
Member # 47925
balance your tires. try rotating as well as that's free and you won't notice unbalanced tires in the rear as much. This has happened to me in the past and thats how i fixed it.
simple oh, and definitley not 'hardcore tech' |
#10 (permalink) | |
Member # 63061
#13 (permalink) |
Member # 8328
If it's a 97 should have cam bolts on the lower control arms. You could check and see if they have loosened up (or perhaps you lossened em up for some reason and moved em). They do allow you to change the caster to a certain degree. Usually caster is the culprit although other things can contribute to the problem..
[color=green]GreenMachine[/color] |
#14 (permalink) | |
Member # 25303
That wouldn't cause it to wobble though; That's for tire wear. It would have to be horribly off to cause a wobble at a certain MPH. If, for example, it started wobbling at 30 and never stopped after that, then toe adjustments would have to be considered
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more! Now incorporating a CJ and Willys section, post your tech and builds! Last edited by gtxracer; 01-01-2006 at 03:59 PM. |
#15 (permalink) |
is this a stock D30??? also check your wheel bearings.....
2002 TJ 4.0L 5sp. D300 ARB'd D44 F/R 37" MTR/s [QUOTE=Diesel Smoke;7969796]It takes two things to build a rig, money and time. Having alot of one means needing less of the other.[/QUOTE] |
#16 (permalink) |
Member # 37992
Does it have a aftermarket pitman arm? I have seen if the arm is aftermarket (dropped) but the track bar is in the factory local (or vice versa) it could cause DW.
lagrange151 - TJs don't have shackles or shims. They are five linked front and rear.
What the hell... |
#17 (permalink) |
The death wobble can also be caused by problems in your suspension. My 2003 tj had death wobble problems at the same MPH range you said. I tried steering stabilizers and balancing rotating tires with no change in DW. I replaced all ball joints in the steering and nothing changed. If you are running the stock suspension and wheel it hard then you might wear out your bushings which was the cause to my death wobble. I replaced all the front end bushings with the rubicon superflex joints (except upper link bushings on axle) and wobble was gone (not to mention increased flex) and has never come back and i dont even use steering stabilizers now and im sure my tires are off balance since ive lost a couple beads and havnt had them balanced since i bought them 20k miles ago i just rotate them. Another thing to change (which is alot cheaper than the new joints) is get a new front trac-bar that does not use a poly bushing and used a heim setup. Check your trac-bar bracket on the frame and ensure it has no chacks. Most rigs ive seen that drove with a death wobble developed cracks on that bracket which eventually failed. The casting left little grooves and lines on the sides of the cast bracket and they make it easy for cracks to develop there. Good luck.
#18 (permalink) |
Member # 13620
The problem with a death wobble is everything mentioned so far can cause one. I suggest you make sure your trackbar is as tight as you can get it at the axle. Have someone quickly steer the steering wheel back and forth while you watch the componets for slop or looseness. I once found a loose trackbar on the axle end of my XJ like this. I had a slight shimmy at 45 to 50 on my XJ and soon it was a DW! Believe me thats scary! I eventually cured it by replacing the complete tierod-draglink-steering stabilizer setup with a ZJ setup I had laying around. Worn TREs, draglink bushings and trackbar bushings or loose, worn componets, bad alignment, and out of balance tires can cause or contribute to a DW. Its a matter of finding the cause or causes of your particular DW that can be a b*tch!
97 TJ 4.0L with modifications 106" WB 4:1 Locked front and rear with 37" MTR's R.I.P. Lowtech and Skii4X4 |
#19 (permalink) | |
Member # 50242
... Shit happens. Carry a shovel. ... |
#20 (permalink) |
Member # 43184
If your front is tight, and alignment is right, tires shouldnt throw you into DW. Shimmy a bit, yeah, DW no.
Track bars biggest/simplist culprit on tj 5 links, then wheel bearings, then alignment. If you have it tuned down to just a shimmy, should be alignment. If not 1. Tighten check both ends of track bar 2. Remove wheel an brakes, test unit bearings for play 3. Check balljoints 4. Go for an alignment This process usually works for me. Gone through and tuned out a lot DW on tj's in the last few years HTH |
