spring compressors - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-03-2005, 10:09 PM   #1 (permalink)
Member # 38729
Send a message via AIM to big blazin sc
spring compressors
I am about to put a 3 inch rough country kit on my xj and i was wondering do i have to have a spring compressor to put it on. thanx
big blazin sc is offline   Reply With Quote
Old 10-03-2005, 10:18 PM   #2 (permalink)
Beat95YJ's Avatar
Member # 22176
Not likely. Disconnect the shocks and swaybar. If that doesn't do it, disconnect the track bar and unlock the steering. Should work fine. Also if you push up on the other side it will often help the side you are working on droop out.
Beat95YJ is offline   Reply With Quote
Old 10-04-2005, 04:23 AM   #3 (permalink)
Member # 32823
you dont have to use a spring compressor , but it will make life easier .
when i did mine , i found that the lower arms limited the down travel of the
axle . even with the shocks removed .
that is if you still have the stock arms .
sw_mi_xj is offline   Reply With Quote
Old 10-12-2005, 08:37 PM   #4 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
Mo is offline   Reply With Quote
Old 10-12-2005, 09:36 PM   #5 (permalink)
Low Range Drifter
JohnnyJ's Avatar
Member # 7903
I once thought that spring compressors were needed because I listened to others on the intarweb, but then I figured out a pry bar and/or a fat guy standing on the axle works just fine.
I'm a fat guy, so there's always one available; and most people have a pry bar. If not, stop at the store and get a case a beer and start working on your belly so you don't need spring compressors.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig
Thanks to Drivetrain Specialists and PAC Racing Springs for your support
JohnnyJ is online now   Reply With Quote
Old 10-13-2005, 08:19 AM   #6 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
you can get a compressor for $10 or so from harbor freight. I used one and it came in real handy..
This Space for rent!
Brandon is offline   Reply With Quote
