Part number for front waggy 44 bearings? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-07-2005, 10:18 PM   #1 (permalink)
Member # 33991
What are part numbers for the inner and outer bearings for an 89 waggy 44. What about the races? The chart over at Mr. N's website only had the early 44 part numbers.
lilgreenjeepyj is offline   Reply With Quote
Old 10-07-2005, 10:30 PM   #2 (permalink)
Member # 53004
1978- 1992 uses the same front D44 parts
706031X - inner pinion bearing kit
706030X - outer pinion bearing kit
also try using the dana expert website when looking for dana parts
'93 YJ
JeepTPI is offline   Reply With Quote
Old 10-08-2005, 06:14 AM   #3 (permalink)
Member # 26405
Timken:
Outer- set45
Inner- LM104949
Race- JLM104949
Seal- 471271
Nick@lockitup is offline   Reply With Quote
Old 10-08-2005, 09:56 AM   #4 (permalink)
Member # 33991
Thanks a bunch. I didn't even think about the dana website. Next time.
Hub Bearings. Forgot to mention that.
Old 10-11-2005, 06:29 PM   #5 (permalink)
CSP
Member # 1533
I know this is late, but your old bearings should have those numbers imprinted on them. So should the races. Bearing part numbers are fairly universal, usually just with one digit added to them depending on the make.
This might be helpful for future reference on any automotive bearing.
CSP is offline   Reply With Quote
Old 10-11-2005, 06:51 PM   #6 (permalink)
Member # 33991
Thanks, the old bearings weren't timken though.
Old 10-13-2005, 06:10 PM   #7 (permalink)
CSP
Member # 1533
It doesn't matter the make of the bearings. As I said, bearing part numbers are pretty universal.
For example a Timken Dana 44 carrier bearing is part number 25590. Another brand of the same bearing might be a 25590G or G25590. The important part is the actual numbers which don't usually change from brand to brand as long as they are for the same application.
Old 10-13-2005, 07:54 PM   #8 (permalink)
Member # 26405
i wish bearings were just a number off, it would make things a lot easier. For the most part, they arent though....
Old 10-13-2005, 08:06 PM   #9 (permalink)
Member # 784
Usually, even the idiots at vatozone can cross reference those numbers. You *should be able to take almost any bearing in there and have it crossed to a timken number
Think for yourself
JEEPRZ is offline   Reply With Quote
Old 10-14-2005, 04:18 PM   #10 (permalink)
CSP
Member # 1533
Every bearing I've used has a very similar part number. It could be because I stick with the same two or three brands though and none of them are the cheap imports.
As Jeeprz mentioned any real auto parts store should be able to cross reference an old bearing part number to another brand anyhow. There again, I stay away from the parts stores with the pimpled kids behind the counter who wouldn't even know where the bearing book is located.
