Power Steering (Help!) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-08-2005, 12:30 PM   #1 (permalink)
Member # 19129
Send a message via ICQ to SPINALDEX Send a message via AIM to SPINALDEX
My 92 YJ is Manual steering, I want to change it to power steering. I have the power steering box and steering arm from a 92 powered YJ, and I know I need a pump, reservoir, hoses, and a different pitman arm.
Could someone give me som pointers or what else I need to get this going? Thanks!
SPINALDEX
SPINALDEX is offline   Reply With Quote
Old 10-10-2005, 04:34 AM   #2 (permalink)
Member # 17445
I don't know about YJ's, but my CJ steering shaft didn't fit the power gearbox, so you might see about getting that too.
Oh, and get the mounting bracket for the pump-to-motor.
[url="http://mysite.verizon.net/dchurch1/jeep/CJ5"]'73 CJ5[/url].
donjr5 is offline   Reply With Quote
Old 10-10-2005, 04:57 AM   #3 (permalink)
tys
Member # 356
Send a message via ICQ to tys Send a message via Yahoo to tys
I have a pump, hoses and assorted brackets off a 4cyl YJ. I also have a spare pump from a 6cyl CJ. Not sure if I have pulleys (I might). Let me know if you're interested and where you live - see if we can work out a dealio...
Chris
tys is offline   Reply With Quote
Old 10-10-2005, 05:01 AM   #4 (permalink)
Member # 39060
Send a message via Yahoo to jeepcjsc
on my cj i just changed the coupling on the end of the steering shaft and that solved that part
jeepcjsc is offline   Reply With Quote
Old 10-11-2005, 09:44 AM   #5 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
You need the gearbox, pump, bracket, new belt and hoses, and new shaft.
Your old pitman arm should work.
actionpaintball is offline   Reply With Quote
Old 10-11-2005, 07:05 PM   #6 (permalink)
Member # 54168
Send a message via AIM to mudeejeep
to make it easy you will want the pump with the serp pulley other than that i think that the brackets should fit
mudeejeep is offline   Reply With Quote
Old 10-11-2005, 07:29 PM   #7 (permalink)
Member # 2331
Would the PS gearbox and pump off of a '86 or '88 XJ work on a YJ?
Warlock is offline   Reply With Quote
Old 10-12-2005, 04:58 AM   #8 (permalink)
Dabbler
Member # 29562
NO
