Suspension or shafts?
98 tj - RE 4.5" SHORT ARM - D44/Ford9" - 35 MT/R's
Heres my problem... I run AZ trails 3-4.5 in rating out of 5.5 every 3rd time I go out it seems like now I am breaking axle shafts. I was planning on going to chromoly shafts to eleviate the problem but then I was informed of another issue that might be contributing to my dilemma nad possible break my cromo's too When I walk up to a rock, my suspension due to the short arms flexes down AND ALSO BACKWARDS so that when my heep starts to go over it has to fight its way to original position AND THEN up the rock so essentially the axle shafts are pulling double duty.... Now my question is this Since I really do have l;imited funds is it better to get a long arm kit and switch to that.. or should I just get the cromos and that would solve everything? I'm basically wondering if the long arms would help so much that I would be able to run stock shafts without breaking them Thanx for your time Sincerly Dumb Newbie |
Member # 20983
I know exactly what you are talking about. I had the same problem, only on an XJ. Definatly go longarm. It will be the best upgrade you can do. I have ripped mounts off the frame from the added stress when that happends. I am now 3" higher with longarms and never have the problem.
#6 (permalink) | |
um..not exactly. The problem you are having is your control arms being to short, and the arc that the suspension travels in is not where it should be. You are going to keep breaking those axles (Im guessing d30/d35) no matter what, if you get new shafts, then it will be something else. I would suggest doing longarms and then saving for some real axles, putting money into the combo you have now is pointless
8 lug ZJ |
#7 (permalink) | ||
Member # 11890
He has the axles |
Member # 53544
Before you spend alot of $ try redrilling your lower control arm mounts to alleviate some of the angle. Obviously you will move the holes down on the upper mount, and up on the lower mount. I haven't measured it, but I believe you can move the upper down app. 1 inch, and lower up app. 1.5 inches. Just be sure to leave enough material in the upper mount to retain strength. Btw cromo shafts rock.
yes DANA 44 FRONT... FORD 9" REAR...
I'm still getting mixed results here I have 4.5" springs 1" body 1"motor mount can I get a general concensus before I decide to just say phucket and cut everything off and make my own 3 link out of 2 inch square tube and JJ's which would be alot more work for me right now and would rather not do unless I have to |
#12 (permalink) |
un-balanced suspention and wheels getting bound is what kills shafts...
fix that and buy some more spicers... I am asuming from your description that you are blowing the front shafts - not the 31spline 9" shafts...
Bryan 'Opie' Bennett JV Rally Post #175 Tellico Rally post #531 Last edited by XJ_ranger; 10-09-2005 at 10:07 PM. |
#14 (permalink) |
Member # 38716
i know what you mean, i use to have a short arm setup like that too.............i would fix that and go long arms, totally changes everything, especially if your running the 4.5" coils with short arms........with 35's though i cant believe your busting that many 44 shafts...........
America is all about Speed. Hot, Nasty, Badass Speed...... Last edited by 00pumpkin; 10-10-2005 at 02:11 PM. |
#15 (permalink) | |
Member # 51511
It sucks when you come up to a ledge, your front tire drops a bit as it goes into a hole....you watch your suspension flex and move the tire towards the rear of the vehicle.....then as you continue to move forward, the tire has to move to the rear while trying to climb. Been there, done that with a 6" lift and short arms. While I was not loosing front shafts, I sure as heck enjoyed the conversion to LAs. |
#16 (permalink) |
Member # 26201
Putting in the long arm kit was one of the best mods I did. I too have the 4.5" RE, 1" body and MM lift. Do the long arm kit. I HAD to do the LA with my 4.5" RE Kit. It was more like a 6" lift. The ride and off road capabilities sucked with the short arms. Once I did the LA it was a totally different ride on and offroad.
I drove my Jeep with D30 and D35 with 35" tires and finally broke a rear shaft after 2 years when the Jeep was sideways and pinned up against a wall, then went 8.8 never broke, then went to D44 front and now a 9" rear and 38's.
Just a spectator now.... |
#17 (permalink) |
Member # 14780
weld a small hoop onto your axle, attach winch cable to it, tighten cable when going up onto big obstacles.
04.5 cummins lb,qc,white, 4x4,,bddl, outlook,, exhaust 315 bfg's 02 WRX caged etc new buggy http://www.pirate4x4.com/forum/showt...43#post5890143 save tellico post #830 |
#19 (permalink) | ||
