Gauge Help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-09-2005, 08:32 PM   #1 (permalink)
Member # 40872
Gauge Help
I amin the process of rebuilding the dash on my yj, i am making it a flat stile like a cj. For the people who have also replaced the factory gauges with aftermarket what ohm range gas gauge did you all end up using thanks for your help.
ECG
East Coast Ghost is offline   Reply With Quote
Old 10-10-2005, 07:44 AM   #2 (permalink)
Member # 19164
Send a message via AIM to FrankyYJ Send a message via MSN to FrankyYJ
I used this: Autometer 2641 - 2 1/16 Fuel Lever (0 empty/90 full)
Henri
'91 YJ 360/727/208, SOA Waggy Leafs, D44, M20, 4.56 Gears, Detroits F/R, 37" Boggers (HP60\14B build in progress)
FrankyYJ is offline   Reply With Quote
Old 10-11-2005, 07:04 PM   #3 (permalink)
Member # 40872
hay thanks for the help.
Old 10-11-2005, 07:23 PM   #4 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
No aftermarket gauge will work with the YJ i dont think.... I think its some goofy ohm interval... I could be wrong though i cant remember if it was the YJ or the CJ stuff that is goofy
Schmozilla is offline   Reply With Quote
Old 10-14-2005, 06:47 AM   #5 (permalink)
Member # 2769
To the best of my knowledge ...
CJ Sender Specs ...
10 ohms full
73 ohms empty
YJ Sender Specs ...
120 ohms - full
10 ohms - empty.
TJ Sender Specs ...
20 ohms - full
220 ohms - empty.
(Fuel level signal wire goes through the PCM)
Jaffer is offline   Reply With Quote
Old 10-14-2005, 01:07 PM   #6 (permalink)
Member # 27230
Send a message via AIM to JEEPSKEET
Heres a good write up on it...
http://www.off-road.com/jeep/reviews/dash/rlwdash.html
If anyone ask's, I got it off E-BAY for $100.00
JEEPSKEET is offline   Reply With Quote
Old 10-18-2005, 09:04 PM   #7 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
Mo is offline   Reply With Quote
Old 10-18-2005, 11:05 PM   #8 (permalink)
Member # 51676
Arrow
I'm not sure how accurate these #'s are from Jaffer..
CJ Sender Specs ...
10 ohms full
73 ohms empty
YJ Sender Specs ...
120 ohms - full
10 ohms - empty.
TJ Sender Specs ...
20 ohms - full
220 ohms - empty.
I know these are right..
0 E-90F
73E-10F
240E-33F
240-33.5 (not sure which is Empty & which is full?)
16E-158F
these numbers are from http://sw-performance.com/products/p...yid=63&ispod=0
And if your looking for design ideas.. here's mine its in a CJ-7 though... and I used the gauges from the link above..
kury is offline   Reply With Quote
