Member # 36676
eye to eye measurements for YJ leafs?
Anyone got the eye to eye measurements for the front and back leafs by any chance?
Even better if you know what the same measurement is for the 2 1/2T front leafs are (that are usually used with Rockwells, hint hint) Thinking of a new project, but I can't get leaf measurements off my TJ! Thanks. -BN Last edited by Bnovak; 10-12-2005 at 04:04 PM. |
Moderator
Member # 5861
I was going to reply, but since it is posted and can be searched, it will help you try the search function before posting. Not flaming you, but for your own good.
I may have the info on my sig... Gui |
Member # 15811
Old info, but this may help:http://www.4x4spot.com/spring_swap_info.htm
[COLOR="Lime"][SIZE="3"][B]booger weldz [/B][/SIZE]alternate account[/COLOR] 1994 fzj80 Elockers front and rear, 35 km2s, 10k winch, coolest station wagon in the world!! [COLOR="Silver"]♣[/COLOR][B][COLOR="Lime"][FONT="Arial Black"][B]Bink'sFab[/B][/FONT][/B][/color][COLOR="Silver"]rication[/COLOR][COLOR="Lime"]♣[/COLOR] - [URL="http://facebook.com/binksfab"]facebook.com/binksfab[/URL] |
#5 (permalink) | |
Moderator
Member # 5861
No flaming, but read three times his first post so you understand what is being asked. |
#6 (permalink) | |
Member # 36676
wow - yer fawkin' smart aren't ya. I'm thinking about buying my neighbors YJ from him. The reason I asked about the eye to eye measurement is that I'm trying to figure out how far I'm going to need to move the shackle mounts to fit leafs from a deuce to keep a pair of rockwells under control. I was going to do rockies on a TJ, but I think I can get almost as much flex out of a leaf suspension. Saves the hassle of building links for coils. The goal is to run as little lift as possible (I know, I need some to clear the 3rd member on the rockwells) and then just trim the body as needed. Goal is to roll 44's or maybe 46's. I'll probably have to bob or comp cut the rear end which isn't a big deal. The puny little 4 cylinder that's going to get stuck up in front of these axles is going to have a heart attack though (more on that to come.) Thanks fawkers - I'll use the search, I promise. -BN |
Moderator
Member # 5861
hehe , no worries, and keep the build up coming. There are a couple rigs running leafs with Rockies under. ALso chekc out the JP Mag hotdog projct for some ideas n the rockwell and leaf setup, Cappa and whoever worked with him did a good job and the install looks pretty clean. I think his rig was on TTC this year, so do a search fro top truck challenge, maybe here or Google or check the JP site for some close up shots of the build for some ideas.
Gui |
#8 (permalink) | |
Member # 36676
moving these things around is going to be a byatch though....and I'm going to HAVE to cut the windshield and cage off (oh darn, have to do a custom cage.) searching I go.... |
Moderator
Member # 5861
Nice, BTW cappa is on the board as well, so you could probably hit him up with some questions. I did the u-bolt to leaf mount on the rockwells, look pretty clean and easy.
Honestly, with rockwells I do not think you will need way tooo much flex, those are heavy as heck. I think the XJ springs would possibly not survive for long on them, maybe F150 thicker springs could be a good choice, or J truck springs. ![]() http://jpmagazine.com/projectbuild/154_0406_dog/ |
Member # 36676
I was originally thinking (yeah, in a bout of stupidity) of running the leafs from the deuce! That's why I was wondering on the leaf measurements for the YJ as I wanted to see how close they would have been to "bolting on." Yer right though, It's not going to need much flex - and I'm aiming for low COG and low lift anyway, so stiff works for me.
I think the F150 (maybe F250?) leafs are going to be the way to go though in the long run. There's plenty of them in the junkyard so it's easy to come by. I do like those U-bolt mounts - did you guys find that it was more rigid using that setup rather than a clamp on the bottom of the axle, or was it more for clearance? Is that just 1.5" DOM tubing or something? (the size wasn't in the article.) The other thing that concerns me is the 3rd member height & impacting the radiator. that's going to be tricky to figure out. |
