who makes flexy yj springs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-13-2005, 07:43 PM   #1 (permalink)
Member # 53048
im about to do a spring over on my CJ (using yj springs) and was wondering what companys make good yj springs with little or no lift (ie. 2" or less). Im looking for maximum flex here so would it be any better to just go with factory yj springs or are there flexier springs out there.
thanks, jake
dirty_dodge is offline   Reply With Quote
Old 10-13-2005, 08:23 PM   #2 (permalink)
Member # 3974
Send a message via MSN to Isley
Find a set of used factory YJ springs, should have all the flex you want.
I've heard good things about the SOA RE springs also.
'93 YJ 4Banger
Isley is offline   Reply With Quote
Old 10-13-2005, 09:04 PM   #3 (permalink)
Member # 54395
some of the re multi-rate springs (the extreme duty) would be a good choice.i think the smallest in those are 2.5 though.
might also just look into some re stock replacements
rsoffar is offline   Reply With Quote
Old 10-13-2005, 09:27 PM   #4 (permalink)
bspencer's Avatar
Member # 18675
Send a message via Yahoo to bspencer
either the RE yj SOA springs or stock yj springs with a full length add a leaf in each pack
Mountaineer Off Road
Facebook
Originally Posted by SilverZuk View Post
You forgot the 3 rules.
1. If she is below your standards - drop your standards.
2. If she is ugly early - start drinking early.
3. No woman is ugly with your dick in her mouth.
Spotter Team 304 MudRiver Motorsports traded the rig
bspencer is offline   Reply With Quote
Old 10-14-2005, 01:02 AM   #5 (permalink)
Member # 13055
Stock YJ 5-leaf packs front & rear, with an additional main leaf in the rear. Will flex very well and can be had for considerably less $.
Stonefly is offline   Reply With Quote
Old 10-14-2005, 01:21 AM   #6 (permalink)
Military Jeeper's Avatar
Member # 2864
Send a message via AIM to Military Jeeper Send a message via MSN to Military Jeeper Send a message via Yahoo to Military Jeeper
A word of caution on springs that are too soft...........it's called Axle Wrap. You need a slightly stiff spring on the rear, or an anti-wrap bar otherwise your rear springs are going to be worthless and have negative arch after enough hard-core wheeling trips. Just my .02 cents...
79 CJ-5 | SOA | 304/T18A/D20 | D44's | 4.11's | ARB's | HAD Shafts | 35" Toyo MT's |
Military Jeeper is offline   Reply With Quote
Old 10-14-2005, 06:29 AM   #7 (permalink)
Rattlecan's Avatar
Member # 50639
I have heard good things about Old Man Emu (OME) springs... I think they make some 1.5" YJ leaf packs for SOA.
I run stock and agree with Military Jeeper - Run some sort of anti-wrap in the back if running stock or your packs will start to bend into an S shape.
Might want to do a quick search on brewing your own packs - I think a few people have had good luck running waggy springs, or mixing stock YJ packs with the main leaf in a Chev or Ford pack to limit wrap.
Rattlecan is offline   Reply With Quote
Old 10-14-2005, 06:38 AM   #8 (permalink)
95steel's Avatar
Member # 14509
BDS Look no further. Lifetime warranty with no ?'s. You break it, they replace it.
95steel is offline   Reply With Quote
Old 10-14-2005, 07:08 AM   #9 (permalink)
Member # 13176
Alcan - last set of springs you'll ever buy.
Brian Lucero
SubCulture New Mexico
www.subcultureworldwyd.net
SubCultureNM is offline   Reply With Quote
Old 10-14-2005, 07:08 AM   #10 (permalink)
Beat95YJ's Avatar
Member # 22176
RE 1.5" SOA springs work great. I have 3 friends running them and they have nothing bad to say.
Beat95YJ is offline   Reply With Quote
Old 10-14-2005, 07:27 AM   #11 (permalink)
Member # 15049
http://full-traction.com/detail.php?...TID=115&NOTES=
1986 K30
sw99 is offline   Reply With Quote
Old 10-14-2005, 08:47 AM   #12 (permalink)
WeBilt 4x4
JDunn's Avatar
Member # 33065
I have ran 4 of the YJ RE 1.5" SOA springs for two years and loved them but needed a bigger lift. What size tire are you going to run? I have been running 35"s with these springs but had to cut the finders out a lot! These springs flex like no other. I can easily pull up on my buddys 42" tire and not pull a tire.
JDunn
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
JDunn is offline   Reply With Quote
