What Parts?
Here's what I need to know, and price doesn't matter:
1) Which Springs:
1) Stainless Steel Brakelines:
This is all in my attempt to make my SOA CJ-5 a wheeler and daily driver. I need to make sure I have a comprehensive itemized list of what I am going to splurg on redo'ing the SOA. The current setup is OE 2" Front Springs, OE 2.5" Rear Springs w/ crappy SkyCrapper Shocks and Steering Stabilizer. Axles are staying stock until I leave Hawaii next year as shipping on two D60's is almost as much as the axles themselves. Please help me out guys, if I am missing something, let me know...if you have recommendations, especially regarding the "Springs" let me know as well. Let the bashing begin
79 CJ-5 | SOA | 304/T18A/D20 | D44's | 4.11's | ARB's | HAD Shafts | 35" Toyo MT's | |
Gravo Malum!!!
Member # 16548
Ok, now that you are in the right forum
Springs: -R.E. for sure Shocks: -toss up between bilstein and fox stabilizer: -screw it and go with a hydro assist from PSC or west texas (I went with PSC and love it with 38" SX's) Shafts: -High angle all the way, I know Jesse personally and he's the best with customer service and has helped with tight deadlines and his product rocks Shackles: -I like the ones Bluetorch Fabrication makes, same idea as the others but with some "improvements" to the designs Brakelines: -they are all the same, I used Earls Swaybar disc. -The JKS ones may be cheaper but I like the new ones by R.E. if you haven't seen them yet. High steer: -M.O.R.E. makes something I think Shock towers: -Make your own Traction bar stuff: -Again Bluetorch fab has all kinds of brakets available Hope this helps, since I was so mean before
98' XJuggy |
Member # 47487
I like Carolina Driveline drive shafts. They can even do cryo if you really want to get strong. The rest looks good...I guess. What size tires are planning to run? How do plan to wheel it?
1. You may need to re-gear the axles to keep high gear on the highway. <31' = 3.07 <33" = 3.73 <35" = 4.10 to as much as you can get 2. I would lock the front axle, in the very least. For a DD you can go cheap with a lunchbox (Lok-Rite or Detriot) or you can do it up a bit and get nice selectable locker like an ARB (which will need on board air )3. Axle shafts. Depending on tire size and wheelin style, you may want to think about cromally shafts. Even if you run what you have, get some good ones to replace your stock ones with if (read as when) you snap them. 4. Roll cage, rock sliders....steel stuff to protect passengers and sheet metal, depending on prefferences 5. Stickers....they add HP
I don't like repeat offenders, I like dead offenders. Mr. Ted Nugent |
Moderator
Member # 5861
Brake lines, check out speedwaymotors.com really cheap and stainless steel brake lines that are 48" long for only $15, beat that
![]() Check my sig, a lot of info on a SOA and parts, build, etc that could help ya ![]() Gui |
Member # 14004
My advice is to sell the 5 in Hawaii and buy another when you get stateside. If you think shipping on 60's is bad... Now, you need to think a little about ultimate tire size and lift. That will dictate wheelbase and width. A SOA CJ-5 on 38's with stock wheelbase has no place on the trail. Fine at the mall or show, but too tippy on the trail.
My opinions: 1) RE SOA 2) Bilstein 3) None, steering stabilizers are sooo 70's 4) Tom Woods has been very good to me 5) No opinion, a shackle is a shackle Other opinions: 1) Brake line length matters, I like rubber, you like SS 2) Swaybars are for link suspensions, ditch it. 3) Do the steering as simple as possible, you will ditch it all when you go to 60's. Hell, this alone would cover shipping for one of the 60's. 4) F-250 if you want function, hoop if you want bling 5) Sam's Offroad HD bar. Forget the Bam bar.
82 CJ7 - TBI 304/T18a/D300/44/70/4.88/40's 87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's |
#7 (permalink) | |
Member # 62
Jeff Neves |
Moderator
Member # 5861
I suggest starting witha budget, people can give you more info based on that as well. I think you can do a SOA from a couple hundred bucks to close to a grand depending what you are getting and where.
Gui |
#9 (permalink) | |
#10 (permalink) | |
Thanks.....see blue
#11 (permalink) | |
#12 (permalink) | |
#13 (permalink) | |
#14 (permalink) |
[COLOR=DarkRed][SIZE=2][FONT=Palatino Linotype]XXX [COLOR=Red]STRAIGHT EDGE [/COLOR] XXX[/FONT][/SIZE][/COLOR] |
