Member # 41844
help quick
im at work and cant get the bolts off. I need to know what size and length the xfer case skid bolts. I need to pick up some new grade 8 ones after work and dont have time to run home and then back out before the store closes. please let me know what they are. i called the stealership and the parts guy said the didnt list a size only a p/n
93YJ 2.5L 5spd,D35 locked and trussed,D30 powertrax and trussed,4.0L TB,4.0L TB Spacer, Warrior Products rear bumper,Bigrocks offroad front stinger bumper,2.5" ghetto lift,rancho 5000's,taurus fan,arb snorkle,31x11.5 super swamper truxus A/T STS on cragar soft 8s |
Moderator
Member # 5861
Sorry, do not have access to them here either, but can you buy them at the stealership, take them to OSH or Home Depot, get 8 grade, and return the stealership ones back? How much are the stealership ones? MAybe just worth buying them?
I googled a crossmember lowering kit. According to fabtech (their 3.5" lift kit) their kit uses 1/2"-13 x 3 1/2" bolts to bolt on the crossmember spacers.
Look at the parts list, it is the only 3 1/2" long bolt supplied. Look at step 16. http://www.fabtechmotorsports.com/pd...on%20Sheet.pdf In the pic they look like 1" or longer spacers. So I would assume 2 1/2" bolts would work. Or you can call fabtech and find out how big the spacers are. Hope that helps.
Is:92 YJ 4.0 AX15 NP231 D30 D35 Will Be: 92 YJ 4.0 NP435 NP205 D60 14 bolt SOA waggy spr. [URL]http://www.rawsoftware.com/YJ-Mule/[/URL] Last edited by yj-mule; 10-14-2005 at 02:19 PM. |
Member # 30471
I have one at my desk out of my 98 wrangler and the threaded shank before the cone washer is 1.25" long and the head with the cone washer and head measure .778" total length is 2". and it is .5" x 13 thread.
Ugly All Day!!! |
