MJ rear lift
I have a 1990 MJ, D35 rear. I need to lift the rear 2-3" without going springover (not legal here) and I am going to swap in the main leaf from a s-10 (with the eyes cut off) as a add-a-leaf.
The question I have is how important are the plastic spacers between the leaves? Also, should I keep the spring clamps? |
Member # 22209
Keeping atleast 1 clamp is a good idea, it keeps the leafs from 'fanning out'.
If it's the type of the clamp with the bolt through the top of an open U, taking out the bolt free's up some travel, but still limits fanning. Those spring inserts reduce friction between the leaves, so leave them in where you can. When you cut the eyes off the S-10 leaf, atleast debur, and taper the cut off end. Tapering the sides a little will help some too, but it's not as importaint as cleaning up the end. Not being able to spring-over an MJ really limits you. Guess I won't be moving to Maine anytime soon.
88' hEEP trail rig 89' hEEP daily driver |
#4 (permalink) | |
![]() just get soem TJ flares and cut the clearince you want.
-Taz, '89 YJ Last edited by YJ4LIFE; 10-15-2005 at 05:05 PM. |
Everyday is Tuesday.
Member # 47
oh, and check in with the guys at http://www.neow.net
There's guys in Maine running spring over. just gotta know where to get the sticker done. |
wow main fuckin blows donkey balls. fuck that place
-05 yamaha yz125 -86 comanche 4.0. soon to have 33 tsls, after i fix the windsheild, tranny, clutch, and brakes. [QUOTE=Sully]Nasty strippers are way more entertaining that hawt ones. The nasty ones will shoot ping pong balls out of their cooters and at your buddy for a dollar. Now THAT is entertainment.[/QUOTE] |
how much lift will soa get you on an mj? i think i might do it
