CJ7 Project, A to be rocker - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-15-2005, 10:18 AM   #1 (permalink)
Member # 55590
Wink CJ7 Project, A to be rocker
I am building a CJ7 project. I need some help. I am goeing to put Currie 9" axles for the rear, A hp44 in the front, Detroits in front and rear, Disk Brakes, 1 ton tie rods, And a M.O.R.E Power Steering Box. I have a Ford 280hp 5.0L V-8 Engine, Goeing to do spring over, 35" MTR's, Full Custom Roll cage, Dual exgaust, 4:88 gears, a NP231 transfer Case, C6 Auto trans. Now tell me if this is a good set up. I am goeing to use this on street a little.
jeep_crazy is offline   Reply With Quote
Old 10-15-2005, 10:36 AM   #2 (permalink)
Member # 47074
Send a message via AIM to XJ618
why not an np205?
[COLOR=DarkOrange]fj40/45 buildup in the works.
[/COLOR]
XJ618 is offline   Reply With Quote
Old 10-15-2005, 10:38 AM   #3 (permalink)
JeepinDoug's Avatar
Member # 13028
You're really young right?
Push away from the keyboard.
Start reading all the Jeep posts you could regarding your inteneded specs.
Just keep reading and reading.
You've gotta lot to learn.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 10-15-2005, 11:03 AM   #4 (permalink)
Member # 62
Originally Posted by XJ618
why not an np205?
or a dana 20
Jeff Neves
NE-RokToy is offline   Reply With Quote
Old 10-15-2005, 05:48 PM   #5 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
Mo is offline   Reply With Quote
Old 10-16-2005, 07:08 PM   #6 (permalink)
Member # 48365
why not an np205?
You will need a $$$ adapter for the c6-np231 combo. Plus the np231 i a chain driven t-case and its aluminum, which is weaker than a gear driven t-case. I wouldnt waste the money on a np231, find something else....and read on
Jeepkid8037 is offline   Reply With Quote
